Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 3
MODEL: CEP-1116 | DESCRIPTION: PIEZO BUZZER TRANSDUCER
FEATURES
• piezo transducer with pin mount
• 90 dB SPL
• 2,000 Hz rated frequency
SPECIFICATIONS
parameter
conditions/description
min
typ
operating voltage
current consumption
at 10 Vp-p, 2,000 Hz square wave
rated frequency
max
units
30
Vp-p
8
mA
2,000
sound pressure level
at 10 cm, 10 Vp-p, 2,000 Hz square wave
electrostatic capacity
at 1 kHz/1 V
dimensions
Ø30.0 x 10.0
Hz
90
19,600
dB
28,000
36,400
pF
mm
weight
material
ABS UL94 1/16” HB High Heat (black)
terminal
pin type (Sn plating)
5.6
g
operating temperature
-30
85
°C
storage temperature
-40
95
°C
max
units
380
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering2
for maximum 2 seconds
330
Notes:
2. Not recommended for wave soldering
cuidevices.com
typ
Product Page
3D Model
CUI DEVICES | MODEL: CEP-1116 | DESCRIPTION: PIEZO BUZZER TRANSDUCER
PCB Footprint
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
01 17
CEP-1116
CHINA
Week
01
02
Year
19---2019
20---2020
FREQUENCY RESPONSE CURVE
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
09/12/2006
1.01
brand update
03/12/2020
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CEP-1116”相匹配的价格&库存,您可以联系我们找货
