SMI-1324-TW-5V-2-R-T/R 数据手册
SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
5
4~7
Vdc
Vdc
30
mA
88
2,400 ± 400
dBA
Hz
0 pulse /sec
CONTINUOUS
-40 ~ +85
-40 ~ +85
PPS
Sn PLATED BRASS
2
THIS DOCUMENT CONTAINS DATA PROPRIETARY
TO PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
°C
°C
grams
REVISION HISTORY
DESCRIPTION
RELEASED FROM ENGINEERING
REVISED TERMINAL MATERIAL
REMOVED LEAD FREE ADDED RoHS NOTE
ADDED NOTE 4
REVISED TEMPERATURES ADD DATE CODE
REVISED LAYOUT ADDED SIDE DIMENSION
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
LTR
A
B
C
D
E
F
G
DATE
8/2/2004
12/13/2004
8/10/2005
11/02/2005
3/20/2006
6/14/2006
8/16/2006
11/9/2007
APPROVED
R.W.
B.R.
B.R.
R.W.
B.R.
B.R.
A(4:1)
SMI-1324-TW
-5V-2-R D 7G
PUI China
SILK SCREEN MARKING
COLOR: SILVER
DATE CODE
MARKING
"7 G"
YEAR:7=2007 MONTH:G=JULY
12.8 `0.3
0.6
6.5
0.5 `0.1
3 `0.3
2 `0.3
12.8 `0.3
9.8 `0.3
n1.4 (3)
NOTES:
A
3.5
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
4. MAXIMUM REFOLW TEMPERATURE IS 260~C.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
SMI-1324-TW-5V-2-R.idw
Designed by
Date
R.A.C.
8/2/2004
Checked by
Date
Approved by
Date
Drawn Date
R.W.
8/2/2004
11/9/2007
SMI-1324-TW-5V-2-R
Indicator
Edition
Sheet
1/1
SMI-1324-TW-5V-2-R-T/R 价格&库存
很抱歉,暂时无法提供与“SMI-1324-TW-5V-2-R-T/R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+62.550281+8.08351
- 10+49.3063510+6.37197
- 25+44.9645225+5.81086
- 50+41.9735450+5.42433
- 100+41.64213100+5.38150
- 国内价格 香港价格
- 450+36.19117450+4.67706
- 900+34.02133900+4.39665
