74AHCU04
Hex unbuffered inverter
Rev. 5 — 18 May 2020
Product data sheet
1. General description
The 74AHCU04 is high-speed Si-gate CMOS devices and is pin compatible with low power
Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7A.
The 74AHCU04 is a general purpose hex unbuffered inverter. Each of the six inverters is a single
stage.
2. Features and benefits
Low power dissipation
Balanced propagation delays
Inputs accepts voltages higher than VCC
ESD protection:
• HBM JESD22-A114F: exceeds 2000 V
• MM JESD22-A115-A: exceeds 200 V
• CDM JESD22-C101C: exceeds 1000 V
Multiple package options
Specified from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74AHCU04D
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74AHCU04PW
-40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74AHCU04BQ
-40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
SOT762-1
74AHCU04
Nexperia
4. Functional diagram
1
1
1
1A
1Y
2
3
2A
2Y
4
1
3
3A
3Y
6
9
4A
4Y
8
11
5A
5Y
10
13
6A
6Y
12
6
1
9
8
1
11
10
1
13
mna342
Fig. 1.
4
1
5
5
2
12
A
Y
mna343
Logic symbol
Fig. 2.
mna045
IEC logic symbol
Fig. 3.
Logic diagram (one inverter)
5. Pinning information
1
1A
terminal 1
index area
2
13 6A
2A
3
2Y
4
3A
5
10 5Y
3Y
6
9
4A
GND
7
8
4Y
12 6Y
04
11 5A
2Y
4
04
11 5A
3A
5
GND(1)
10 5Y
3Y
6
9
4A
001aac442
Transparent top view
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
001aac441
Fig. 4.
13 6A
12 6Y
8
1Y
3
4Y
14 VCC
2
2A
7
1
1Y
GND
1A
14 VCC
5.1. Pinning
Pin configuration SOT108-1 (SO14) and
SOT402-1 (TSSOP14)
Fig. 5.
Pin configuration SOT762-1 (DHVQFN14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A, 5A, 6A
1, 3, 5, 9, 11, 13
data input
1Y, 2Y, 3Y, 4Y, 5Y, 6Y
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74AHCU04
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 14
74AHCU04
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
nA
nY
L
H
H
L
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
IO
output current
ICC
Conditions
Max
Unit
-0.5
+7.0
V
-20
-0.5
+7.0
V
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
-0.5 V < VO < VCC + 0.5 V
±25
mA
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
Min
Typ
Max
Unit
2.0
5.0
5.5
V
V
[1]
[2]
VI < -0.5 V
Min
[1]
Tamb = -40 °C to +125 °C
[2]
mA
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C.
For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C.
For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74AHCU04
Product data sheet
Conditions
VCC
V
-40
+25
+125
°C
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
3 / 14
74AHCU04
Nexperia
9. Static characteristics
Table 6. Static characteristics
Symbol Parameter
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.7
1.7
1.7
V
VCC = 3.0 V
2.4
2.4
2.4
V
VCC = 5.5 V
4.4
4.4
4.4
V
VCC = 2.0 V
0.3
0.3
0.3
V
VCC = 3.0 V
0.6
0.6
0.6
V
VCC = 5.5 V
1.1
1.1
1.1
V
IO = -50 μA; VCC = 2.0 V
1.8
2.0
1.8
1.8
V
IO = -50 μA; VCC = 3.0 V
2.7
3.0
2.7
2.7
V
IO = -50 μA; VCC = 4.5 V
4.0
4.5
4.0
4.0
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.4
V
IO = -8.0 mA; VCC = 4.5 V
3.94
3.8
3.7
V
IO = 50 μA; VCC = 2.0 V
0.2
0.2
V
IO = 50 μA; VCC = 3.0 V
0.3
0.3
V
IO = 50 μA; VCC = 4.5 V
0.5
0.5
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
μA
CI
input
capacitance
3
10
10
10
pF
74AHCU04
Product data sheet
4 / 14
74AHCU04
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V; For test circuit see Fig. 7.
Symbol Parameter
tpd
propagation
delay
CPD
[1]
[2]
[3]
[4]
power
dissipation
capacitance
Conditions
25 °C
nA to nY; see Fig. 6
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
[1]
VCC = 3.0 V to 3.6 V; CL = 15 pF
[2]
3.0
7.1
1.0
8.5
1.0
9.0
VCC = 3.0 V to 3.6 V; CL = 50 pF
[2]
3.4
10.6
1.0
12.0
1.0
13.5 ns
VCC = 4.5 V to 5.5 V; CL = 15 pF
[3]
2.4
5.5
1.0
6.5
1.0
7.0
ns
VCC = 4.5 V to 5.5 V; CL = 50 pF
[3]
3.5
7.0
1.0
8.0
1.0
9.0
ns
[4]
9.1
pF
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
ns
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
10.1. Waveforms
VCC
PULSE
GENERATOR
VI
VM
nA input
VM
VI
VO
DUT
CL
50 pF
RT
GND
t PHL
t PLH
VOH
VM
nY output
VM
VOL
mna344
VM = 0.5 × VCC; VI = GND to VCC.
Fig. 6.
The input (nA) to output (nY) propagation delay
times
Fig. 7.
74AHCU04
Product data sheet
mna034
Test data is given in Table 7.
Definitions for test circuit:
CL = Load capacitance including jig and probe
capacitance.
RT = Termination resistance should be equal to
output impedance Zo of the pulse generator.
Test circuit for measuring switching times
5 / 14
74AHCU04
Nexperia
11. Typical transfer characteristics
mna353
2
VO
VO
(V)
700
ICC
(µA)
1.5
mna352
4
VO
(V)
6
ICC
(mA)
VO
500
3
1
300
2
2
0.5
100
1
ICC
ICC
1
1.5 V (V)
i
2
- 100
Tamb = 25 °C.
Fig. 8.
2
3
Vi (V)
-2
Tamb = 25 °C.
VCC = 2.0 V; IO = 0 A
Fig. 9.
mna351
8
VO
(V)
VCC = 3.0 V; IO = 0 A
30
ICC
(mA)
6
Rbias = 560 kΩ
VCC
4
10
0.47 µF
ICC
2
input
output
100 µF
VI
(f = 1 kHz)
A IO
GND
VO
Tamb = 25 °C.
Fig. 10. VCC = 5.5 V; IO = 0 A
74AHCU04
Product data sheet
mna050
4
Vi (V)
6
- 10
fi = 1 kHz at VO is constant
Fig. 11. Test set-up for measuring forward
transconductance
6 / 14
74AHCU04
Nexperia
mna355
40
g fs
(mA/V)
30
4
VCC (V)
6
Tamb = 25 °C.
Fig. 12. Typical forward transconductance as a function of the supply voltage
12. Application information
Some applications are:
Linear amplifier (see Fig. 13)
In crystal oscillator design (see Fig. 14)
Remark: All values given are typical unless otherwise specified.
R2
VCC
1 µF
R1
R1
U04
ZL
R2
U04
mna052
out
Maximum Vo(p-p) = VCC - 1.5 V centered at
0.5 × VCC.
Gol = open loop gain
Gv = voltage gain
R1 ≥ 3 kΩ, R2 ≤ 1 MΩ
ZL > 10 kΩ; Gol = 12 (typical)
Typical unity gain bandwidth product is 5 MHz.
Fig. 13. Used as a linear amplifier
74AHCU04
Product data sheet
C1
C2
mna053
C1 = 47 pF (typical)
C2 = 33 pF (typical)
R1 = 1 MΩ to 10 MΩ (typical)
R2 optimum value depends on the frequency
and required stability against changes in VCC or
average minimum ICC (ICC is typically 5 mA at
VCC = 5 V and fi = 10 MHz).
Fig. 14. Crystal oscillator configuration
7 / 14
74AHCU04
Nexperia
Table 8. External components for resonator (f < 1 MHz)
All values given are typical and must be used as an initial set-up.
Frequency
R1
R2
C1
C2
10 kHz to 15.9 kHz
22 MΩ
220 kΩ
56 pF
20 pF
16 kHz to 24.9 kHz
22 MΩ
220 kΩ
56 pF
10 pF
25 kHz to 54.9 kHz
22 MΩ
100 kΩ
56 pF
10 pF
55 kHz to 129.9 kHz
22 MΩ
100 kΩ
47 pF
5 pF
130 kHz to 199.9 kHz
22 MΩ
47 kΩ
47 pF
5 pF
200 kHz to 349.9 kHz
10 MΩ
47 kΩ
47 pF
5 pF
350 kHz to 600 kHz
10 MΩ
47 kΩ
47 pF
5 pF
Table 9. Optimum value for R2
Frequency
R2
3 kHz
6 kHz
10 kHz
14 kHz
>14 kHz
74AHCU04
Product data sheet
Optimum for
2.0 kΩ
minimum required ICC
8.0 kΩ
minimum influence due to change in VCC
1.0 kΩ
4.7 kΩ
minimum influence by VCC
0.5 kΩ
2.0 kΩ
0.5 kΩ
1.0 kΩ
replace R2 by C3 with a typical value of 35 pF
8 / 14
74AHCU04
Nexperia
13. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 15. Package outline SOT108-1 (SO14)
74AHCU04
Product data sheet
9 / 14
74AHCU04
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 16. Package outline SOT402-1 (TSSOP14)
74AHCU04
Product data sheet
10 / 14
74AHCU04
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 x 3 x 0.85 mm
B
D
SOT762-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
v
w
b
2
6
C A B
C
y
y1 C
L
1
7
14
8
Eh
e
k
13
9
Dh
X
k
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
1
A1
b
0.05 0.30
0.02 0.25
0.00 0.18
4 mm
scale
c
D(1)
Dh
E(1)
Eh
e
e1
0.2
3.1
3.0
2.9
1.65
1.50
1.35
2.6
2.5
2.4
1.15
1.00
0.85
0.5
2
k
L
v
0.2
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
SOT762-1
References
IEC
JEDEC
JEITA
sot762-1_po
European
projection
Issue date
15-04-10
15-05-05
MO-241
Fig. 17. Package outline SOT762-1 (DHVQFN14)
74AHCU04
Product data sheet
11 / 14
74AHCU04
Nexperia
14. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charge Device Model
CMOS
Complementary Metal Oxide Semiconductor
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
TTL
15. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74AHCU04 v.5
20200518
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Table 4: Derating values for Ptot total power dissipation updated.
74AHCU04 v.4
20151207
Modifications:
74AHCU04 v.3
20071114
Modifications:
74AHCU04 v.4
Product data sheet
74AHCU04 v.3
Descriptive title updated. Added "unbuffered" (errata).
Product data sheet
74AHCU04 v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Section 3: DHVQFN14 package added.
Section 7: derating values added for DHVQFN14 package.
Section 13: outline drawing added for DHVQFN14 package.
74AHCU04 v.2
19990927
Product specification
74AHCU04 v.1
74AHCU04 v.1
19990226
74AHCU04
Product data sheet
12 / 14
74AHCU04
Nexperia
16. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AHCU04
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
13 / 14
74AHCU04
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 2
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................3
9. Static characteristics....................................................4
10. Dynamic characteristics............................................ 5
10.1. Waveforms.................................................................5
11. Typical transfer characteristics................................. 6
12. Application information............................................. 7
13. Package outline.......................................................... 9
14. Abbreviations............................................................ 12
15. Revision history........................................................12
16. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 18 May 2020
74AHCU04
Product data sheet
14 / 14
