74HC541PW,118
74HC541PW,118
    NEXPERIA(安世)
    TSSOP-20
    八进制缓冲器/线路驱动器;三态 TSSOP20 2~6V
74HC541PW,118 数据手册
74HC541; 74HCT541 Octal buffer/line driver; 3-state Rev. 4 — 3 March 2016 Product data sheet 1. General description The 74HC541; 74HCT541 is an octal non-inverting buffer/line driver with 3-state outputs. The device features two output enables (OE1 and OE2). A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Non-Inverting outputs  Complies with JEDEC standard no. 7A  Input levels:  For 74HC541: CMOS level  For 74HCT541: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC541D Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74HCT541D 74HC541DB 74HCT541DB 74HC541PW 74HCT541PW 74HC541; 74HCT541 Nexperia Octal buffer/line driver; 3-state 4. Functional diagram     $
74HC541PW,118 价格&库存
很抱歉,暂时无法提供与“74HC541PW,118”相匹配的价格&库存,您可以联系我们找货
74HC541PW,118
  • 5+1.79968
  • 50+1.45236
  • 500+1.09542
  • 1000+1.07899
  • 2500+1.01442
74HC541PW,118
  • 5+7.04781
  • 50+3.61883
  • 100+2.83574
  • 500+2.37300
  • 1000+1.91027
74HC541PW,118
  • 1+7.977301+0.99270
  • 10+4.9589010+0.61710
  • 50+3.6174050+0.45020
  • 100+3.18610100+0.39650
  • 1000+2.299801000+0.28620
  • 2500+1.796702500+0.22360
  • 5000+1.653005000+0.20570
库存:506
74HC541PW,118
    • 828+0.91762
    库存:828
