CPE-750P
CPE-750P
    CUIDEVICES
    BUZZER PIEZO 12V 37.8MM PANEL
CPE-750P 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 3 MODEL: CPE-750P | DESCRIPTION: PIEZO BUZZER INDICATOR FEATURES • through-hole pins • threaded body • 12 Vdc rating • 80 dB • 3.6 kHz rated frequency SPECIFICATIONS parameter conditions/description min rated voltage 4 at rated voltage rated frequency 3,100 sound pressure level at 30 cm, rated voltage tone continuous dimensions Ø37.8 x 23.5 3,600 material ABS UL94 1/16” HB (grey) terminal solder pins (tin plating) storage temperature -40 RoHS yes Vdc 7 mA 4,100 Hz dB -30 maximum 3 seconds Vdc mm operating temperature hand soldering units 28 80 weight Notes: max 12 operating voltage current consumption typ 330 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted. cuidevices.com 350 18.5 g 85 °C 95 °C 370 °C Additional Resources: Product Page CUI DEVICES | MODEL: CPE-750P | DESCRIPTION: PIEZO BUZZER INDICATOR | 3D Model date 08/05/2022 | page 2 of 3 MECHANICAL DRAWING units: mm tolerance: ±0.5 mm PERFORMANCE CURVES Voltage vs. Current Consumption Voltage vs. Sound Pressure Level cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CPE-750P | DESCRIPTION: PIEZO BUZZER INDICATOR date 08/05/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 11/12/2007 1.01 brand update 05/11/2020 logo, datasheet style update 08/05/2022 1.02 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CPE-750P 价格&库存
很抱歉,暂时无法提供与“CPE-750P”相匹配的价格&库存,您可以联系我们找货
