74LVCH16245ADGG,51
74LVCH16245ADGG,51
    NEXPERIA(安世)
    TSSOP-48
    IC TXRX NON-INVERT 3.6V 48TSSOP
74LVCH16245ADGG,51 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia 74LVC16245A; 74LVCH16245A 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state Rev. 12 — 13 February 2012 Product data sheet 1. General description The 74LVC16245A; 74LVCH16245A are 16-bit transceivers featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The device features two output enable (nOE) inputs for easy cascading and two send/receive (nDIR) inputs for direction control. nOE controls the outputs so that the buses are effectively isolated. This device can be used as two 8-bit transceivers or one 16-bit transceiver. Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs. These features allow the use of these devices in mixed 3.3 V and 5 V applications. The 74LVCH16245A bus hold on data inputs eliminates the need for external pull-up resistors to hold unused inputs. 2. Features and benefits            5 V tolerant inputs/outputs for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption MULTIBYTE flow-through standard pin-out architecture Low inductance multiple power and ground pins for minimum noise and ground bounce Direct interface with TTL levels High-impedance when VCC = 0 V All data inputs have bus hold (74LVCH16245A only) Complies with JEDEC standard:  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A (2.3 V to 2.7 V)  JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-B exceeds 200 V  CDM JESD22-C101E exceeds 1000 V Specified from 40 C to +85 C and 40 C to +125 C 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 3. Ordering information Table 1. Ordering information Type number 74LVC16245ADL Temperature range Package Name Description Version 40 C to +125 C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 40 C to +125 C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 40 C to +125 C VFBGA56 plastic very thin fine-pitch ball grid array package; SOT702-1 56 balls; body 4.5  7  0.65 mm 40 C to +125 C HXQFN60 plastic compatible thermal enhanced extremely thin quad flat package; no leads; 60 terminals; body 4  6  0.5 mm 74LVCH16245ADL 74LVC16245ADGG 74LVCH16245ADGG 74LVC16245AEV 74LVCH16245AEV 74LVC16245ABX 74LVCH16245ABX SOT1134-2 4. Functional diagram 2DIR 1DIR 2OE 1OE 2A0 1A0 1B0 1A1 2B0 2A1 2B1 1B1 1A2 2A2 1B2 1A3 2B2 2A3 1B3 1A4 2B3 2A4 2B4 1B4 1A5 2A5 1B5 1A6 2B5 2A6 1B6 2B6 2A7 1A7 1B7 2B7 001aaa789 Fig 1. Logic symbol 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 2 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state G3 3EN1[BA] 3EN2[AB] G6 6EN1[BA] 6EN2[AB] 1OE 1DIR 2OE 2DIR 1A0 1B0 1 2 1A1 1B1 1A2 1B2 1A3 1B3 1A4 1B4 1A5 1B5 1A6 1B6 1A7 1B7 2A0 2B0 4 5 2A1 2B1 2A2 2B2 2A3 2B3 2A4 2B4 2A5 2B5 2A6 2B6 2A7 2B7 001aaa790 Fig 2. IEC logic symbol VCC data input to internal circuit mna705 Fig 3. Bus hold circuit 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 3 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 5. Pinning information 5.1 Pinning 74LVC16245A 74LVCH16245A 1DIR 1 48 1OE 1B0 2 47 1A0 1B1 3 46 1A1 GND 4 45 GND 1B2 5 44 1A2 1B3 6 43 1A3 VCC 7 42 VCC 1B4 8 41 1A4 1B5 9 40 1A5 GND 10 39 GND 1B6 11 38 1A6 1B7 12 37 1A7 2B0 13 36 2A0 2B1 14 35 2A1 GND 15 34 GND 2B2 16 33 2A2 2B3 17 32 2A3 VCC 18 31 VCC 2B4 19 30 2A4 2B5 20 29 2A5 GND 21 28 GND 2B6 22 27 2A6 2B7 23 26 2A7 2DIR 24 25 2OE 74LVC16245A ball A1 74LVCH16245A index area 1 2 3 4 5 6 A B C D E F G H J K 001aad111 Transparent top view 001aad110 Fig 4. Pin configuration SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 74LVC_LVCH16245A Product data sheet Fig 5. Pin configuration SOT702-1 (VFBGA56) All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 4 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state terminal 1 index area D1 A32 A1 D5 A31 A30 B20 A29 B19 A28 B18 A27 D4 D8 A26 A2 A25 B1 B17 B2 B16 A3 A24 A4 A23 B15 B3 A5 A22 74LVC16245A 74LVCH16245A B4 A6 B14 A21 B5 B13 B6 B12 A20 A7 A8 A19 B7 B11 GND(1) A9 A10 D6 D2 A11 B8 A12 B9 A13 A18 B10 A14 A15 D7 A17 A16 D3 001aai894 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 6. Pin configuration SOT1134-2 (HXQFN60) 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 5 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 5.2 Pin description Table 2. Symbol Pin description Pin Description SOT370-1 and SOT362-1 SOT702-1 SOT1134-2 1DIR, 2DIR 1, 24 A1, K1 A30, A13 direction control input 1B0 to 1B7 2, 3, 5, 6, 8, 9, 11, 12 B2, B1, C2, C1, D2, D1, E2, E1 B20, A31, D5, D1, A2, B2, B3, A5 data input/output 2B0 to 2B7 13, 14, 16, 17, 19, F1, F2, G1, G2, H1, H2, 20, 22, 23 J1, J2 A6, B5, B6, A9, D2, D6, A12, B8 data input/output GND 4, 10, 15, 21, 28, 34, 39, 45 B3, B4, D3, D4, G3, G4, J3, J4 A32, A3, A8, A11, A16, A19, A24, A27 ground (0 V) VCC 7, 18, 31, 42 C3, C4, H3, H4 A1, A10, A17, A26 supply voltage 1OE, 2OE 48, 25 A6, K6 A29, A14 output enable input (active LOW) 1A0 to 1A7 47, 46, 44, 43, 41, B5, B6, C5, C6, D5, D6, 40, 38, 37 E5, E6 B18, A28, D8, D4, A25, B16, B15, A22 data input/output 2A0 to 2A7 36, 35, 33, 32, 30, F6, F5, G6, G5, H6, H5, 29, 27, 26 J6, J5 A21, B13, B12, A18, D3, data input/output D7, A15, B10 n.c. A4, A7, A20, A23, B1, B4, B7, B9, B11, B14, B17, B19 - A2, A3, A4, A5, K2, K3, K4, K5 not connected 6. Functional description Table 3. Function table[1] Inputs Outputs nOE nDIR nAn nBn L L nAn = nBn inputs L H inputs nBn = nAn H X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 6 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] Max Unit 0.5 +6.5 V 50 - mA 0.5 +6.5 V - 50 mA output HIGH or LOW [2] 0.5 VCC + 0.5 V output 3-state [2] 0.5 +6.5 V - 50 mA VO > VCC or VO < 0 V output voltage VO Min IO output current VO = 0 V to VCC ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation Tamb = 40 C to +125 C; (T)SSOP48 package [3] - 500 mW VFBGA56 package [4] - 1000 mW HXQFN60 package [4] - 1000 mW [1] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] Above 60 C the value of Ptot derates linearly with 5.5 mW/K. [4] Above 70 C the value of Ptot derates linearly with 1.8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Min Typ Max Unit 1.65 - 3.6 V 1.2 - 3.6 V 0 - 5.5 V output HIGH or LOW 0 - VCC V output 3-state 0 - 5.5 V functional Tamb ambient temperature in free air 40 - +125 C t/V input transition rise and fall rate VCC = 1.2 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 7 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 40 C to +85 C Conditions VCC = 1.2 V Min Max Min Unit Max 1.08 - - 1.08 - V 0.65  VCC - - 0.65  VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V 0.12 V VCC = 1.65 V to 1.95 V VCC = 1.2 V - - 0.12 - VCC = 1.65 V to 1.95 V - - 0.35  VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC  0.2 - - VCC  0.3 - V 1.2 - - 1.05 - V 0.35  VCC V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 3.6 V IO = 4 mA; VCC = 1.65 V VOL 40 C to +125 C Typ[1] IO = 8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = 18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = 24 mA; VCC = 3.0 V 2.2 - - 2.0 - V - - 0.2 - 0.3 V - - 0.45 - 0.65 V LOW-level output VI = VIH or VIL voltage IO = 100 A; VCC = 1.65 V to 3.6 V IO = 4 mA; VCC = 1.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V - 0.1 5 - 20 A II input leakage current[2] IOZ OFF-state output VI = VIH or VIL; current[2][3] VO = 5.5 V or GND; VCC = 3.6 V - 0.1 5 - 20 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0.0 V - 0.1 10 - 20 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 3.6 V - 0.1 20 - 80 A ICC additional supply per input pin; VI = VCC  0.6 V; current IO = 0 A; VCC = 2.7 V to 3.6 V - 5 500 - 5000 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 5.0 - - - pF CI/O input/output capacitance - 10 - - - pF 74LVC_LVCH16245A Product data sheet VI = 5.5 V or GND; VCC = 3.6 V VCC = 0 V to 3.6 V; VI = GND to VCC All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 8 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter IBHL bus hold LOW current [4][5] bus hold HIGH current [4][5] IBHH IBHLO 40 C to +85 C Conditions Max Min Max VCC = 1.65; VI = 0.58 V 10 - - 10 - A VCC = 2.3; VI = 0.7 V 30 - - 25 - A VCC = 3.0; VI = 0.8 V 75 - - 60 - A VCC = 1.65; VI = 1.07 V 10 - - 10 - A VCC = 2.3; VI = 1.7 V 30 - - 25 - A VCC = 3.0; VI = 2.0 V 75 - - 60 - A 200 - - 200 - A 300 - - 300 - A 500 - - 500 - A 200 - - 200 - A 300 - - 300 - A 500 - - 500 - A bus hold LOW VCC = 1.95 V overdrive current V = 2.7 V CC [4][6] bus hold HIGH VCC = 1.95 V overdrive current V = 2.7 V CC [4][6] VCC = 3.6 V [1] Unit Min VCC = 3.6 V IBHHO 40 C to +125 C Typ[1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. [2] The bus hold circuit is switched off when VI > VCC allowing 5.5 V on the input terminal. [3] For I/O ports the parameter IOZ includes the input leakage current. [4] Valid for data inputs of bus hold parts only (74LVCH16245A). Note that control inputs do not have a bus hold circuit. [5] The specified sustaining current at the data input holds the input below the specified VI level. [6] The specified overdrive current at the data input forces the data input to the opposite input state. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9. Symbol Parameter tpd propagation delay 40 C to +85 C Conditions nAn to nBn; nBn to nAn; see Figure 7 enable time VCC = 1.2 V Max - 13.0 - - - ns 1.5 5.2 12.2 1.5 13.8 ns VCC = 2.3 V to 2.7 V 1.0 2.8 6.0 1.0 6.7 ns VCC = 2.7 V 1.0 2.7 4.7 1.0 6.0 ns 1.0 2.4 4.5 1.0 6.0 ns - 15.0 - - - ns 1.5 5.9 15.0 1.5 16.9 ns nOE to nAn, nBn; see Figure 8 VCC = 1.65 V to 1.95 V Product data sheet Min VCC = 1.65 V to 1.95 V VCC = 1.2 V 74LVC_LVCH16245A Max 40 C to +125 C Unit [1] VCC = 3.0 V to 3.6 V ten Min Typ[2] [1] VCC = 2.3 V to 2.7 V 1.0 3.3 7.9 1.0 8.8 ns VCC = 2.7 V 1.5 3.5 6.7 1.5 8.5 ns VCC = 3.0 V to 3.6 V 1.0 2.7 5.5 1.0 7.0 ns All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 9 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9. Symbol Parameter tdis disable time 40 C to +85 C Conditions nOE to nAn, nBn; see Figure 8 [1] Min Max - 11.0 - - - ns VCC = 1.65 V to 1.95 V 1.0 4.9 13.1 1.0 14.7 ns VCC = 2.3 V to 2.7 V 0.5 2.7 7.1 0.5 7.9 ns VCC = 2.7 V 1.5 3.4 6.6 1.5 8.5 ns 1.5 3.3 5.6 1.5 7.0 ns VCC = 1.65 V to 1.95 V - 11.5 - - - pF VCC = 2.3 V to 2.7 V - 15.2 - - - pF VCC = 3.0 V to 3.6 V - 18.5 - - - pF VCC = 3.0 V to 3.6 V power dissipation capacitance Max 40 C to +125 C Unit [1] VCC = 1.2 V CPD Min Typ[2] [3] per input; VI = GND to VCC tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [2] [3] Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively. CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 11. Waveforms VI nAn, nBn input VM GND t PHL t PLH VOH nBn, nAn output VM VOL mna477 Measurement points are given in Table 8. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. The input (nAn, nBn) to output (nBn, nAn) propagation delays 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 10 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs enabled outputs disabled mna362 Measurement points are given in Table 8. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. 3-state enable and disable times Table 8. Measurement points Supply voltage VM VCC Input VI tr = tf VX VY 1.2 V 0.5  VCC VCC  2.5 ns VOL + 0.15 V VOH  0.15 V 1.65 V to 1.95 V 0.5  VCC VCC  2.5 ns VOL + 0.15 V VOH  0.15 V 2.3 V to 2.7 V 0.5  VCC VCC  2.5 ns VOL + 0.15 V VOH  0.15 V 2.7 V 1.5 V 2.7 V  2.5 ns VOL + 0.3 V VOH  0.3 V 3.0 V to 3.6 V 1.5 V 2.7 V  2.5 ns VOL + 0.3 V VOH  0.3 V 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 11 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC VI RL VO G DUT RT RL CL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC  2 ns 30 pF 1 k open 2  VCC GND 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k open 2  VCC GND 2.3 V to 2.7 V VCC  2 ns 30 pF 500  open 2  VCC GND 2.7 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 12 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 12. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA MO-118 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 10. Package outline SOT370-1 (SSOP48) 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 13 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 E D A X c HE y v M A Z 48 25 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 detail X 24 w M bp e 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 12.6 12.4 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.8 0.4 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT362-1 REFERENCES IEC JEDEC JEITA MO-153 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 11. Package outline SOT362-1 (TSSOP48) 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 14 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state VFBGA56: plastic very thin fine-pitch ball grid array package; 56 balls; body 4.5 x 7 x 0.65 mm B D SOT702-1 A ball A1 index area A E A2 A1 detail X e1 1/2 C ∅v M C A B ∅w M C b e y1 C e y K J H e G F e2 E D 1/2 e C X B A ball A1 index area 1 2 3 4 5 6 DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 b D E e e1 e2 v w y y1 mm 1 0.3 0.2 0.7 0.6 0.45 0.35 4.6 4.4 7.1 6.9 0.65 3.25 5.85 0.15 0.08 0.08 0.1 OUTLINE VERSION SOT702-1 REFERENCES IEC JEDEC JEITA 0 2.5 5 mm scale EUROPEAN PROJECTION ISSUE DATE 02-08-08 03-07-01 MO-225 Fig 12. Package outline SOT702-1 (VFBGA56) 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 15 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state HXQFN60: plastic compatible thermal enhanced extremely thin quad flat package; no leads; 60 terminals; body 4 x 6 x 0.5 mm A B D SOT1134-2 terminal 1 index area A A2 E A1 detail X e2 b e1 L1 L A11 B10 A17 A10 eR eT y y1 C D3 D7 A16 B8 C eT 1/2 e D2 D6 C A B C eR e C A B C v w v w e B11 B7 Eh e3 e4 1/2 e B17 B1 A1 terminal 1 index area A26 D5 D1 A32 B20 B18 A27 Dh D8 D4 eT eR X K eT eR 0 5 mm Dimensions Unit mm A A1 A2 b max 0.50 0.08 0.42 0.28 nom 0.05 0.40 0.23 min 0.02 0.38 0.18 D Dh E Eh e e1 e2 e3 e4 eR 4.1 4.0 3.9 1.95 1.85 1.75 6.1 6.0 5.9 3.95 3.85 3.75 0.5 1.0 2.5 3.0 4.5 0.5 eT K L L1 v w 0.25 0.28 0.195 0.49 0.20 0.23 0.145 0.1 0.15 0.18 0.095 y 0.05 0.08 y1 0.1 sot1134-2_po References Outline version IEC JEDEC JEITA SOT1134-2 --- --- --- European projection Issue date 11-08-15 Fig 13. Package outline SOT1134-2 (HXQFN60) 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 16 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC_LVCH16245A v.12 20120213 Product data sheet - 74LVC_LVCH16245A v.11 • Modifications: 74LVC_LVCH16245A v.11 20111208 • Modifications: 74LVC_LVCH16245A v.10 For type number 74LVC16245ABX and 74LVCH16245ABX the sot code has changed to SOT1134-2. - 74LVC_LVCH16245A v.10 Table 4, Table 5, Table 6, Table 7, and Table 9: values added for lower voltage ranges. 20110623 Modifications: Product data sheet Product data sheet - 74LVC_LVCH16245A v.9 • type numbers 74LVC16245ABQ and 74LVCH16245ABQ changed to 74LVC16245ABX and 74LVCH16245ABX. • Figure 6: figure note 1 changed. 74LVC_LVCH16245A v.9 20100329 Product data sheet - 74LVC_LVCH16245A v.8 74LVC_LVCH16245A v.8 20081106 Product data sheet - 74LVC_LVCH16245A v.7 74LVC_LVCH16245A v.7 20031125 Product specification - 74LVC_LVCH16245A v.6 74LVC_LVCH16245A v.6 20030130 Product specification - 74LVC_LVCH16245A v.5 74LVC_LVCH16245A v.5 20021030 Product specification - 74LVC_H16245A v.4 74LVC_H16245A v.4 19970925 Product specification - 74LVC16245A_ 74LVCH16245A v.3 74LVC16245A_ 74LVCH16245A v.3 19970925 Product specification - 74LVC16245A v.2 74LVC16245A v.2 19970801 Product specification - 74LVC16245A v.1 74LVC16245A v.1 - - - - 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 17 of 20 74LVC16245A; 74LVCH16245A NXP Semiconductors 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVC_LVCH16245A Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 18 of 20 NXP Semiconductors 74LVC16245A; 74LVCH16245A 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74LVC_LVCH16245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 13 February 2012 © NXP B.V. 2012. All rights reserved. 19 of 20 NXP Semiconductors 74LVC16245A; 74LVCH16245A 16-bit bus transceiver with direction pin; 5 V tolerant; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 6 Functional description . . . . . . . . . . . . . . . . . . . 6 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 7 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 8 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2012. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 13 February 2012 Document identifier: 74LVC_LVCH16245A
74LVCH16245ADGG,51 价格&库存
很抱歉,暂时无法提供与“74LVCH16245ADGG,51”相匹配的价格&库存,您可以联系我们找货
