B5015E12B-BSR
B5015E12B-BSR
    MECHATRONICSFANGROUP(机电一体化)
    BLOWER50X15MM12VDC
B5015E12B-BSR 数据手册
2.10 ±0.02 (51 ±0.5) 1.00 ±0.01 (25.5 ±0.3) 2x R0.136 (3.45) 1.00 ±0.01 (25.4 ±0.03) 0.71±0.01 (18 ±0.3) 0.93 ±0.01 (23.5 ±0.3) 24 2x R0.09 ±0.01 (2.25 ±0.3) 0.62 ±0.01 (15.7 ±0.3) 0.79 ±0.01 (20 ±0.3) 2.01±0.02 (51 ±0.5) 4x R0.79 (2) 0.91 ±0.01 (23 ±0.3) 0.30 (7.5) 1.08 ±0.01 (27.5 ±0.3) 0.69 (17.6) 0.79 ±0.01 (20 ±0.3) STATIC PRESSURE - MM OF WATER DC BLOWERS B5015 series E 20 H M 16 12 8 4 0.02 0 0.47±0.01 (12 ±0.3) 0.04 0.06 0.08 0.10 0.12 0.14 AIR FLOW (M3/MIN) (51 x 51 x 15 mm) 2.01 x 2.01 x .62 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing Connection: Protection: Options: Speed Max. Static Pressure (H2 0) Rated Voltage V 5 12 24 RPM M³/Min. CFM MM Current mA Air Volume Weight INCH Sound Noise db g AWG 26, UL1061 lead wires B5015M 5/12/24 280 130 90 4,500 0.09 3 8.98 0.35 35 25 thermal B5015H 5/12/24 400 200 130 5,500 0.11 4 14.28 0.56 40 25 B5015E 12/24 – 300 180 6,500 0.13 5 22.45 0.88 45 25 tachometer output signal w w w.mechatronic s.com 12.11.14 Model No. E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
B5015E12B-BSR 价格&库存
很抱歉,暂时无法提供与“B5015E12B-BSR”相匹配的价格&库存,您可以联系我们找货
B5015E12B-BSR
  • 1+122.037351+14.68432
