74HC366PW,112
74HC366PW,112
    NEXPERIA(安世)
    TSSOP-16
    IC BUFFER INVERT 6V 16TSSOP
74HC366PW,112 数据手册
74HC366; 74HCT366 Hex buffer/line driver; 3-state; inverting Rev. 6 — 17 February 2021 Product data sheet 1. General description The 74HC366; 74HCT366 is a hex inverting buffer/line driver with 3-state outputs controlled by the output enable inputs (OEn). A HIGH on OEn causes the outputs to assume a high impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 2.0 V to 6.0 V CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Inverting outputs Input levels: • For 74HC366: CMOS level • For 74HCT366: TTL level ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package 74HC366D Temperature range Name Description -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 Version -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm 74HCT366D 74HC366PW 74HCT366PW SOT403-1 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 4. Functional diagram 2 4 6 10 12 14 1A 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 6Y 3 5 7 9 11 13 1A 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 1 15 6Y OE1 OE2 OE1 OE2 001aaf583 Fig. 1. 1 15 Functional diagram Fig. 2. & EN 2 3 4 5 6 7 10 9 12 11 14 13 001aaf581 Logic symbol 001aaf582 Fig. 3. buffer/line driver 1 IEC logic symbol VCC 1A 1Y OE1 OE2 GND 2A 3A 4A 5A 6A buffer/line driver 2 2Y buffer/line driver 3 3Y buffer/line driver 4 4Y buffer/line driver 5 5Y buffer/line driver 6 6Y 001aaf584 Fig. 4. Logic diagram 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 2 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 5. Pinning information 5.1. Pinning 74HC366 74HCT366 OE1 1 16 VCC 1A 2 15 OE2 1Y 3 14 6A 2A 4 13 6Y 2Y 5 12 5A 3A 6 11 5Y 3Y 7 10 4A GND 8 9 4Y 001aaf580 Fig. 5. Pin configuration for SOT109-1 (SO16) and SOT403-1 (TSSOP16) 5.2. Pin description Table 2. Pin description Symbol Pin Description OE1, OE2 1, 15 output enable input (active LOW) 1A, 2A, 3A, 4A, 5A, 6A 2, 4, 6, 10, 12, 14 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 3, 5, 7, 9, 11, 13 data output GND 8 ground (0 V) VCC 16 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input Output OE1 OE2 nA nY L L L H L L H L X H X Z H X X Z 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 3 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current VO = -0.5 V to (VCC + 0.5 V) - ±35 mA ICC supply current - 70 mA IGND ground current - -70 mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [1] For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74HC_HCT366 Product data sheet Conditions 74HC366 74HCT366 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V 0 - VCC 0 - VCC V 0 - VCC 0 - VCC V -40 +25 +125 -40 +25 +125 °C VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 4 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 9. Static characteristics Table 6. Static characteristics 74HC366 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 Tamb = 25 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL V - - - IO = -20 μA; VCC = 2.0 V 1.9 2.0 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - V IO = -6.0 mA; VCC = 4.5 V 3.98 4.32 - V IO = -7.8 mA; VCC = 6.0 V 5.48 5.81 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 V LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±0.5 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 μA CI input capacitance - 3.5 - pF 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 5 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 - - V IO = -20 μA; VCC = 4.5 V 4.4 - - V IO = -20 μA; VCC = 6.0 V 5.9 - - V IO = -6.0 mA; VCC = 4.5 V 3.84 - - V IO = -7.8 mA; VCC = 6.0 V 5.34 - - V IO = 20 μA; VCC = 2.0 V - - 0.1 V IO = 20 μA; VCC = 4.5 V - - 0.1 V IO = 20 μA; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.33 V IO = 7.8 mA; VCC = 6.0 V - - 0.33 V Tamb = -40 °C to +85 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V; - - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±5.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 80 μA VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 - - V IO = -20 μA; VCC = 4.5 V 4.4 - - V IO = -20 μA; VCC = 6.0 V 5.9 - - V IO = -6.0 mA; VCC = 4.5 V 3.7 - - V IO = -7.8 mA; VCC = 6.0 V 5.2 - - V IO = 20 μA; VCC = 2.0 V - - 0.1 V IO = 20 μA; VCC = 4.5 V - - 0.1 V IO = 20 μA; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.4 V IO = 7.8 mA; VCC = 6.0 V - - 0.4 V Tamb = -40 °C to +125 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±10.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © 160 μA Nexperia B.V. 2021. All rights reserved 6 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting Table 7. Static characteristics 74HCT366 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - V IO = -6.0 mA 3.98 4.32 - V IO = 20 μA - 0 0.1 V IO = 6.0 mA - 0.16 0.26 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - ±0.5 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 μA ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A pins nA - 100 360 μA pin OE1 - 100 360 μA pin OE2 - 90 320 μA - 3.5 - pF CI input capacitance Tamb = -40 °C to +85 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 - - V IO = -6.0 mA 3.84 - - V IO = 20 μA - - 0.1 V IO = 6.0 mA - - 0.33 V - - ±1.0 μA VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A 74HC_HCT366 Product data sheet ±5.0 μA - - 80 μA pins nA - - 450 μA pin OE1 - - 450 μA pin OE2 - - 400 μA All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 7 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting Symbol Parameter Conditions Min Typ Max Unit Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 - - V IO = -6.0 mA 3.7 - - V IO = 20 μA - - 0.1 V IO = 6.0 mA - - 0.4 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - ±10.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 160 μA ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A pins nA - - 490 μA pin OE1 - - 490 μA pin OE2 - - 441 μA 10. Dynamic characteristics Table 8. Dynamic characteristics 74HC366 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Fig. 8. Symbol Parameter Min Typ VCC = 2.0 V - 33 100 ns VCC = 4.5 V - 12 20 ns VCC = 5 V; CL = 15 pF - 10 - ns VCC = 6.0 V - 10 17 ns VCC = 2.0 V - 44 150 ns VCC = 4.5 V - 16 30 ns VCC = 6.0 V - 13 26 ns VCC = 2.0 V - 55 150 ns VCC = 4.5 V - 20 30 ns - 16 26 ns VCC = 2.0 V - 14 60 ns VCC = 4.5 V - 5 12 ns VCC = 6.0 V - 4 10 ns - 30 - pF Conditions Max Unit Tamb = 25 °C tpd ten tdis propagation delay enable time disable time nA to nY; see Fig. 6 OEn to nY; see Fig. 7 OEn to nY; see Fig. 7 [1] [2] [3] VCC = 6.0 V tt CPD transition time power dissipation capacitance 74HC_HCT366 Product data sheet see Fig. 6 [4] per buffer; VI = GND to VCC All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 [5] © Nexperia B.V. 2021. All rights reserved 8 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting Symbol Parameter Min Typ VCC = 2.0 V - - 125 ns VCC = 4.5 V - - 25 ns VCC = 6.0 V - - 21 ns VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns VCC = 6.0 V - - 33 ns VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns - - 33 ns VCC = 2.0 V - - 75 ns VCC = 4.5 V - - 15 ns VCC = 6.0 V - - 13 ns VCC = 2.0 V - - 150 ns VCC = 4.5 V - - 30 ns VCC = 6.0 V - - 26 ns VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns VCC = 6.0 V - - 38 ns VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns VCC = 6.0 V - - 38 ns VCC = 2.0 V - - 90 ns VCC = 4.5 V - - 18 ns VCC = 6.0 V - - 15 ns Conditions Max Unit Tamb = -40 °C to +85 °C tpd propagation delay ten enable time tdis disable time nA to nY; see Fig. 6 OEn to nY; see Fig. 7 OEn to nY; see Fig. 7 [1] [2] [3] VCC = 6.0 V tt transition time see Fig. 6 [4] Tamb = -40 °C to +125 °C tpd propagation delay ten enable time tdis disable time tt [1] [2] [3] [4] [5] transition time nA to nY; see Fig. 6 OEn to nY; see Fig. 7 OEn to nY; see Fig. 7 see Fig. 6 [1] [2] [3] [4] tpd is the same as tPHL and tPLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 9 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting Table 9. Dynamic characteristics 74HCT366 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Fig. 8. Symbol Parameter Min Typ VCC = 4.5 V - 13 24 ns VCC = 5 V; CL = 15 pF - 11 - ns Conditions Max Unit Tamb = 25 °C tpd propagation delay nA to nY; see Fig. 6 [1] ten enable time OEn to nY; VCC = 4.5 V; see Fig. 7 [2] - 16 35 ns tdis disable time OEn to nY; VCC = 4.5 V; see Fig. 7 [3] - 20 35 ns tt transition time VCC = 4.5 V; see Fig. 6 [4] - 5 12 ns CPD power dissipation capacitance per buffer; VI = GND to (VCC - 1.5 V) [5] - 30 - pF Tamb = -40 °C to +85 °C tpd propagation delay nA to nY; VCC = 4.5 V; see Fig. 6 [1] - - 30 ns ten enable time OEn to nY; VCC = 4.5 V; see Fig. 7 [2] - - 44 ns tdis disable time OEn to nY; VCC = 4.5 V; see Fig. 7 [3] - - 44 ns tt transition time VCC = 4.5 V; see Fig. 6 [4] - - 15 ns Tamb = -40 °C to +125 °C tpd propagation delay nA to nY; VCC = 4.5 V; see Fig. 6 [1] - - 36 ns ten enable time OEn to nY; VCC = 4.5 V; see Fig. 7 [2] - - 53 ns tdis disable time OEn to nY; VCC = 4.5 V; see Fig. 7 [3] - - 53 ns tt transition time VCC = 4.5 V; see Fig. 6 [4] - - 18 ns [1] [2] [3] [4] [5] tpd is the same as tPHL and tPLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 10 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 10.1. Waveforms and test circuit VI nA input VM VM GND t PHL t PLH VOH nY output VM VOL t THL VM t TLH 001aaf585 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Propagation delay data input (nA) to output (nY) and output transition time VI VM OEn input VM GND tPLZ nY output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPHZ nY output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled 001aaf586 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. 3-state enable and disable times Table 10. Measurement points Input Type Output VM VM VX VY 74HC366 0.5VCC 0.5VCC 0.1 x VCC 0.9 x VCC 74HCT366 1.3 V 1.3 V 0.1 x VCC 0.9 x VCC 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 11 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance S1 = Test selection switch Fig. 8. Test circuit for measuring switching times Table 11. Test data Type Input Load VI tr, tf CL 74HC366 VCC 6 ns 74HCT366 3V 6 ns 74HC_HCT366 Product data sheet S1 position RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 15 pF, 50 pF 1 kΩ open GND VCC 15 pF, 50 pF 1 kΩ open GND VCC All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 12 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 11. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 13 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 10. Package outline SOT403-1 (TSSOP16) 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 14 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 12. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 13. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT366 v.6 20210217 Product data sheet - 74HC_HCT366 v.5 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 2 updated. Section 7: Derating values for Ptot total power dissipation updated. Type number 74HCT366DB (SOT338-1 / SSOP16) removed. 74HC_HCT366 v.5 20160202 Modifications: • 74HC_HCT366 v.4 20120904 Modifications: • 74HC_HCT366 v.3 20061121 74HC_HCT366_CNV v.2 19901201 74HC_HCT366 Product data sheet Product data sheet - 74HC_HCT366 v.4 Type numbers 74HC366N and 74HCT366N (SOT38-4) removed. Product data sheet - 74HC_HCT366 v.3 Product data sheet - 74HC_HCT366_CNV v.2 Product specification - - Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 15 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT366 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 16 / 17 74HC366; 74HCT366 Nexperia Hex buffer/line driver; 3-state; inverting Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 8 10.1. Waveforms and test circuit...................................... 11 11. Package outline........................................................ 13 12. Abbreviations............................................................ 15 13. Revision history........................................................15 14. Legal information......................................................16 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 February 2021 74HC_HCT366 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 February 2021 © Nexperia B.V. 2021. All rights reserved 17 / 17
74HC366PW,112 价格&库存
很抱歉,暂时无法提供与“74HC366PW,112”相匹配的价格&库存,您可以联系我们找货
