MM2072H48B-FSR
MM2072H48B-FSR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL208X72MM48VDC
MM2072H48B-FSR 数据手册
2.83±0.02 (72.0±0.5) 0.27±0.01 (7.0±0.3) magnesium alloy impeller & frame Bearing option: ball bearing Connection: terminal or AWG 18 lead wire Frame: flanged 1.0 H 0.8 0.6 0.4 0.2 150 300 450 600 750 900 AIR FLOW (CFM) ø8xM5 8.19 x 8.19 x 2.83 inches Construction: 1.2 0 6.85±0.02 (174.0±0.5) 8.19±0.02 (208.0±0.5) (208 x 208x 72 mm) 1.4 STATIC PRESSURE - IN. OF WATER DC AXIAL FANS MM2072 series* 0.28 (7) Terminal 0.12 (3) 0.02 (0.5) Protection: thermal Model No. Options: tachometer output or locked rotor alarm signal MM2072H Rated Voltage Current mA Speed Air Volume Max. Static Pressure (H2 0) Sound Noise Weight V 24 48 RPM M³/Min. CFM MM INCH dbA kg 24/48 5000 2800 3,600 23 825 30.48 1.2 65 1.55 *Not to be used for new designs w w w.mechatronic s.com 10.03.17 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
MM2072H48B-FSR 价格&库存
很抱歉,暂时无法提供与“MM2072H48B-FSR”相匹配的价格&库存,您可以联系我们找货
