MM28080H48B-FSR
MM28080H48B-FSR
    MECHATRONICSFANGROUP(机电一体化)
    FAN AXIAL 280X80MM 48VDC
MM28080H48B-FSR 数据手册
11.02 ±0.02 (280.0±0.50) 3.15 ±0.02 (80.0 ±0.50) 1.4 STATIC PRESSURE - IN. OF WATER 90° 0.11 ±0.02 2.5±0.50 0.63 ±0.02 (16-ø5.0) AIR 4.86 ±0.02 (123.5±0.50) DC AXIAL FANS MM28080H series* ROTATATION 11.02 dia. x 3.15 inches Construction: Bearing option: ball bearing Rated Voltage Model No. MM28080H Connection: terminal Frame: flanged Protection: thermal Options: tachometer output or locked rotor alarm signal 0.8 H 0.6 0.4 0.2 200 400 600 800 1000 1200 AIR FLOW (CFM) 12.60 (ø320.0) 11.61 (ø295.0) 11.48 (ø291.7) magnesium alloy impeller & frame 1.0 0 8-M5 (280 dia. x 80 mm) 1.2 Current mA Speed Air Volume Max. Static Pressure (H2 0) Sound Noise Weight V 24 48 RPM M³/Min. CFM MM INCH dbA kg 24/48 5200 2600 3,000 32 1130 25.40 1.0 65 1.60 1.4 w w w.mechatronic s.com 10.03.17 E - mail: S ales @ M echatronic s.com . OF WATER *Not to be used for new designs 1.2 Fa x : 425 -2 2 2- 515 5 1.0 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
MM28080H48B-FSR 价格&库存
很抱歉,暂时无法提供与“MM28080H48B-FSR”相匹配的价格&库存,您可以联系我们找货
