74LVC32245AEC,557
74LVC32245AEC,557
    NEXPERIA(安世)
    BGA96_13.5X5.5MM
    IC TXRX NON-INVERT 3.6V 96LFBGA
74LVC32245AEC,557 数据手册
74LVC32245A 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state Rev. 3 — 16 December 2011 Product data sheet 1. General description The 74LVC32245A is a 32-bit transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The device features four output enable (nOE) inputs for easy cascading and four send/receive (nDIR) inputs for direction control. Pin nOE controls the outputs so that the buses are effectively isolated. Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs. These features allow the use of these devices in mixed 3.3 V and 5 V applications. To ensure the high-impedance state during power-up or power-down, pin nOE should be tied to VCC through a pull-up resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. 2. Features and benefits             5 V tolerant inputs/outputs for interfacing with 5 V logic Wide supply voltage range from 2.3 V to 3.6 V CMOS low power consumption MULTIBYTE flow-through standard pin-out architecture Low inductance multiple power and ground pins for minimum noise and ground bounce Direct interface with TTL levels Inputs accept voltages up to 5.5 V High-impedance when VCC = 0 V Complies with JEDEC standard:  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A (2.3 V to 2.7 V)  JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115B exceeds 200 V  CDM JESD22-C101E exceeds 1000 V Specified from 40 C to +85 C and 40 C to +125 C Packaged in plastic fine-pitch ball grid array package 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name 74LVC32245AEC 74LVC32245A Product data sheet 40 C to +125 C Description Version LFBGA96 plastic low profile fine-pitch ball grid array package; 96 balls; body 13.5  5.5  1.05 mm All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © SOT536-1 Nexperia B.V. 2017. All rights reserved 2 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 4. Functional diagram A3 1DIR H3 1OE A5 A6 E5 4B5 T6 4B6 T5 3B7 R1 4A6 M2 3A7 R2 4A5 L1 3A6 3B6 M6 4B4 R6 P1 4A4 L2 3A5 3B5 M5 4B3 R5 P2 4A3 K1 3A4 3B4 L6 4B2 P6 N1 4A2 K2 3A3 3B3 L5 4B1 P5 N2 4A1 J1 3A2 3B2 K6 4B0 N6 T4 4A0 J2 3A1 3B1 K5 4OE N5 H2 4DIR J4 3A0 3B0 J6 2B7 T3 H1 2A7 D1 3DIR 3OE J5 2B6 H5 G1 2A6 D2 1A7 1B7 J3 2B5 H6 G2 2A5 C1 1A6 1B6 D6 2B4 G6 F1 2A4 C2 1A5 1B5 D5 2B3 G5 F2 2A3 B1 1A4 1B4 C6 2B2 F6 E1 2A2 B2 1A3 1B3 C5 2B1 F5 E2 2A1 A1 1A2 1B2 B6 2B0 E6 H4 2A0 A2 1A1 1B1 B5 2OE A4 1A0 1B0 2DIR T1 4A7 M1 4B7 T2 mna476 Fig 1. Logic symbol 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 3 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 5. Pinning information 5.1 Pinning mna475 Fig 2. 6 1A1 1A3 1A5 1A7 2A1 2A3 2A5 2A6 3A1 3A3 3A5 3A7 4A1 4A3 4A5 4A6 5 1A0 1A2 1A4 1A6 2A0 2A2 2A4 2A7 3A0 3A2 3A4 3A6 4A0 4A2 4A4 4A7 4 1OE GND VCC GND GND VCC GND 2OE 3OE GND VCC GND GND VCC GND 4OE 3 1DIR GND VCC GND GND VCC GND 2DIR 3DIR GND VCC GND GND VCC GND 4DIR 2 1B0 1B2 1B4 1B6 2B0 2B2 2B4 2B7 3B0 3B2 3B4 3B6 4B0 4B2 4B4 4B7 1 1B1 1B3 1B5 1B7 2B1 2B3 2B5 2B6 3B1 3B3 3B5 3B7 4B1 4B3 4B5 4B6 A B C D E F G H J K L M N P R T Pin configuration 5.2 Pin description Table 2. Pin description Symbol Ball Description nDIR (n = 1 to 4) A3, H3, J3, T3 direction control nOE (n = 1 to 4) A4, H4, J4, T4 output enable input (active LOW) 1A[0:7] A5, A6, B5, B6, C5, C6, D5, D6 input or output 1B[0:7] A2, A1, B2, B1, C2, C1, D2, D1 input or output 2A[0:7] E5, E6, F5, F6, G5, G6, H6, H5 input or output 2B[0:7] E2, E1, F2, F1, G2, G1, H1, H2 input or output 3A[0:7] J5, J6, K5, K6, L5, L6, M5, M6 input or output 3B[0:7] J2, J1, K2, K1, L2, L1, M2, M1 input or output 4A[0:7] N5, N6, P5, P6, R5, R6, T6, T5 input or output 4B[0:7] N2, N1, P2, P1, R2, R1, T1, T2 input or output GND B3, B4, D3, D4, E3, E4, G3, G4, K3, K4, ground (0 V) M3, M4, N3, N4, R3, R4 VCC C3, C4, F3, F4, L3, L4, P3, P4 supply voltage 6. Functional description Table 3. Function selection[1] Input Output nOE nDIR L L H [1] nAn nBn L nAn = nBn inputs H inputs nBn = nAn X Z Z H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 4 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] Max Unit 0.5 +6.5 V 50 - mA 0.5 +6.5 V - 50 mA output HIGH or LOW state [2] 0.5 VCC + 0.5 V output 3-state [2] 0.5 +6.5 V - 50 mA VO > VCC or VO < 0 V output voltage VO Min IO output current ICC supply current [3] - 200 mA IGND ground current [3] 200 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 1000 mW [1] VO = 0 V to VCC Tamb = 40 C to +125 C [4] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] All supply and ground pins connected externally to one voltage source. [4] Above 70 C the value of Ptot derates linearly with 1.8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions functional Min Typ Max Unit 1.65 - 3.6 V 1.2 - - V 0 - 5.5 V VI input voltage VO output voltage output HIGH or LOW state 0 - VCC V output 3-state 0 - 5.5 V Tamb ambient temperature in free air 40 - +125 C t/V input transition rise and fall rate VCC = 2.3 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 3.6 V - - 10 ns/V 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 5 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter HIGH-level input voltage VIH 40 C to +85 C Conditions VCC = 1.2 V VOH HIGH-level output voltage LOW-level output voltage Max Min Max 1.08 - - 1.08 - V - - 0.65  VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V 0.12 V - - 0.12 - - - 0.35  VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC  0.2 - - VCC  0.3 - V 1.2 - - 1.05 - V 0.35  VCC V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 3.6 V IO = 4 mA; VCC = 1.65 V VOL Min Unit 0.65  VCC VCC = 1.65 V to 1.95 V LOW-level input VCC = 1.2 V voltage VCC = 1.65 V to 1.95 V VIL 40 C to +125 C Typ[1] IO = 8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = 18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = 24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 A; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V VI = VIH or VIL IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V - 0.1 5 - 20 A - 0.1 5 - 20 A II input leakage current VCC = 3.6 V; VI = 5.5 V or GND IOZ OFF-state output current VI = VIH or VIL; VCC = 3.6 V; VO = 5.5 V or GND; IOFF power-off VCC = 0 V; VI or VO = 5.5 V leakage current - 0.1 10 - 20 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 40 - 160 A ICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A - 5 500 - 5000 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 5.0 - - - pF [2] [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. [2] For I/O ports the parameter IOZ includes the input leakage current. 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 6 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 5. Symbol Parameter propagation delay tpd enable time ten Tamb = 40 C to +85 C 40 C to +125 C Unit Conditions Min Typ[1] Max Min Max - 13.0 - - - ns VCC = 1.65 V to 1.95 V 1.5 4.8 10.4 1.5 12.0 ns VCC = 2.3 V to 2.7 V 1.0 2.6 5.4 1.0 6.1 ns VCC = 2.7 V 1.0 2.6 4.7 1.0 6.0 ns VCC = 3.0 V to 3.6 V 1.0 2.2 4.5 1.0 6.0 ns - 15.0 - - - ns VCC = 1.65 V to 1.95 V 1.5 5.8 12.5 1.5 14.4 ns VCC = 2.3 V to 2.7 V 1.0 3.3 6.9 1.0 8.0 ns VCC = 2.7 V 1.5 3.4 6.7 1.5 8.5 ns 1.0 2.7 5.5 1.0 7.0 ns - 11.0 - - - ns VCC = 1.65 V to 1.95 V 1.0 4.4 9.7 1.0 11.2 ns VCC = 2.3 V to 2.7 V 0.5 2.5 5.5 0.5 6.5 ns VCC = 2.7 V 1.5 2.5 6.6 1.5 8.5 ns VCC = 3.0 V to 3.6 V 1.5 3.1 5.6 1.5 7.0 ns - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 11.5 - - - pF VCC = 2.3 V to 2.7 V - 15.2 - - - pF VCC = 3.0 V to 3.6 V - 18.5 - - - pF nAn to nBn; nBn to nAn; see Figure 3 [2] VCC = 1.2 V nOE to nAn, nBn: see Figure 4 [2] VCC = 1.2 V VCC = 3.0 V to 3.6 V disable time tdis nOE to nAn, nBn; see Figure 4 [2] VCC = 1.2 V tsk(o) output skew time VCC = 3.0 V to 3.6 V [3] CPD power dissipation capacitance per buffer; VI = GND to VCC [4] [1] Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] [4] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 7 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 11. Waveforms VI nAn, nBn input VM GND t PHL t PLH VOH nBn, nAn output VM VOL mna477 VM = 1.5 V at VCC  2.7 V. VM = 0.5  VCC at VCC < 2.7 V. VOL and VOH are typical output voltage levels that occur with the output load. Fig 3. The input (nAn, nBn) to output (nBn, nAn) propagation delays VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs disabled outputs enabled mna362 VM = 1.5 V at VCC  2.7 V. VM = 0.5  VCC at VCC < 2.7 V. VX = VOL + 0.3 V at VCC  2.7 V; VX = VOL + 0.15 V at VCC < 2.7 V. VY = VOH  0.3 V at VCC  2.7 V; VY = VOH  0.15 V at VCC < 2.7 V. VOL and VOH are typical output voltage levels that occur with the output load. Fig 4. 3-state enable and disable times. 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 8 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC VI RL VO G DUT RT RL CL 001aae331 Test data is given in Table 8. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 5. Table 8. Load circuitry for switching times Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC  2 ns 30 pF 1 k open 2  VCC GND 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k open 2  VCC GND 2.3 V to 2.7 V VCC  2 ns 30 pF 500  open 2  VCC GND 2.7 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 9 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 12. Package outline LFBGA96: plastic low profile fine-pitch ball grid array package; 96 balls; body 13.5 x 5.5 x 1.05 mm SOT536-1 A B D ball A1 index area A A2 E A1 detail X e1 1/2 C e ∅v M e ∅w M b T R P N M L K J H G F E D C B A ball A1 index area y1 C C A B C y e e2 1/2 e 1 2 3 4 5 6 X 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 b D E e e1 e2 v w y y1 mm 1.5 0.41 0.31 1.2 0.9 0.51 0.41 5.6 5.4 13.6 13.4 0.8 4 12 0.15 0.1 0.1 0.2 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 00-03-04 03-02-05 SOT536-1 Fig 6. Package outline SOT536-1 (LFBGA96) 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 10 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 13. Abbreviations Table 9. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC32245A v.3 20111216 Product data sheet - 74LVC32245A v.2 Modifications: 74LVC32245A v.2 Modifications: 74LVC32245A v.1 74LVC32245A Product data sheet • Maximum propagation delay value for VCC = 1.65 V to 1.95 V at +125 C changed from 11.7 ns to 12.0 ns • Maximum enable time value for VCC = 1.65 V to 1.95 V at +125 C changed from 14.3 ns to 14.4 ns 20111108 Product data sheet - 74LVC32245A v.1 • The format of this document has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Table 4, Table 5, Table 6, Table 7 and Table 8: values added for lower voltage ranges. 19990901 Product Specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 - © Nexperia B.V. 2017. All rights reserved 11 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 12 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVC32245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 December 2011 © Nexperia B.V. 2017. All rights reserved 13 of 14 74LVC32245A Nexperia 32-bit bus transceiver with direction pin; 5 V tolerant; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 December 2011
74LVC32245AEC,557 价格&库存
很抱歉,暂时无法提供与“74LVC32245AEC,557”相匹配的价格&库存,您可以联系我们找货
