A1259-HBTTC.N.GN
A1259-HBTTC.N.GN
    SUNON
    FANAXIAL254X89MM115VACTERM
A1259-HBTTC.N.GN 数据手册
O 254x89 mm Alveolate Motor 425-870 CFM Model Rating Voltage Bearing P/N VAPO BALL Sleeve TC.N.GN A1259-MBL TC.N.GN A1259-MBT TC.N.GN A1259-HBL TC.N.GN A1259-HBT TC.N.GN A1259-XBL TC.N.GN A1259-XBT TC.N.GN A2259-MBL TC.N.GN A2259-MBT TC.N.GN A2259-HBL TC.N.GN A2259-HBT Frame : Aluminum alloy Static Pressure (Inch-H2O) 0.8 Ball (50Hz) 0.7 Power Consumption Speed Air Flow Static Pressure Noise Weight (Hz) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 115 115 115 115 115 115 220-240 220-240 220-240 220-240 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 50/60 0.23/0.23 0.23/0.23 0.60/0.65 0.60/0.65 0.83/1.10 0.83/1.10 0.15/0.13 0.15/0.13 0.24/0.27 0.24/0.27 20/23 20/23 63/72 63/72 88/120 88/120 63/72 63/72 56/61 56/61 1400/1600 1400/1600 2100/1900 2100/1900 2600/2900 2600/2900 1400/1600 1400/1600 2100/1900 2100/1900 425/500 425/500 650/585 650/585 800/870 800/870 425/500 425/500 650/585 650/585 0.27/0.31 0.27/0.31 0.35/0.31 0.35/0.31 0.76/0.62 0.76/0.62 0.27/0.31 0.27/0.31 0.35/0.31 0.35/0.31 50/52 50/52 62/60 62/60 68/70 68/70 50/52 50/52 62/60 62/60 2300 2300 2300 2300 2400 2400 2300 2300 2300 2300 Ball (60Hz) XBL HBL MBL 0.7 0.6 0.6 0.5 0.5 0.4 0.4 0.3 0.3 0.2 0.2 0.1 0.1 0 Power Current (VAC) 0.8 XBL HBL MBL Freq. 0 100 200 300 400 500 600 700 800 900 100 200 300 400 500 600 700 800 900 Airflow (CFM) ROTATION 320²10 UNITS:mm AIR FLOW 10²1 TERMINAL TYPE 7.5 (THICK 0.5) INLET OUTLET UL1015 #20AWG ROTATION 16- 4.5 22 3.6 231 .9 AIR FLOW SUNON M5 245.5 ²0.5 89²0.5 254 +1 -0.5 *All model could be customized on voltage or any other requirements to fit your need. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 23
A1259-HBTTC.N.GN 价格&库存
很抱歉,暂时无法提供与“A1259-HBTTC.N.GN”相匹配的价格&库存,您可以联系我们找货
