CFM-7010-13-22
CFM-7010-13-22
    CUIDEVICES
    DCAXIALFAN,70MMSQUARE,10M
CFM-7010-13-22 数据手册
Additional Resources: Product Page date 04/28/2021 page 1 of 5 SERIES: CFM-70 │ DESCRIPTION: DC AXIAL FAN 70 x 70 mm frame high fan speed for greater air flow dual ball bearing construction auto restart protection standard on all models MODEL input voltage range (Vdc) 12 6~13.8 CFM-7010-13* Notes: input power rated speed air flow1 static pressure2 noise typ (A) max (A) max (W) typ (RPM) (CFM) (inch H2O) max (dBA) 0.22 0.27 3.24 4,400 31.11 0.16 40.6 TI rated (Vdc) input current N U • • • • ED FEATURES 1. At 0 inch H20 static pressure. 2. At 0 CFM airflow. *. Discontinued CFM-7010-13-20 and CFM-7010-13-22 models N PART NUMBER KEY O CFM-7010-13 - XX - CXX Base Number Reserved for Custom Configurations D IS C Fan Signals 10 = no signals 11 = rotation detector signal 20 = tachometer signal 22 = tachometer signal / PWM control signal cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-70 │ DESCRIPTION: DC AXIAL FAN date 04/28/2021 │ page 2 of 5 INPUT parameter conditions/description operating input voltage min typ max units 6 12 13.8 Vdc 0.22 0.27 power 2.64 starting voltage at 25°C conditions/description min rated speed at 25°C, after 10 minutes 3,960 air flow at 0 inch H2O, see performance curves static pressure at 0 CFM, see performance curves noise at 1 m auto restart protection available on all models rotation detector available on “11” models tachometer signal available on “20” and “22” models PWM control signal available on “22” models Notes: min N conditions/description 1. See application notes for details. SAFETY & COMPLIANCE conditions/description at 500 Vdc between frame and positive terminal dielectric strength at 500 Vac, 60 Hz, 1 minute between frame and positive terminal safety approvals UL/cUL 507, TUV (EN 62368-1) EMI/EMC EN 55022:2010+AC:2011 Class B, EN 61000-32:2014, EN 61000-3-3:2013, EN 55024:2010 min 4,400 4,840 RPM CFM inch H2O 39.5 40.6 dBA typ max units typ max units 10 MΩ 5 O RoHS units N parameter insulation resistance of frame life expectancy max 31.11 TI parameter Vdc 0.16 PROTECTIONS / SIGNALS1 at 45°C, 15~65% RH W typ U parameter 3.24 6 PERFORMANCE A ED current 70,000 mA hours yes IS C ENVIRONMENTAL max units operating temperature parameter conditions/description min -10 typ 70 °C storage temperature -40 70 °C non-condensing 5 90 % storage humidity non-condensing 5 95 % D operating humidity cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-70 │ DESCRIPTION: DC AXIAL FAN date 04/28/2021 │ page 3 of 5 0.18 ED (mm H 2O) (Inch H2O) PERFORMANCE CURVES 4.50 4.00 0.14 3.50 3.00 0.11 0.07 2.50 2.00 0.04 1.00 0.50 0.00 0.00 10.00 20.00 30.00 40.00 (CFM) N 0.00 U 1.50 (CMM) 0.00 0.23 MECHANICAL 0.45 0.68 0.91 conditions/description 4 pole DC brushless bearing system ball bearing direction of rotation counter-clockwise viewed from front of fan blade dimensions 70 x 70 x 10.6 material PBT (UL94V-0) units: mm [inch] IS C wire: UL 1061, 26 AWG O MECHANICAL DRAWING N weight min TI parameter motor WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin 1 FG Signal White1 RD Signal Blue PWM Yellow /DEHO D 1 Note: 1.13 1. Wires only present on versions with output signals. cuidevices.com typ max units mm 37.3 g Additional Resources: Product Page CUI Devices │ SERIES: CFM-70 │ DESCRIPTION: DC AXIAL FAN date 04/28/2021 │ page 4 of 5 APPLICATION NOTES N U Figure 1 Current Limit Protection ED Auto Restart Protection/Current Limit Protection When the fan motor is locked, the device will cut off the drive current within two to six seconds and restart automatically after a few seconds. If the lock situation is continued, the device will work on a repeated cycle of cut-off and restart until the lock is released. (See Figure 1 below). TI Lock Sensor/Rotation Detector Lock Sensor is used to detect if the fan motor is operating or stopped. Alarm High: the output will be logical low when fan is operating and be logical high when fan motor is locked. (See Figures 2~3 below). Figure 3 RD Signal Output Circuit: Open Collector Ic=5mA max N Figure 2 Alarm High Output Waveform O Pulse Sensor/Tachometer Signal/FG Pulse Sensor is for detecting the rotational speed of the fan motor. At locked rotor condition, the signal stops cycling and the output is fixed at VoH or VoL (See Figures 4~5 below). Figure 5 FG Signal Output Circuit: Open Collector IS C Figure 4 Output Waveform Ic=10mA max D PMW Control Signal A speed control lead can be provided that will accept a PWM signal from the customer circuit to vary the speed of the fan. The change in speed is linear by changing the Duty-Cycle of the PWM. Open collector type and pull-up voltage is changed by maximum operating voltage and sink current by consuming current. (See Figure 6 below). Figure 6 Duty Cycle Vs=4~5 V cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-70 │ DESCRIPTION: DC AXIAL FAN date 04/28/2021 │ page 5 of 5 REVISION HISTORY description date 08/15/2016 1.0 initial release 1.01 updated datasheet 1.02 updated to be certified to EN 62368-1 safety standard 1.03 brand update ED rev. 07/27/2017 07/09/2019 02/10/2020 1.04 updated drawing 1.05 discontinued CFM-7010-13-20 and CFM-7010-13-22 models 06/12/2020 04/28/2021 D IS C O N TI N U The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CFM-7010-13-22 价格&库存
很抱歉,暂时无法提供与“CFM-7010-13-22”相匹配的价格&库存,您可以联系我们找货
