G4010E24B-RSR
G4010E24B-RSR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL40X10MM24VDC
G4010E24B-RSR 数据手册
1.57 ±0.02 (40 ±0.5) 12 0.41 ±0.02 (10.3 ±0.5) 1.26 ±0.01 (32 ±0.3) STATIC PRESSURE - MM OF WATER DC AXIAL FANS G4010 series S 10 L M 8 H E 6 4 2 0 (40 x 40 x 10.3 mm) 0.1 AIR FLOW 4x Ø0.17 ±0.01 (4x Ø4.25 ±0.3) 0.2 0.3 0.4 AIR FLOW (M3/MIN) 1.57 x 1.57 x 0.41 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing Connection: Rated Voltage Current mA V 5 12 Speed Air Volume 24 RPM M³/Min. CFM Max. Static Pressure (H2 0) MM INCH Sound Noise Weight dbA g AWG 26, UL1061 lead wires G4010S 5/12 90 60 - 4,000 0.13 5.00 1.70 0.07 21 12 Frame: ribbed G4010L 5/12/24 140 100 70 5,000 0.16 6.00 2.70 0.11 22 12 Protection: thermal G4010M 5/12/24 240 150 100 6,000 0.19 7.00 3.70 0.15 28 12 G4010H 5/12/24 400 220 160 8,000 0.25 9.00 6.40 0.25 35 12 G4010E 12/24 - 350 250 10,000 0.32 11.00 9.90 0.39 41 12 Options: tachometer output or locked rotor alarm signal w w w.mechatronic s.com 12.15.14 Model No. E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
G4010E24B-RSR 价格&库存
很抱歉,暂时无法提供与“G4010E24B-RSR”相匹配的价格&库存,您可以联系我们找货
