CFM-8015-13-22
CFM-8015-13-22
    CUIDEVICES
    DCAXIALFAN,80MMSQUARE,15M
CFM-8015-13-22 数据手册
Additional Resources: Product Page date 10/18/2021 page 1 of 7 SERIES: CFM-80 │ DESCRIPTION: DC AXIAL FAN FEATURES • • • • 80 x 80 mm frame high fan speed for greater air flow dual ball bearing construction auto restart protection standard on all models MODEL input voltage input current input power rated speed air flow1 static pressure2 noise rated (Vdc) range (Vdc) typ (A) max (A) max (W) typ (RPM) (CFM) (inch H2O) max (dBA) CFM-8010-13* 12 6~13.8 0.16 0.24 2.88 3,300 33.61 0.11 38.2 CFM-8015-13* 12 6~13.8 0.18 0.24 2.88 3,500 43.96 0.16 39.8 CFM-8025-13* 12 6~13.8 0.33 0.43 5.16 5,100 69.20 0.42 47.0 CFM-8025-23* 24 16~27.6 0.16 0.25 4.8 5,100 69.20 0.42 47.0 Notes: 1. At 0 inch H20 static pressure. 2. At 0 CFM airflow. *. Discontinued all models of the CFM-8010-13, CFM-8015-13, & CFM-8025-13; and individual models CFM-8025-23-11, CFM-8025-23-20, and CFM-8025-23-22. PART NUMBER KEY CFM-80 XX - X 3 - XX - CXX Base Number Depth 10 = 10 mm 15 = 15 mm 25 = 25 mm Notes: Reserved for Custom Configurations Input Voltage 1 = 12 Vdc 23 = 24 Vdc 3. 24 Vdc input voltage option only available with 25 mm depth cuidevices.com Fan Signals 10 = no signals 11 = rotation detector signal 20 = tachometer signal 22 = tachometer signal / PWM control signal Additional Resources: Product Page CUI Devices │ SERIES: CFM-80 │ DESCRIPTION: DC AXIAL FAN date 10/18/2021 │ page 2 of 7 INPUT parameter conditions/description operating input voltage 12 Vdc input models 24 Vdc input models min typ max units 6 16 12 24 13.8 27.6 Vdc Vdc current CFM-8010 CFM-8015 CFM-8025 CFM-8025 models models models models 0.16 0.18 0.33 0.16 0.24 0.24 0.43 0.25 A A A A power CFM-8010 CFM-8015 CFM-8025 CFM-8025 models models models models 1.92 2.16 3.96 3.84 2.88 2.88 5.16 4.8 W W W W starting voltage at 25°C 12 Vdc input models 24 Vdc input models 6 16 Vdc Vdc PERFORMANCE parameter conditions/description min typ max units rated speed at 25°C, after 10 minutes CFM-8010 models CFM-8015 models CFM-8025 models 2,970 3,150 4,590 3,300 3,500 5,100 3,630 3,850 5,610 RPM RPM RPM air flow at 0 inch H2O, see performance curves CFM-8010 models CFM-8015 models CFM-8025 models static pressure noise 33.61 43.96 69.20 CFM CFM CFM at 0 CFM, see performance curves CFM-8010 models CFM-8015 models CFM-8025 models 0.11 0.16 0.42 inch H2O inch H2O inch H2O at 1 m CFM-8010 models CFM-8015 models CFM-8025 models 36.0 38.0 45.5 38.2 39.8 47.0 dBA dBA dBA min typ max units min typ max units PROTECTIONS / SIGNALS1 parameter conditions/description auto restart protection available on all models rotation detector available on “11” models tachometer signal available on “20” and “22” models PWM control signal available on “22” models Notes: 1. See application notes for details. SAFETY & COMPLIANCE parameter conditions/description insulation resistance of frame at 500 Vdc between frame and positive terminal dielectric strength at 500 Vac, 60 Hz, 1 minute between frame and positive terminal safety approvals UL/cUL 507, TUV (EN 62368-1) EMI/EMC EN 55022:2010+AC:2011 Class B, EN 61000-32:2014, EN 61000-3-3:2013, EN 55024:2010 life expectancy at 45°C, 15~65% RH RoHS yes 10 MΩ 5 70,000 cuidevices.com mA hours Additional Resources: Product Page CUI Devices │ SERIES: CFM-80 │ DESCRIPTION: DC AXIAL FAN date 10/18/2021 │ page 3 of 7 ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature max units -10 typ 70 °C -40 70 °C operating humidity non-condensing 5 90 % storage humidity non-condensing 5 95 % PERFORMANCE CURVES 0.12 0.09 0.18 3.00 0.14 2.00 0.05 0.07 1.00 2.50 2.00 1.50 0.04 0.50 0.00 3.50 3.00 0.11 1.50 0.00 4.50 4.00 2.50 0.07 0.02 (mm H 2O) (Inch H2O) CFM-8015 (mm H 2O) (Inch H2O) CFM-8010 1.00 0.50 0.00 0.00 10.00 20.00 30.00 40.00 (CFM) 0.00 0.00 10.00 0.00 0.28 20.00 30.00 40.00 0.85 1.13 50.00 (CFM) (CMM) 0.00 0.23 0.45 0.68 0.91 1.13 0.47 0.38 (mm H 2O) (Inch H2O) CFM-8025 12.00 10.00 8.00 0.28 6.00 0.19 4.00 0.09 0.00 2.00 0.00 0.00 20.00 40.00 60.00 80.00 (CFM) (CMM) 0.00 0.45 0.91 1.36 1.81 2.26 cuidevices.com (CMM) 0.57 1.42 Additional Resources: Product Page CUI Devices │ SERIES: CFM-80 │ DESCRIPTION: DC AXIAL FAN date 10/18/2021 │ page 4 of 7 MECHANICAL parameter conditions/description motor 4 pole DC brushless min bearing system ball bearing direction of rotation counter-clockwise viewed from front of fan blade dimensions CFM-8010 models: 80 x 80 x 10.6 CFM-8015 models: 80 x 80 x 15.4 CFM-8025 models: 80 x 80 x 25.4 material PBT (UL94V-0) weight CFM-8010-13 CFM-8015-13 CFM-8025-13 CFM-8025-23 models models models models units: mm [inch] CFM-8010 wire: UL 1061, 26 AWG WIRE CONNECTIONS Function Red +Vin Black -Vin Yellow1 FG Signal White1 RD Signal Blue1 PWM ōŢţŦŭ CFM-8015 wire: UL 1061, 26 AWG WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin Yellow1 FG Signal White1 RD Signal Blue1 PWM Note: ōŢţŦŭ 1. Wires only present on versions with output signals. cuidevices.com max units mm mm mm 42.6 59.2 87.7 91.6 MECHANICAL DRAWING Wire Color typ g g g g Additional Resources: Product Page CUI Devices │ SERIES: CFM-80 │ DESCRIPTION: DC AXIAL FAN date 10/18/2021 │ page 5 of 7 MECHANICAL DRAWING (CONTINUED) units: mm [inch] CFM-8025 wire: UL 1007, 24 AWG WIRE CONNECTIONS Wire Color Function Red +Vin Black Yellow -Vin 1 FG Signal White1 RD Signal Blue1 PWM Note: ōŢţŦŭ 1. Wires only present on versions with output signals. cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-80 │ DESCRIPTION: DC AXIAL FAN date 10/18/2021 │ page 6 of 7 APPLICATION NOTES Auto Restart Protection/Current Limit Protection When the fan motor is locked, the device will cut off the drive current within two to six seconds and restart automatically after a few seconds. If the lock situation is continued, the device will work on a repeated cycle of cut-off and restart until the lock is released. (See Figure 1 below). Figure 1 Current Limit Protection Lock Sensor/Rotation Detector Lock Sensor is used to detect if the fan motor is operating or stopped. Alarm High: the output will be logical low when fan is operating and be logical high when fan motor is locked. (See Figures 2~3 below). Figure 3 RD Signal Output Circuit: Open Collector Figure 2 Alarm High Output Waveform Ic=5mA max Pulse Sensor/Tachometer Signal/FG Pulse Sensor is for detecting the rotational speed of the fan motor. At locked rotor condition, the signal stops cycling and the output is fixed at VoH or VoL (See Figures 4~5 below). Figure 4 Output Waveform Figure 5 FG Signal Output Circuit: Open Collector Ic=10mA max PMW Control Signal A speed control lead can be provided that will accept a PWM signal from the customer circuit to vary the speed of the fan. The change in speed is linear by changing the Duty-Cycle of the PWM. Open collector type and pull-up voltage is changed by maximum operating voltage and sink current by consuming current. (See Figure 6 below). Figure 6 Duty Cycle Vs=4~5 V cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: CFM-80 │ DESCRIPTION: DC AXIAL FAN date 10/18/2021 │ page 7 of 7 REVISION HISTORY rev. description date 1.0 initial release 08/15/2016 1.01 updated datasheet 07/27/2017 1.02 discontinued model CFM-8025-13-22 11/10/2017 1.03 discontinued CFM-8025-13-11, CFM-8025-23-11, CFM-8025-23-20, and CFM-8025-23-22 models 01/29/2018 1.04 updated to be certified to EN 62368-1 safety standard 07/09/2019 1.05 brand update 02/10/2020 1.06 discontinued CFM-8015-13-10 and CFM-8015-13-20 models 04/28/2021 1.07 discontinued model CFM-8010-13-22 09/24/2021 1.08 discontinued CFM-8010-13-10, CFM-8010-13-11, CFM-8010-13-20, CFM-8015-13-11, CFM-8015-13-22, CFM-8025-13-10, & CFM-802513-20 models 10/18/2021 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CFM-8015-13-22 价格&库存
很抱歉,暂时无法提供与“CFM-8015-13-22”相匹配的价格&库存,您可以联系我们找货
