74LVC1G07GW,165
74LVC1G07GW,165
    NEXPERIA(安世)
    TSSOP-5
    IC BUF NON-INVERT 5.5V 5TSSOP
74LVC1G07GW,165 数据手册
74LVC1G07 Buffer with open-drain output Rev. 12 — 28 November 2016 Product data sheet 1. General description The 74LVC1G07 provides the non-inverting buffer. The output of this device is an open drain and can be connected to other open-drain outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. Schmitt-trigger action at all inputs makes the circuit tolerant for slower input rise and fall time. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits             Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant input/output for interfacing with 5 V logic High noise immunity Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V) ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 24 mA output drive (VCC = 3.0 V) CMOS low power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels Inputs accept voltages up to 5 V Multiple package options Specified from 40 C to +85 C and 40 C to +125 C 74LVC1G07 Nexperia Buffer with open-drain output 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G07GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G07GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G07GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1.45  0.5 mm SOT886 74LVC1G07GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1  0.5 mm SOT891 74LVC1G07GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74LVC1G07GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74LVC1G07GX 40 C to +125 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G07GW VS 74LVC1G07GV V07 74LVC1G07GM VS 74LVC1G07GF VS 74LVC1G07GN VS 74LVC1G07GS VS 74LVC1G07GX VS [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram < /9&* QF   9&& $   QF *1'   < $ DDE Logic symbol 74LVC1G07 Product data sheet  < $ *1' PQD 7UDQVSDUHQWWRSYLHZ Fig 1.  Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 12 — 28 November 2016 Fig 3. PQD Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 18 74LVC1G07 Nexperia Buffer with open-drain output 6. Pinning information 6.1 Pinning /9&* /9&* QF  $  *1'   9&&  < QF   9&& $   QF *1'   < DDE 7UDQVSDUHQWWRSYLHZ DDE Fig 4. Pin configuration SOT353-1 and SOT753 Fig 5. Pin configuration SOT886 /9&* /9&* QF QF   9&& $   QF *1'   <  9&&  <  *1' $ DDJ  DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 6.  Pin configuration SOT891, SOT1115 and SOT1202 Fig 7. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description TSSOP5 and X2SON5 XSON6 n.c. 1 1 not connected A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 74LVC1G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 28 November 2016 © Nexperia B.V. 2017. All rights reserved 3 of 18 74LVC1G07 Nexperia Buffer with open-drain output 7. Functional description Table 4. Function table[1] Input A Output Y L L H Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions input voltage IOK output clamping current VO < 0 V VO output voltage Active mode Power-down mode IO output current Max Unit +6.5 V 50 - [1] 0.5 +6.5 50 - [1] 0.5 +6.5 V [1][2] 0.5 +6.5 V - 50 mA VI < 0 V VI Min 0.5 VO = 0 V to 6.5 V mA V mA ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot Tamb = 40 C to +125 C [3] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - 5.5 V Power-down mode; VCC = 0 V 0 - 5.5 V 40 - +125 - - 20 ns/V - - 10 ns/V Tamb ambient temperature t/V input transition rise and VCC = 1.65 V to 2.7 V fall rate VCC = 2.7 V to 5.5 V 74LVC1G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 28 November 2016 © C Nexperia B.V. 2017. All rights reserved 4 of 18 74LVC1G07 Nexperia Buffer with open-drain output 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter HIGH-level input voltage VIH LOW-level input voltage VIL 40 C to +85 C Conditions VCC = 1.65 V to 1.95 V Min Max Min Max Unit 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.65 V to 1.95 V - - 0.35VCC - 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V - - 0.10 - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.70 V LOW-level VI = VIH or VIL output voltage IO = 100 A; VCC = 1.65 V to 5.5 V VOL 40 C to +125 C Typ[1] IO = 8 mA; VCC = 2.3 V - - 0.30 - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.40 - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.80 V - - 0.55 - 0.80 V - 0.1 1 - 1 A IO = 32 mA; VCC = 4.5 V [2] II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - 0.1 2 - 2 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - 0.1 2 - 2 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 - 4 A ICC additional per pin; VI = VCC  0.6 V; supply current IO = 0 A; VCC = 2.3 V to 5.5 V - 5 500 - 500 A CI input capacitance - 5.0 - - - pF VCC = 3.3 V; VI = GND to VCC [1] All typical values are measured at Tamb = 25 C. [2] These typical values are measured at VCC = 3.3 V. 74LVC1G07 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 12 — 28 November 2016 © Nexperia B.V. 2017. All rights reserved 5 of 18 74LVC1G07 Nexperia Buffer with open-drain output 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for load circuit see Figure 9. Symbol Parameter 40 C to +85 C Conditions Min Max Min Max VCC = 1.65 V to 1.95 V 1.0 2.6 6.7 1.0 8.4 ns VCC = 2.3 V to 2.7 V 0.5 1.7 5.5 0.5 7.0 ns VCC = 2.7 V 0.5 2.3 4.7 0.5 6.0 ns VCC = 3.0 V to 3.6 V 0.5 2.2 4.2 0.5 5.5 ns VCC = 4.5 V to 5.5 V 0.5 1.6 3.5 0.5 4.5 ns - 7.0 - - - pF [2] propagation delay A to Y; see Figure 8 tpd power dissipation capacitance CPD 40 C to +125 C Unit Typ[1] VI = GND to VCC; VCC = 3.3 V [3] [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLZ and tPZL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. Waveforms 9, 90 $LQSXW  *1' W 3=/ W 3/= 9&& 90
74LVC1G07GW,165
物料型号:74LVC1G07
器件简介: - 74LVC1G07是一种非反相缓冲器,具有开漏输出。 - 输出可以连接到其他开漏输出,以实现主动低电平或主动高电平的线或逻辑功能。 - 输入可以从3.3V或5V设备驱动,适用于3.3V和5V混合环境。 - 所有输入都具有施密特触发器动作,使电路对较慢的输入上升和下降时间具有容忍度。 - 该设备在部分断电应用中完全指定,使用IOFF电路来禁用输出,防止在断电时通过设备产生有害的反向电流。
引脚分配: - 引脚1:未连接 - 引脚2:数据输入(A) - 引脚3:地(GND) - 引脚4:数据输出(Y) - 引脚5或6:供电电压(Vcc)
参数特性: - 供电电压范围:1.65V至5.5V - 5V容限输入/输出,适用于与5V逻辑接口 - 高噪声免疫力 - 符合JEDEC标准 - ESD保护:HBM JESD22-A114F超过2000V,MM JESD22-A115-A超过200V - 输出驱动电流:-24mA(VCC = 3.0V) - CMOS低功耗 - 闩锁性能超过250mA - 直接与TTL电平接口 - 输入接受高达5V的电压 - 多种封装选项 - 指定温度范围:-40°C至+85°C和-40°C至+125°C
功能详解: - 功能表显示输入A和输出Y的逻辑关系,其中输入A为高电平时,输出Y也为高电平;输入A为低电平时,输出Y为低电平。 - 施密特触发器动作确保了输入信号的稳定性。
应用信息: - 74LVC1G07适用于需要非反相缓冲和开漏输出的应用,例如在数字逻辑电路中。
封装信息: - 提供多种封装选项,包括TSSOP5、SC-74A、XSON6、SOT353-1、SOT753、SOT886、SOT891、SOT1115、SOT1202和X2SON5。
74LVC1G07GW,165 价格&库存
很抱歉,暂时无法提供与“74LVC1G07GW,165”相匹配的价格&库存,您可以联系我们找货
