G8032L24B-RSR
G8032L24B-RSR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL80X32MM24VDC
G8032L24B-RSR 数据手册
DC G8032 series Size: (80 x 80 x 32 mm) 2.82 ±0.01 (71.5 ±0.3) 0.16 (4) 0.16 (4) 3.15 x 3.15 x 1.26 inches Construction: Bearing option: Connection: Frame: Protection: Options: STATIC PRESSURE - MM OF WATER 1.26 ±0.02 (32 ±0.5) 3.15 ±0.02 (80 ±0.5) 12 UL94V-0 PBT impeller & frame ball bearing AWG 24, 1007 lead wires ribbed thermal tachometer output or locked rotor alarm signal; encapsulated motor E 10 H 8 M L 6 S 4 2 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 AIR VOLUME Q= M3/MIN 4x Ø 0.17 (Ø 4.4) Model No. Ø 3. 54 (Ø 90 ) 2.82 ±0.01 (71.5 ±0.3) 18 www.mechatronics.com 4x Ø 0.17 (Ø 4.4) Rated Voltage V Current mA 12 24 Revolution RPM Air Volume M³/Min. CFM Max. Static Pressure (H20) MM INCH Sound Noise dbA Weight g G8032S 12/24 140 100 2,500 0.82 29 3.77 0.15 30 128 G8032L 12/24 200 150 3,000 0.97 34 5.11 0.20 34 128 G8032M 12/24 260 200 3,500 1.17 41 7.34 0.29 38 128 G8032H 12/24 450 250 4,000 1.35 48 9.33 0.37 42 128 G8032E 12/24 550 330 4,500 1.47 52 11.34 0.45 46 128 E-mail: Sales@Mechatronics.com Fax: 425-222-5155 Tel: 425-222-5900 800-453-4569 03/22/11 3.00 (76)
G8032L24B-RSR 价格&库存
很抱歉,暂时无法提供与“G8032L24B-RSR”相匹配的价格&库存,您可以联系我们找货
