74LV132DB,112
74LV132DB,112
    NEXPERIA(安世)
    SSOP-14_6.2X5.3MM
    IC GATE NAND 4CH 2-INP 14SSOP
74LV132DB,112 数据手册
74LV132 Quad 2-input NAND Schmitt trigger Rev. 8 — 13 September 2021 Product data sheet 1. General description The 74LV132 is a quad 2-input NAND gate with Schmitt-trigger inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess VCC. 2. Features and benefits • • • • • • • • • • • Wide supply voltage range from 1.0 V to 5.5 V CMOS low power dissipation Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 °C Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 °C Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Applications • • • Wave and pulse shapers for highly noisy environments Astable multivibrators Monostable multivibrators 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV132D -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV132PW -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV132BQ -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm SOT762-1 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 5. Functional diagram 1 1A 1Y 2 4 1B 2A 2Y 5 9 2B 1 6 2 4 3A 3Y 10 3 3B 5 9 4A 4Y 13 4B 12 11 13 & 6 & 8 & 11 A Y B mna408 mna407 Fig. 1. 3 8 10 12 & Logic symbol Fig. 2. mna409 IEC logic symbol Fig. 3. Logic diagram (one gate) 6. Pinning information 6.1. Pinning 1 74LV132 2 13 4B 3 2A 4 2B 5 2Y 6 11 4Y VCC(1) 1Y 3 12 4A 2A 4 11 4Y 2B 5 10 3B 2Y 6 9 3A GND 7 8 3Y Product data sheet 10 3B 9 3A 001aah099 Transparent top view Pin configuration SOT108-1 (SO14) and SOT402-1 (TSSOP14) 74LV132 13 4B 12 4A 8 1B 1Y 3Y 14 VCC 2 7 1 1B GND 1A (1) This is not a supply pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to VCC 001aac203 Fig. 4. 1A terminal 1 index area 14 VCC 74LV132 Fig. 5. Pin configuration SOT762-1 (DHVQFN14) All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 2 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 6.2. Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A 1, 4, 9, 12 data input 1B, 2B, 3B, 4B 2, 5, 10, 13 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Output Input nA nB nY L L H L H H H L H H H L 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7.0 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±50 mA IO output current VO = -0.5 V to (VCC + 0.5 V) - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C. 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 3 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 9. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature [1] [1] Min Typ Max Unit 1.0 3.3 5.5 V 0 - VCC V 0 - VCC V -40 +25 +125 °C The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 10. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH VOL Conditions -40 °C to +85 °C Min Typ [1] Max Min Max - 1.2 - - - V lO = -100 μA; VCC = 2.0 V 1.8 2.0 - 1.8 - V lO = -100 μA; VCC = 2.7 V 2.5 2.7 - 2.5 - V lO = -100 μA; VCC = 3.0 V 2.8 3.0 - 2.8 - V lO = -100 μA; VCC = 4.5 V 4.3 4.5 - 4.3 - V lO = -6 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V lO = -12 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V IO = 100 μA; VCC = 1.2 V - 0 - - - V IO = 100 μA; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 μA; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 μA; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 100 μA; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 12 mA; VCC = 4.5 V - 0.35 0.55 - 0.65 V HIGH-level output VI = VT+ or VTvoltage lO = -100 μA; VCC = 1.2 V LOW-level output voltage -40 °C to +125 °C Unit VI = VT+ or VT- II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 - 40 μA ΔICC additional supply current per input; VI = VCC - 0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 μA CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 °C. 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 4 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 11. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Fig. 7. Symbol Parameter tpd propagation delay CPD [1] [2] [3] [4] power dissipation capacitance Conditions -40 °C to +85 °C Min Typ [1] VCC = 1.2 V - VCC = 2.0 V - VCC = 2.7 V nA, nB to nY; see Fig. 6 -40 °C to +125 °C Unit Max Min Max 65 - - - ns 18 34 - 43 ns - 15 24 - 30 ns [2] VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 10 - - - ns VCC = 3.0 V to 3.6 V [3] - 12 20 - 25 ns VCC = 4.5 V to 5.5 V [3] - 9.0 14 - 17 ns CL = 50 pF; fi = 1 MHz; VI = GND to VCC [4] - 24 - - - pF All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching 2 Σ(CL × VCC × fo) = sum of the outputs. 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 5 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 11.1. Waveforms and test circuit VI VM nA, nB input GND t PHL t PLH VOH VM nY output VOL 001aaa662 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. The input (nA, nB) to output (nY) propagation delays Table 8. Measurement points Supply voltage Input Output VCC VM VM < 2.7 V 0.5VCC 0.5VCC 2.7 V to 3.6 V 1.5 V 1.5 V ≥ 4.5 V 0.5VCC 0.5VCC VCC PULSE GENERATOR VI VO DUT RT CL 50 pF RL 1 kΩ 001aaa663 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. Fig. 7. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf < 2.7 V VCC ≤ 2.5 ns 2.7 V to 3.6 V 2.7 V ≤ 2.5 ns ≥ 4.5 V VCC ≤ 2.5 ns 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 6 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 12. Transfer characteristics Table 10. Transfer characteristics GND = 0 V; See Fig. 8 to Fig. 12. Symbol Parameter -40 °C to +85 °C see Fig. 8 to Fig. 12 positive-going threshold voltage V = 1.2 V CC VT+ VH hysteresis voltage Min Typ [1] -40 °C to +125 °C Max Min Unit Max - 0.70 - - - V VCC = 2.0 V 0.8 1.10 1.4 0.8 1.4 V VCC = 2.7 V 1.0 1.45 2.0 1.0 2.0 V VCC = 3.0 V 1.2 1.60 2.2 1.2 2.2 V VCC = 3.6 V 1.5 1.95 2.4 1.5 2.4 V VCC = 4.5 V 1.7 2.50 3.2 1.7 3.2 V VCC = 5.5 V 2.1 3.00 3.9 2.1 3.9 V - 0.34 - - - V VCC = 2.0 V 0.3 0.65 0.9 0.3 0.9 V VCC = 2.7 V 0.4 0.90 1.4 0.4 1.4 V VCC = 3.0 V 0.6 1.05 1.5 0.6 1.5 V VCC = 3.6 V 0.8 1.30 1.8 0.8 1.8 V VCC = 4.5 V 0.9 1.60 2.0 0.9 2.0 V VCC = 5.5 V 1.2 2.00 2.6 1.2 2.6 V VCC = 1.2 V - 0.3 - - - V VCC = 2.0 V 0.2 0.55 0.8 0.2 0.8 V VCC = 2.7 V 0.3 0.60 1.1 0.3 1.1 V VCC = 3.0 V 0.4 0.65 1.2 0.4 1.2 V VCC = 3.6 V 0.4 0.70 1.2 0.4 1.2 V VCC = 4.5 V 0.4 0.80 1.4 0.4 1.4 V VCC = 5.5 V 0.6 1.00 1.5 0.6 1.5 V see Fig. 8 to Fig. 12 negative-going threshold voltage V = 1.2 V CC VT- [1] Conditions (VT+ - VT-); see Fig. 8 to Fig. 12 All typical values are measured at Tamb = 25 °C. 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 7 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 12.1. Waveforms transfer characteristics VO VT- VT+ mna208 VT+ and VT- limits at 70 % and 20 %. mna207 Transfer characteristic Fig. 9. 001aaa659 12 VH VT- VO VI VH Fig. 8. VT+ VI Definition of VT+, VT- and VH 001aaa660 100 ICC (µA) ICC (µA) 80 8 60 40 4 20 0 0 0.3 0.6 0.9 VI (V) 0 1.2 VCC = 1.2 V. 0 0.4 0.8 1.2 1.6 VI (V) 2 VCC = 2.0 V. Fig. 10. Typical 74LV132 transfer characteristics Fig. 11. Typical 74LV132 transfer characteristics 001aaa661 300 ICC (µA) 200 100 0 0 0.6 1.2 1.8 2.4 VI (V) 3 VCC = 3.0 V. Fig. 12. Typical 74LV132 transfer characteristics 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 8 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 13. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 13. Package outline SOT108-1 (SO14) 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 9 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 14. Package outline SOT402-1 (TSSOP14) 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 10 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 15. Package outline SOT762-1 (DHVQFN14) 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 11 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 14. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV132 v.8 20210913 Product data sheet - Modifications: • • • 74LV132 v.7 20200520 Modifications: • • • 74LV132 v.7 Type number 74LV132DB (SOT337-1/SSOP14) removed. Section 1 updated. Section 2 updated. Product data sheet - 74LV132 v.6 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Table 4: Derating values for Ptot total power dissipation updated. 74LV132 v.6 20151209 Modifications: • 74LV132 v.5 20090702 Modifications: • 74LV132 v.4 20071112 Product data sheet - 74LV132 v.3 74LV132 v.3 20040415 Product specification - 74LV132 v.2 74LV132 v.2 19980428 Product specification - 74LV132 v.1 74LV132 v.1 19970204 Product specification - - 74LV132 Product data sheet Product data sheet - 74LV132 v.5 Type number 74LV132N (SOT27-1) removed. Product data sheet - 74LV132 v.4 Table 6: the conditions for HIGH-level output voltage and LOW-level output voltage have been changed. All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 12 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LV132 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 13 / 14 74LV132 Nexperia Quad 2-input NAND Schmitt trigger Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................5 11.1. Waveforms and test circuit........................................ 6 12. Transfer characteristics............................................. 7 12.1. Waveforms transfer characteristics............................8 13. Package outline.......................................................... 9 14. Abbreviations............................................................ 12 15. Revision history........................................................12 16. Legal information......................................................13 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 September 2021 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 September 2021 © Nexperia B.V. 2021. All rights reserved 14 / 14
74LV132DB,112 价格&库存
很抱歉,暂时无法提供与“74LV132DB,112”相匹配的价格&库存,您可以联系我们找货
