74HCT173DB,118
74HCT173DB,118
    NEXPERIA(安世)
    SSOP-16
    IC FF D-TYPE SNGL 4BIT 16SSOP
74HCT173DB,118 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS DATA SHEET For a complete data sheet, please also download: • The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications • The IC06 74HC/HCT/HCU/HCMOS Logic Package Information • The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines 74HC/HCT173 Quad D-type flip-flop; positive-edge trigger; 3-state Product specification File under Integrated Circuits, IC06 December 1990 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 synchronously with the LOW-to-HIGH clock (CP) transition. When one or both En inputs are HIGH one set-up time prior to the LOW-to-HIGH clock transition, the register will retain the previous data. Data inputs and clock enable inputs are fully edge-triggered and must be stable only one set-up time prior to the LOW-to-HIGH clock transition. FEATURES • Gated input enable for hold (do nothing) mode • Gated output enable control • Edge-triggered D-type register • Asynchronous master reset • Output capability: bus driver The master reset input (MR) is an active HIGH asynchronous input. When MR is HIGH, all four flip-flops are reset (cleared) independently of any other input condition. • ICC category: MSI GENERAL DESCRIPTION The 3-state output buffers are controlled by a 2-input NOR gate. When both output enable inputs (OE1 and OE2) are LOW, the data in the register is presented to the Qn outputs. When one or both OEn inputs are HIGH, the outputs are forced to a high impedance OFF-state. The 3-state output buffers are completely independent of the register operation; the OEn transition does not affect the clock and reset operations. The 74HC/HCT173 are high-speed Si-gate CMOS devices and are pin compatible with low power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74HC/HCT173 are 4-bit parallel load registers with clock enable control, 3-state buffered outputs (Q0 to Q3) and master reset (MR). When the two data enable inputs (E1 and E2) are LOW, the data on the Dn inputs is loaded into the register QUICK REFERENCE DATA GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns TYPICAL SYMBOL PARAMETER CONDITIONS UNIT HC tPHL/ tPLH propagation delay CP to Qn MR to Qn HCT CL = 15 pF; VCC = 5 V 17 13 17 17 ns ns fmax maximum clock frequency 88 88 MHz CI input capacitance 3.5 3.5 pF CPD power dissipation capacitance per flip-flop 20 20 pF notes 1 and 2 Notes 1. CPD is used to determine the dynamic power dissipation (PD in µW): PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz fo = output frequency in MHz ∑ (CL × VCC2 × fo) = sum of outputs CL = output load capacitance in pF VCC = supply voltage in V 2. For HC the condition is VI = GND to VCC For HCT the condition is VI = GND to VCC −1.5 V ORDERING INFORMATION See “74HC/HCT/HCU/HCMOS Logic Package Information”. December 1990 2 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 PIN DESCRIPTION PIN NO. SYMBOL NAME AND FUNCTION 1, 2 OE1, OE2 output enable input (active LOW) 3, 4, 5, 6 Q0 to Q3 3-state flip-flop outputs 7 CP clock input (LOW-to-HIGH, edge-triggered) 8 GND ground (0 V) 9, 10 E1, E2 data enable inputs (active LOW) 14, 13, 12, 11 D0 to D3 data inputs 15 MR asynchronous master reset (active HIGH) 16 VCC positive supply voltage Fig.1 Pin configuration. December 1990 Fig.2 Logic symbol. 3 Fig.3 IEC logic symbol. Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 Fig.4 Functional diagram. FUNCTION TABLE INPUTS OUTPUTS REGISTER OPERATING MODES MR CP E1 E2 Dn Qn (register) reset (clear) H X X X X L parallel load L L ↑ ↑ l l l l l h L H hold (no change) L L X X h X X h X X qn qn INPUTS OUTPUTS 3-STATE BUFFER OPERATING MODES Qn (register) OE1 OE2 Q0 Q1 Q2 Q3 read L H L L L L L H L H L H L H disabled X X H X X H Z Z Z Z Z Z Z Z Notes 1. H = HIGH voltage level h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition L = LOW voltage level I = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition q = lower case letters indicate the state of the referenced input (or output) one set-up time prior to the LOW-to-HIGH CP transition X = don’t care Z = high impedance OFF-state ↑ = LOW-to-HIGH CP transition December 1990 4 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state Fig.5 Logic diagram. December 1990 5 74HC/HCT173 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 DC CHARACTERISTICS FOR 74HC For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: bus driver ICC category: MSI AC CHARACTERISTICS FOR 74HC GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 −40 to +85 −40 to +125 min. typ. max. min. max. min. UNIT V WAVEFORMS CC (V) max. tPHL/ tPLH propagation delay CP to Qn 55 20 16 175 35 30 220 44 37 265 53 45 ns 2.0 4.5 6.0 Fig.6 tPHL propagation delay MR to Qn 44 16 13 150 30 26 190 38 33 225 45 38 ns 2.0 4.5 6.0 Fig.7 tPZH/ tPZL 3-state output enable time OEn to Qn 52 19 15 150 30 26 190 38 33 225 45 38 ns 2.0 4.5 6.0 Fig.8 tPHZ/ tPLZ 3-state output disable time OEn to Qn 52 19 15 150 30 26 190 38 33 225 45 38 ns 2.0 4.5 6.0 Fig.8 tTHL/ tTLH output transition time 14 5 4 60 12 10 75 15 13 90 18 15 ns 2.0 4.5 6.0 Fig.6 tW clock pulse width HIGH or LOW 80 16 14 14 5 4 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig.6 tW master reset pulse width; HIGH 80 16 14 14 5 4 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig.7 trem removal time MR to CP 60 12 10 −8 −3 −2 75 15 13 90 18 15 ns 2.0 4.5 6.0 Fig.7 tsu set-up time En to CP 100 20 17 33 12 10 125 25 21 150 30 26 ns 2.0 4.5 6.0 Fig.9 tsu set-up time Dn to CP 60 12 10 17 6 5 75 15 13 90 18 15 ns 2.0 4.5 6.0 Fig.9 December 1990 6 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 −40 to +85 −40 to +125 min. typ. max. min. max. min. WAVEFORMS UNIT V CC (V) max. th hold time En to CP 0 0 0 −17 −6 −5 0 0 0 0 0 0 ns 2.0 4.5 6.0 Fig.9 th hold time Dn to CP 1 1 1 −11 −4 −3 1 1 1 1 1 1 ns 2.0 4.5 6.0 Fig.9 fmax maximum clock pulse frequency 6.0 30 35 26 80 95 4.8 24 28 4.0 20 24 MHz 2.0 4.5 6.0 Fig.6 December 1990 7 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 DC CHARACTERISTICS FOR 74HCT For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: bus driver ICC category: MSI Note to HCT types The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications. To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below. INPUT UNIT LOAD COEFFICIENT OE1, OE2 MR E1, E2 Dn CP 0.50 0.60 0.40 0.25 1.00 December 1990 8 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 AC CHARACTERISTICS FOR 74HCT GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER +25 −40 to +85 −40 to +125 UNIT V CC (V) WAVEFORMS min. typ. max. min. max. min. max. tPHL/ tPLH propagation delay CP to Qn 20 40 50 60 ns 4.5 Fig.6 tPHL propagation delay MR to Qn 20 37 46 56 ns 4.5 Fig.7 tPZH/ tPZL 3-state output enable time OEn to Qn 20 35 44 53 ns 4.5 Fig.8 tPHZ/ tPLZ 3-state output disable time OEn to Qn 19 30 38 45 ns 4.5 Fig.8 tTHL/ tTLH output transition time 5 12 15 19 ns 4.5 Fig.6 tW clock pulse width HIGH or LOW 16 7 20 24 ns 4.5 Fig.6 tW master reset pulse width; HIGH 15 6 19 22 ns 4.5 Fig.7 trem removal time MR to CP 12 −2 15 18 ns 4.5 Fig.7 tsu set-up time En to CP 22 13 28 33 ns 4.5 Fig.9 tsu set-up time Dn to CP 12 7 15 18 ns 4.5 Fig.9 th hold time En to CP 0 −6 0 0 ns 4.5 Fig.9 th hold time Dn to CP 0 −3 0 0 ns 4.5 Fig.9 fmax maximum clock pulse frequency 30 80 24 20 MHz 4.5 Fig.6 December 1990 9 Philips Semiconductors Product specification Quad D-type flip-flop; positive-edge trigger; 3-state 74HC/HCT173 AC WAVEFORMS (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.6 Fig.7 Waveforms showing the clock (CP) to output (Qn) propagation delays, the clock pulse width, the output transition times and the maximum clock pulse frequency. Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation delays and the master reset to clock (CP) removal time. The shaded areas indicate when the input is permitted to change for predictable output performance. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.9 Waveforms showing the data set-up and hold times from input (En, Dn) to clock (CP). (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.8 PACKAGE OUTLINES Waveforms showing the 3-state enable and disable times. December 1990 See “74HC/HCT/HCU/HCMOS Logic Package Outlines”. 10
74HCT173DB,118 价格&库存
很抱歉,暂时无法提供与“74HCT173DB,118”相匹配的价格&库存,您可以联系我们找货
