PMD1212PMB1-A(2).GN.IP55
    SUNON
    FANAXIAL120X38MM12VDC
PMD1212PMB1-A(2).GN.IP55 数据手册
*All products are RoHS compliant. DC Brushless Fan & Blower Research Center about Sunon Sunon was founded in 1980 and has always upheld the philosophy of “Brand, Innovation, and Value” for their business operations. From the start, the Sunon name has become an international trademark that is well recognized and featured on products sold worldwide. Over the years, Sunon has continuously focused on developing and making innovations for their core motor technology, leading the industry in product trends for motors, cooling fans, and cooling modules. Sunon is one of the few operations in the world with a motor R&D team and is fully capable of developing innovative new motor designs. Examples for the R&D efforts are the world’s first MagLev design and Sunon Mighty Mini series, featuring a compact sub-centimeter size that is the world’s smallest and thinnest fan. Today, Sunon is the worldwide leader in precision motors and micro miniature fans, and is widely recognized by the industry as the designated partner for various multinational corporations. Sunon products are widely used in various applications and industries such as information technology, network communications, optoelectronics, and automobile electronics industries, as well as in industrial production equipment, medical equipment, home applications, OA machines, and others. Sunon Research Center the Driving Engine for Inventions and Innovations Sunon established the “Sunon Research Center” in Kaohsiung in 2002 to promote and execute the innovation blueprint for Sunon Group. Research labs and engineers from Europe, America, Japan, and China are centralized to form a worldwide technological service network for quick and efficient services. Sunon Tripartite R&D Theory Motor Research Key Modules for Innovating Core Motor Technology Mo Ap tor Re plied sea rch Fan Motor Sunon has been researching their motor technology for over 30 years and adhering to the Sunon R&D Trinity as their innovation roadmap, focusing on the three major technology fields of “Motor Research,” “Motor Applied Research,” and “Total Thermal Solution.” Sunon strives to expand the endless possibilities and optimization of motor applications and will continue to make breakthroughs and product innovations. The efforts will push Sunon to the front of the technology curve and clients will be able to realize their future dream products with the three key Sunon products of motors, cooling fans, and cooling modules. Commercialization Sunon has the capacity to design and implement the complete magnetic, mechanical, and driving circuit of a motor to conform to client design specifications. With the efforts of the mechanism and electrical circuit engineering teams, Sunon recognizes the needs of their clients regarding cooling modules and can provide flexible designs for high performance and high quality cooling fans. Sunon utilizes advanced simulation systems and analysis projects that result in an even more accurate heat analysis and heat dissipation design for the system. Subsequently the most efficient total thermal solution can be provided to the client. 01 Motor Invention Applied material research Raw material development and evaluation tal To al erm Th tion lu Total thermal solution, So Simulation, Certification MagLev about Sunon MagLev The Sunon patented MagLev design is based on magnetic principles and forces that not only propel the fan but also ensure stable rotation over its entire 360 degrees of movement. Utilizing the attraction of the magnetic levitation force, MagLev eliminates the wobbling and shaking problems of traditional motor fans. With this new technology, the MagLev fan propeller is suspended in air during rotation so that the shaft and bearing do not come into direct contact with each other to create friction. These features result in a fan with low acoustic noise level, high-temeperature endurance, and longer lifespan. Comparison between MagLev and General Motor Fans (A) Sunon MagLev Fan stator stator magnet magnet maglev plate (B) General Fan the center of gravity is higher the center of gravity is lower 2 factors: the magnet and the stator Possesses 3 important factors: the maglev plate, the magnet and the stator The resulting interaction between the maglev plate and the magnet pulls the rotor downward along the entire 360-degree surface. Due to the lower center of gravity, the rotor runs in a more stable consistent orbit. The general fan utilizes a deviating magnetic center to attract the rotor downward. This technology causes the rotor to vibrate violently, due to the lack of a consistent orbit as well as a deviation of the magnetic center. SUNON MagLev prevents the defects of conventional fans Deficiencies of Sunon MagLev Solution Traditional Motors Sleeve Bearing Ball Bearing Weight of rotor is entirely loaded on to the shaft. Abrasive rotation between shaft and bearing will result in an irregular and rough surface on the inner surface of bearing bore. The fan motor rotation becomes uneven and in turn, causes operational noise and shortens fan life. The oil ring and mylar washer not only results in added friction area but also blocks the heated air, which, if not released before solidification, would become nitride particles that clog up in the gap between shaft and bearing bore, then causing a much slower rotation of rotor and noise. When the fan motor is operating, the steel balls inside will generate a higher rotational noise than that of a sleeve bearing. The construction of Ball bearings is quite weak and unable to absorb external impact. The bearings can be easily damaged, causing louder rotational noise. 02 The entire weight of the rotor is completely attracted by the magnetic force in any mounted position, keeping the motor rotating evenly at a fixed point in a consistent distance from the inner surface of the bearing. No more traditional rubs and noise will occur. The oil rings, the washers are no longer used in MagLev structure. For customized use, MagLev design allows an operating temperature higher than 700C. Sound Quality Sunon Sound Quality Analysis and Research Sunon introduced acoustics engineering in the year 2000 to transform the traditional school of Sound Pressure and Sound Power into the more advanced theory of Sound Quality. Sunon’s Sound Quality analysis and research is performed by Head Measurement System (HMS) . The HMS system records and simulates the auditory senses of the human ears, where the sounds, vibration, rotation speed, and electrical signals are measured. The software subsequently performs time domain and sound quality parameter analysis to assist the acoustics engineers in allowing Sunon products to feature a more favorable sound quality. The expertise and experience of the acoustics engineer combined with the software analysis will result in an even more user-friendly environment that is rivaled by none. Sound Quality Testing Sound quality is measured in an semi anechoic chamber by means of Head Measurement System (HMS) . The Sound quality of fans can be described according to the objective parameter of sound (Loudness, Tonality, Roughness/Fluctuation, Sharpness). After the recording of acoustic signals,the data is performed the FFT, order Psycho acoustic And modulation analyses and playback diagnosis in order to improve the sound quality of fans. Artificial Head 50cm 120cm Horizontal Line The mobile Sound Quality Laboratory SQlab II The Analysis Software It can analyze, filter, display and document acoustic and vibration measurement data in a wide range of modes. Yet an outstanding feature of this software is the possibility of including the aural sense of the human user in signal analysis. SQlab II is a compact, mobile multi-channel measurement system for acoustic analysis, vibration investigation and sound design. It is used wherever investigation of sound quality should be combined with vibrational measurements. HEADphone Playback System The comparison of vibrational measurements with acoustic signals enables the user to draw direct conclusions from sound sources and their sound quality. For this purpose, SQlab II is able to measure aurally-accurate recordings of sound events using an Artificial Head and vibration data with accelerometers, etc. at the same time. Thus, correlations between the subjective aural impressions of sound events (airborne sound) and the related sources (vibration, solid-borne sound) as well as transfer mechanisms become apparent. This is the basis for sound optimization. Moreover, SQlab II can be used as a "stethoscope" for error analysis. The digital 24 bit HEADphone Playback System HPS IV is complementary to the Head Measuring System HMS III. Conditioning of audio data for aurally-accurate playback is via equalization of the acoustic signal in the programmable Equalizer PEQ IV, with subsequent amplification via the Power Amplifier PVA IV.2. Two electrostatic headphones can be connected to the playback system, which are individually calibrated and correspondingly driven. 03 Total Thermal Solution Sunon Total Thermal Solution Sunon introduced its first chip cooling module in 1993, it has continued to rely on its impressive R&D team to also succeed in the laptop computer cooling module market. Sunon's innovative technology and superior design talent have consistently won customers' trust. In addition to Sunon's cutting-edge cooling fan products, it also offers laptop, VGA card, Desk Top, and server product designs. Sunon's cooling module product line ranges from low-end to high-end, enabling it the ability to provide customers with "Total Thermal Solutions." Sophisticated Tools Strengthen Design and Quality Apart from optimized design and superior R&D, we use infrared (IR) thermal imagers in module design work to make precise measurements of module temperatures, thereby avoiding the use of conventional thermocouples to measure temperatures. Our R&D personnel can instead rely on IR images to get a clear understanding of system temperature distribution. The data from our thermal imaging reports allow us to provide a clear system-wide thermal and cooling design analysis. In order to give customers the best quality guarantee, we go well beyond industry standards in production, assembly, inspection equipment design and deployment. We have also committed large amounts of manpower and material resources, and adopted the newest hardware and software equipment in our quest for quality. For instance, our thermal inspection systems can fully simulate thermal resistance measurements and pressure settings within systems and measure thermal resistance simultaneously at six different points. Precise measurements of pressure settings enable simulation of pressure within the system, making measurements even more accurate and protecting product quality by ensuring that excessive pressure doesn't cause product deformation. Furthermore, independent bar codes on each product ensure effective product tracking and improve the quality of after-sales service. We can satisfy our customers' needs for various types of customized cooling modules while meeting the highest quality requirements. Structural Simulation analysis Magnetization Simulation analysis Fluid dynamic analysis 3D model Thermal analysis IR thermograph inspect Advantage for Sunon Thermal Solutions Design Sunon thermal Solution Current thermal Solution Sunonmodule cooling module Dept. Dept. Sunon cooling OptimalDesign Designof ofOverall OverallProduct Product Optimal Customized thermal solutions Heat Sink + Fan Separated Separated Heat Sink Vender Heat Sink Vender Heat Sink Fan Fan Vendor Vendor Fan 04 Difficult to get total thermal solution Technology Fan 3rd Wire Signal Fan with switching driving circuit designed for rpm measurement: These fan motors have three lead wires: +:Red, -:Black, output signal for 3rd wire: F Type : Yellow R Type : White F Type (Frequency Generator) 1Pulse a R Type (Rotation Detector) 1Rotation b c Locked Run Vcc Vcc DC FAN Red(+) Ic RL 3 rd wire Black(-) Locked Run Customer's Circuit Vcc The relationship between rotation & output pulses signal from 3rd wire are as follows: (a) 1 Rotation=2 Pulses(4 poles' motor) (b) 1 Rotation=3 Pulses(6 poles' motor) (c) 1 Rotation=4 Pulses(8 poles' motor) DC FAN Red(+) Ic RL 3 rd wire Black(-) Notice: For 8 poles' motor: normally, 1Rotation=4 pulses, if frequency divided circuit is implemented in this motor then 1Rotation=2 pulses. Customer's Circuit 05 Production Netwok Sunon Reliability Verification System Sunon has 5 reliability testing labs worldwide equipped with the topmost precision verification instruments for testing from the design phase, through pre-production, and into mass production. The complete verification system is computerized and fully automated for precise analysis of product reliability and quality satisfaction to meet the market requirements. Sunon Production Network All Sunon products are RoHS compliant from design phase to mass production. Sunon is the long-term green partner for SONY, CANON, SAMSUNG and various other multinational companies Sunon Group has a total of three manufacturing plants located in both China and Taiwan for production of 8mm~250mm series of fan products, 0.1Watt~60Watt of motor products, and various cooling module products. The overall monthly production output capacity is 16 million units. Sunon deeply recognizes its corporate duty to protect our earth and the ecosystem and to reduce the use of materials that impact the environment. In light of this, Sunon has been actively promoting green product design, green purchasing, and green manufacturing reforms. All current product series conform to EU RoHS and China RoHS, and Sunon has been selected as the green environment partner for multinational corporations such as SONY, CANON, and SAMSUNG. All of the aforementioned efforts will result in greener products that have the least impact on the worldwide environment. In addition to the MES system that provides clients with the best manufacturing quality, Sunon goes well beyond industry standards in production, assembly, inspection equipment design and deployment. Sunon has also committed large amounts of manpower and material resources, and adopted the newest hardware and software equipment, in our quest for quality. For example, an automated production line for cooling products, the self-developed automated inspection machine for the production line, a heat inspection system capable of six simultaneous measurements, and an independent barcode with each cooling product indicate Sunon’s commitment. For improving the quality management system and regulations of hazardous materials contained in the products, Sunon further introduces the IECQ QC080000 to their product production. This will complete the approval and certification process for usage of hazardous materials and the reduction management system, thereby setting up a green quality management system that conforms to international standards for the benefit of Sunon and their partners. Sunon manufacturing bases have obtained certifications for QS9000, ISO9001, ISO14001, ISO/TS16949, and OHSAS18001. Each product has passed UL, TUV, VDE, CCC, CSA certifications and so on. Kun Shan Kun Shan plant CHINA Headquarters Foshan plant TAIWAN Foshan Kaohsiung Kaohsiung plant I Kaohsiung Plant II 06 Contents Page p01 p02 p03 p04 p05 p06 p07 p08 p09 Sunon research center Sunon MagLev Sunon Sound quality Sunon total thermal solution Sunon fan 3rd wire signal Sunon Production Network Content DC Fan & Blower Model Numbering System New DC Fan & Blower Model Numbering Systemn / Certification & Safety DC Fan NEW NEW NEW NEW NEW NEW Size (mm) Air Flow (CFM) Page 17x17x8 20x20x8 20x20x10 25x25x6 25x25x10 25x25x15 30x30x6 30x30x10 30x30x15 35x35x6 35x35x10 38x38x20 38x38x28 40x40x6 40x40x10 40x40x15 40x40x20 40x40x20 40x40x24 40x40x28 40x40x56 45x45x10 50x50x10 50x50x15 55x55x15 60x60x15 60x60x20 0.7~0.9 1.3~1.6 1.5~1.9 2.2~3.0 3.0~3.5 2.2~3.1 3.7~4.9 4.6~5.5 4.8~6.0 4.3~5.5 6.5~7.0 10.6~13.5 12.6~19.0 5.5~5.9 7.0~8.0 14 6.3~10.8 6.3~10.8 21.6 23.4 26.7 9.2~11.0 11~13 10.2~17 21.1 15~21 27.5~30.5 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 Air Flow (CFM) Page p64 p65 p66 p67 p68 Size (mm) NEW NEW NEW NEW NEW NEW NEW NEW NEW 60x60x20 60x60x25 60x60x25 60x60x38 60x60x60 70x70x15 70x70x20 70x70x20 70x70x25 70x70x25 80x80x15 80x80x20 80x80x20 80x80x25 80x80x25 80x80x25 80x80x32 80x80x38 92x92x25 92x92x25 92x92x25 92x92x32 92x92x38 120x120x25 120x120x25 120x120x38 120x120x38 Air Flow (CFM) Page 19~25.5 29~40 19.3~27 41.5~56.5 67 19~27 37~43 23.5~29 40~49 24~32.5 32~40 45~53 29~39 49~60 53~60 33~45 61.9 59.5~84.1 65~77 65~75 39.5~55 79 91.7~120.2 120~150 75~108.2 153~190 93~138 p37 p38 p39 p40 p41 p42 p43 p44 p45 p46 p47 p48 p49 p50 p51 p52 p53 p54 p55 p56 p57 p58 p59 p60 p61 p62 p63 Air Flow (CFM) Page p69 p70 p71 p72 DC Blower Size (mm) NEW NEW 35x35x7 45x45x20 50x50x15 50x50x20 60x60x15 0.9 4.6 2.3~4.7 4.8~5.7 3.5~5.2 Size (mm) NEW 07 60x60x25 75x75x30 97x94x33 120x120x32 7.3 7.5~13.6 22.4~30.5 31.4~35.9 DC Fan & Blower Model Numbering System GM 05 02 P F V 1- -- 8Motor Poles 8: 8 Poles 6: 6 Poles Blank: 4 Poles Speed X: Super 3: Low 1: High 4: Extra Low 2: Middle Bearing System V: Vapo B: Ball Frame Thickness E: 6mm B: 24mm D: 8mm T: 25mm F: 10mm Q: 28mm G: 12mm N: 30mm H: 15mm L: 32mm K: 20mm Y: 33mm Frame Material P: PBT Plastic A: Aluminum I: 35mm M: 38mm O: 40mm P: 56mm W: 60mm Frame Size 17:17mm 38:38mm 06:60mm 01:20mm 04:40mm 07:70mm 02:25mm 45:45mm 75:75mm 03:30mm 05:50mm 08:80mm 35:35mm 55:55mm 09:92mm Voltage 05:5VDC 12:12VDC 24:24VDC 48:48VDC Fan Series GM Series PMD Series GB Series PSD Series KD Series PMB Series KDE Series P/N Example: PMD1206PTVX P/N:U.GN 11/13 MS (2) G (9) N A F R U GN X Z Motor model MagLev Design Two ball bearing Big hub 9 Blades Smaller hub Auto restart 3rd wire with frequency generation waveform 3rd wire with rotation detector waveform Upgrade RoHS compliance UV Glue Specific RPM 08 97:97mm 12:120mm New Model Numbering System M- E 80 25 1 V 1 0000 999 Function Code 999: standard model A99: AutoRestart C99: F type (3rd wire) D99: with PWM H99: AutoRestart and with PWM Q99: AutoRestart , R type and with PWM S99: AutoRestart , F type and with PWM Customer Code 0000 stand for standard model Speed X:Super High 3: Low 4: Super Low 1: High 2: Medium Bearing V: Vapo B: 2 Ball S: Sleeve Voltage 0: 5VDC 1: 12VDC 2: 24VDC 3: 36VDC 4: 48VDC Fan Thickness 0~9; A~Z (except O) Frame Size 0~9; A~Z (except O) Motor Type Series Code E Series M Series Code 01~09 10~19 20~29 30~39 40~49 50~59 60~69 70~79 80~89 90~99 Size(mm) 01~09 10~19 20~29 30~39 40~49 50~59 60~69 70~79 80~89 90~99 Code A0~A9 B0~B9 C0~C9 D0~D9 E0~E9 F0~F9 G0~G9 H0~H9 I0~I9 J0~J0 Size(mm) Code 100~109 110~119 120~129 130~139 140~149 150~159 160~169 170~179 180~189 190~199 K0~K9 L0~L9 M0~M9 N0~N9 P0~P9 Q0~Q9 R0~R9 S0~S9 T0~T9 U0~U9 Certification Size(mm) 200~209 210~219 220~229 230~239 240~249 250~259 260~269 270~279 280~289 290~299 P Series Code V0~V9 W0~W9 X0~X9 Y0~Y9 Z0~Z9 Size(mm) 300~309 310~319 320~329 330~339 340~349 Safety * Note: For critical or extreme environments, including non stop operation, please contact Sunon and we will gladly provide assistance with your product selection to ensure an appropriate cooling product for your application. * Note: The “Life Expectancy” of the fan has not been evaluated for use in combination with any end application. Therefore, the Life Expectancy Test Reports(L10 and MTTF Report) that relate to the fan are only for reference. 09 17x17x8 mm 0.7~0.9 CFM P/N Bearing VAPO GM0517PDV1-8 GM0517PDV2-8 Rating Voltage (VDC) 5 5 GN GN Power Current Power Consumption (AMP) Weight Speed Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.8 0.6 20000 15000 0.9 0.7 0.28 0.17 25 16 4.36 4.36 0.16 0.11 1 2 INLET UL1571,#28AWG 1 16.5 0.25 0.2 0.1 0.05 13.5 +- 0.3 3- OUTLET 17 +- 0.5 13.5 +- 0.3 150 +- 30 2 0.15 5 +- 0.3 Static Pressure (Inch-H2O) 0.3 2 8 +- 0.5 0 16.4 17 +- 0.5 0 0.25 0.5 0.75 1 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 10 Curve 20x20x8 mm 1.3~1.6 CFM P/N Bearing VAPO GM0501PDV1-8 GM0501PDV2-8 Rating Voltage (VDC) 5 5 GN GN Power Current Power Consumption (AMP) 0.17 0.11 Weight Speed Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.9 0.6 15000 12000 1.6 1.3 0.22 0.15 23 21 4.64 4.64 INLET UL1571,#28AWG 19 .1 0.2 1 0.15 2 150 +- 30 0.1 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) 0.25 19 .1 0.05 316.2 +- 0.3 2. 5 8 +- 0.5 0 20 +- 0.5 0 0 0.5 1 1.5 2 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 11 Curve 1 2 20x20x10 mm 1.5~1.9 CFM P/N Bearing VAPO GM0501PFV1-8 GM0501PFV2-8 Rating Voltage (VDC) 5 5 N.GN N.GN Power Current Power Consumption (AMP) Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 1.1 0.9 17000 14000 1.9 1.5 0.29 0.20 25 20 5.5 5.5 0.21 0.18 INLET 0.3 UL1571,#28AWG 19 .1 1 0.25 3- 2.5 150 +- 30 2 0.15 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) 0.35 0.2 0.1 19 0.05 0 Weight Speed 16.2 +- 0.3 20 +- 0.5 0.5 1 1.5 2 10+- 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 12 Curve 1 2 25x25x6 mm 2.2~3.0 CFM P/N Bearing VAPO GM0502PEV1-8 GM0502PEV2-8 Rating Voltage (VDC) 5 5 N.GN N.GN Speed Air Flow Static Pressure Noise Weight (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.6 0.4 13000 10000 3.0 2.2 0.22 0.16 31 23 5 5 Power Current Power Consumption (AMP) 0.11 0.08 0.24 23 UL3265,#28AWG 0.21 .6 1 3- 2.8 0.18 2 150 +- 30 0.15 0.12 0.09 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.06 23 20 +- 0.3 0.03 6.9 +- 0 0.5 .4 25 +- 0.5 0 1 2 3 4 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 13 Curve 1 2 25x25x10 mm 3.0~3.5 CFM P/N Bearing VAPO GM0502PFV1-8 GM0502PFV2-8 GM1202PFV1-8 GM1202PFV2-8 GN GN GN GN Rating Voltage Power Current Power Consumption (VDC) (AMP) 5 5 12 12 0.12 0.08 0.067 0.038 Weight Speed Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.6 0.4 0.8 0.5 13000 10000 13000 10000 3.5 3.0 3.5 3.0 0.25 0.18 0.25 0.18 23 16 23 16 7.5 7.5 7.5 7.5 0.27 0.24 23 UL1571,#28AWG .4 1 3- 2.8 0.21 2 150 +- 30 0.18 0.15 OUTLET 0.12 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.09 24 0.06 20 +- 0.3 25 +- 0.5 0.03 10+- 0.5 0 0 1 2 3 4 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 14 Curve 1 2 1 2 25x25x15 mm 2.2~3.1 CFM P/N Bearing VAPO GM0502PHV1-8 GM0502PHV2-8 GM1202PHV1-8 GM1202PHV2-8 GN GN GN GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) 5 5 12 12 0.11 0.08 0.048 0.029 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.6 0.4 0.6 0.4 10000 7000 10000 7000 3.1 2.2 3.1 2.2 0.16 0.11 0.16 0.11 20 14 20 14 11 11 11 11 Curve 1 2 1 2 0.18 AIR FLOW 2. R 8 1 .5 24 O TAT I O N 3- 0.15 UL1571,#28AWG 0.12 20 +- 0.3 25 +- 0.5 150 +- 20 2 0.09 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.06 15 +- 0.5 0 0.03 0 1 2 3 ( Units : mm ) 4 Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 15 .5 24 30x30x6 mm 3.7~4.9 CFM P/N Rating Voltage Bearing VAPO GM0503PEV1-8 GM0503PEV2-8 (VDC) 5 5 N.GN N.GN Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.7 0.4 9500 7500 4.9 3.7 0.14 0.09 28 24 6 6 0.13 0.08 0.15 UL3265,#28AWG 28 .3 1 3- 3.2 0.09 150 +- 30 0.12 2 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.06 OUTLET 0.03 24 +- 0.3 6.9+- 0 0.5 28 .9 30 +- 0.5 0 1 2 3 4 5 6 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 16 Curve 1 2 30x30x10 mm 4.6~5.5 CFM P/N Rating Voltage Bearing VAPO GM0503PFV1-8 GM0503PFV2-8 GM1203PFV1-8 GM1203PFV2-8 GN GN GN GN Weight Power Current Power Consumption Speed Air Flow Static Pressure Noise (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 12 12 0.14 0.10 0.078 0.042 0.7 0.5 1.0 0.5 9500 8000 9500 8000 5.5 4.6 5.5 4.6 0.15 0.12 0.15 0.12 23 20 23 20 8.6 8.6 8.5 8.5 0.18 28 .4 UL1571,#28AWG 0.15 1 0.12 2 150 +- 30 3- 3.2 0.09 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.06 29 0.03 24 +- 0.3 30 +- 0.5 10 +- 0.5 0 0 1 2 3 4 5 6 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 17 Curve 1 2 1 2 30x30x15 mm 4.8~6.0 CFM P/N Bearing VAPO GM0503PHV1-8 GM0503PHV2-8 GM1203PHV1-8 GM1203PHV2-8 GN GN GN GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 12 12 0.11 0.07 0.054 0.029 0.6 0.4 0.6 0.4 8500 7000 8500 7000 6.0 4.8 6.0 4.8 0.17 0.12 0.17 0.12 27 20 27 20 13.5 13.5 13.2 13.2 0.18 28 UL1571,#28AWG 0.15 3- 3.2 2 150 +- 30 0.12 .4 1 0.09 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.06 0.03 24 +- 0.3 30 +- 0.5 15 +- 0.5 0 29 0 1 2 3 4 5 6 7 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 18 Curve 1 2 1 2 35x35x6 mm 4.3~5.5 CFM P/N Bearing VAPO GM0535PEV1-8 GM0535PEV2-8 N.GN N.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 0.14 0.09 0.7 0.5 7600 5800 5.5 4.3 0.08 0.06 26 19 7 7 0.08 UL3265,#28AWG 33 .3 3- 3.2 0.06 0.04 150 +- 30 1 2 5 +- 0.3 Static Pressure (Inch-H2O) INLET OUTLET 0.02 29 +- 0.3 35 +- 0.5 6.9+- 0 0.5 32 .8 0 0 1 2 3 4 5 6 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 19 Curve 1 2 35x35x10 mm 6.5~7.0 CFM P/N Rating Voltage Bearing VAPO GM0535PFV1-8 GM0535PFV2-8 GM1235PFV1-8 GM1235PFV2-8 GN GN GN GN Weight Power Current Power Consumption Speed Air Flow Static Pressure Noise (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 12 12 0.15 0.10 0.08 0.043 0.8 0.5 1.0 0.5 9500 7500 9500 7500 7.0 6.5 7.0 6.5 0.18 0.12 0.18 0.12 28 22 28 22 10.5 10.5 10.5 10.5 0.18 UL1571,#28AWG 33 .5 0.15 3- 3.2 0.12 150 +- 30 1 0.09 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.06 2 0.03 29 +- 0.3 10 +- 0.5 0 33 .2 35 +- 0.5 0 1 2 3 4 5 6 7 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 20 Curve 1 2 1 2 38x38x20 mm 10.6~13.5 CFM P/N Bearing VAPO PMD1238PKBX-A PMD1238PKB1-A PMD1238PKB2-A (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption (VDC) (AMP) (WATTS) 12 12 12 0.36 0.26 0.21 4.3 3.1 2.5 Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 15000 13000 11000 13.5 12.0 10.6 0.82 0.61 0.45 48.0 44.0 39.0 27 27 27 Speed Curve 1 2 3 INLET .6 36 0.8 ATI ROT ON UL2468,#26AWG 0.7 4 4- 1 3. 2 0.4 3 30 +- 0.3 300 +- 50 0.5 38 +- 0.5 0.6 5 +- 0.3 Static Pressure (Inch-H2O) 0.9 OUTLET 0.3 35 0.2 30 +- 0.3 38 +- 0.5 0.1 0 5 10 15 2.8 +- 0.3 20 +- 0.3 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 21 38x38x28 mm 12.6~19.0 CFM P/N Bearing VAPO PMD1238PQBX-A PMD1238PQB1-A PMD1238PQB2-A (2).GN (2).GN (2).GN Rating Voltage (VDC) 12 12 12 Power Current Power Consumption (AMP) 0.48 0.30 0.19 Weight Speed Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5.8 3.6 2.3 15000 13000 10000 19.0 16.5 12.6 1.20 0.91 0.55 52.0 47.0 42.0 35.2 35.2 35.2 Curve 1 2 3 INLET .4 36 1 1 UL2468,#26AWG 5 4- 3. 0.8 0.4 30 +- 0.3 38 +- 0.5 300 +- 50 2 0.6 5 +- 0.3 Static Pressure (Inch-H2O) 1.2 OUTLET 3 .2 36 0.2 0 0 5 10 15 20 30 +- 0.3 3 +- 0.3 38 +- 0.5 28 +- 0.3 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 22 40x40x6 mm 5.5~5.9 CFM P/N Rating Voltage Bearing VAPO GM0504PEV1-8 GM0504PEV2-8 (VDC) 5 5 GN GN Weight Power Current Power Consumption Speed Air Flow Static Pressure Noise (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.5 0.4 7000 6000 5.9 5.5 0.10 0.08 32 26 7.5 7.5 0.09 0.07 0.12 38 1 .6 UL3265,#28AWG 4- 3.4 0.09 2 150 +- 30 0.06 OUTLET 5 +- 0.3 Static Pressure (Inch-H2O) INLET 0.03 32 +- 0.3 40 +- 0.5 0 1 2 3 4 5 6 7 2 +- 0.3 6.9+- 0 0.5 38 .3 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 23 Curve 1 2 40x40x10 mm 7.0~8.0 CFM P/N Bearing VAPO KDE0504PFV1 KDE0504PFV2 KDE1204PFV1 KDE1204PFV2 11.MS.A.GN 11.MS.A.GN 11.MS.A.GN 11.MS.A.GN Model P/N KD0504PFS1 KD0504PFS2 KD1204PFS1 KD1204PFS2 11.GN 11.GN 11.GN 11.GN 2BALL Sleeve Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 12 12 0.24 0.14 0.09 0.08 1.2 0.7 1.1 1.0 7000 5800 7000 5800 8.0 7.0 8.0 7.0 0.19 0.13 0.19 0.13 32 27 32 27 17 17 17 17 1 2 1 2 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 5 5 12 12 0.26 0.161 0.106 0.092 1.3 0.8 1.3 1.1 7000 5800 7000 5800 8.0 7.0 8.0 7.0 0.19 0.13 0.19 0.13 32 27 32 27 17 17 17 17 1 2 1 2 *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 24 Curve 40x40x15 mm NEW 14 CFM Model P/N Bearing 2BALL Sleeve PSD1204PHB1-A PSD1204PHB1-A PSD1204PHB1-A (2).Z.GN (2).Z.F.PWM.GN (2).Z.R.PWM.GN Rating Voltage Power Current Power Consumption (VDC) (AMP) 12 12 12 0.24 0.24 0.24 Weight Speed Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 2.9 2.9 2.9 12000 12000 12000 14 14 14 0.63 0.63 0.63 44.2 44.2 44.2 25.85 25.85 25.85 Curve 1 1 1 INLET 8.2 Ø3 0.7 0.6 4-Ø ROT 3.4± AIR FLOW A T I ON 0.3 SUNON 32±0.3 0.4 40±0.5 0.5 OUTLET 0.3 Ø3 UL1571 #28AWG 0.2 15 +0.5 -0 5±0.3 150±20 0.1 0 0 3 6 9 12 15 *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 25 8 40x40x20 mm 6.3~10.8 CFM P/N Bearing VAPO KDE0504PKV1 KDE0504PKV2 KDE0504PKV3 KDE1204PKVX KDE1204PKV1 KDE1204PKV2 KDE1204PKV3 KDE2404PKVX KDE2404PKV1 KDE2404PKV2 MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 5 12 12 12 12 24 24 24 0.19 0.12 0.08 0.12 0.07 0.05 0.03 0.064 0.05 0.033 1.1 0.6 0.4 1.4 0.8 0.6 0.4 1.5 1.2 0.8 7200 6200 5200 8200 7200 6200 5200 8200 7200 6200 8.9 7.7 6.3 10.8 8.9 7.7 6.3 10.8 8.9 7.7 0.21 0.16 0.11 0.27 0.21 0.16 0.11 0.27 0.21 0.16 25.5 21.0 18.0 27.5 25.5 21.0 18.0 27.5 25.5 21.0 30 30 30 31 31 31 31 31 31 31 Curve 2 3 4 1 2 3 4 1 2 3 INLET ROT 0.25 AT I O N 6 39. 300±50 1 5±0.3 UL1007 #26AWG AIR FLOW 0.2 2 0.15 32±0.3 3 0.1 40±0.5 Static Pressure (Inch-H2O) 0.3 OUTLET 4 7 39. 0.05 4- 0.3 .3± 4 20 0.5 0 0 0 2 4 6 8 10 12 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 26 40x40x20 mm 6.3~10.8 CFM Model P/N Bearing 2BALL Sleeve KD0504PKB1 KD0504PKB2 KD0504PKB3 KD0504PKS1 KD0504PKS2 KD0504PKS3 KD1204PKBX KD1204PKB1 KD1204PKB2 KD1204PKB3 KD2404PKSX KD2404PKS1 KD2404PKS2 (2).GN (2).GN (2).GN GN GN GN (2).GN (2).GN (2).GN (2).GN GN GN GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 5 5 5 5 12 12 12 12 24 24 24 0.223 0.142 0.091 0.218 0.14 0.09 0.124 0.08 0.062 0.044 0.12 0.08 0.063 1.1 0.7 0.5 1.1 0.7 0.5 1.5 1.0 0.7 0.5 1.4 1.0 0.8 7200 6200 5200 7200 6200 5200 8200 7200 6200 5200 8200 7200 6200 8.9 7.7 6.3 8.9 7.7 6.3 10.8 8.9 7.7 6.3 10.8 8.9 7.7 0.21 0.16 0.11 0.21 0.16 0.11 0.27 0.21 0.16 0.11 0.27 0.21 0.16 26.5 22.0 19.0 25.5 21.0 18.0 28.5 26.5 22.0 19.0 27.5 25.5 21.0 30 30 30 30 30 30 31 31 31 31 31 31 31 Curve 2 3 4 2 3 4 1 2 3 4 1 2 3 INLET ROT 0.25 AT I O N 6 39. 300ɲ50 1 5ɲ0.3 UL1007 #26AWG AIR FLOW 0.2 2 0.15 Ĵijɲ0.3 3 0.1 ĵıɲ0.5 Static Pressure (Inch-H2O) 0.3 OUTLET 4 7 39. 0.05 4- .3 ɲ0 4.3 ijı ıįĶ ı 0 0 2 4 6 8 10 12 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 27 40x40x24 mm NEW 21.6 CFM Model P/N Bearing 2BALL Sleeve PSD1204PBB1-A PSD1204PBB1-A PSD1204PBB1-A (2).Z.GN (2).Z.F.PWM.GN (2).Z.R.PWM.GN Rating Voltage Power Current Power Consumption (VDC) (AMP) (WATTS) 12 12 12 0.5 0.5 0.5 6.0 6.0 6.0 Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 14700 14700 14700 21.6 21.6 21.6 1.23 1.23 1.23 Speed ROT A T I ON 4-Ø 3.5± 55.7 55.7 55.7 Curve 80 80 80 1 1 1 0.3 32±0.3 Ø3 4.7 4 1.5 32±0.3 40±0.5 0.9 24±0.5 1.2 AIR FLOW UL1571 #28AWG OUTLET Ø3 1 4.5 150±20 0.6 0.3 5±0.3 Static Pressure (Inch-H2O) 40±0.5 INLET 0 0 5 10 15 20 25 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 28 6 40x40x28 mm NEW 23.4 CFM Model P/N Bearing 2BALL Sleeve PSD1204PQBX-A (2).Z.GN PSD1204PQBX-A (2).Z.F.PWM.GN PSD1204PQBX-A (2).Z.R.PWM.GN Rating Voltage Power Current Power Consumption (VDC) (AMP) (WATTS) 12 12 12 0.75 0.75 0.75 9.0 9.0 9.0 Speed (RPM) 19000 19000 19000 Air Flow Static Pressure Noise Weight (CFM) (Inch-H2O) (dBA) (g) 23.4 23.4 23.4 2.01 2.01 2.01 59.9 59.9 59.9 Curve 43 43 43 1 1 1 INLET 8.6 8-Ø 3.6 2.5 ROT ±0 AIR FLOW A T I ON .3 SUNON 1.5 32±0.3 2 40±0.5 Static Pressure (Inch-H2O) Ø3 1 OUTLET 1 28±0.3 5±0.3 UL1571 #28AWG 150±20 0.5 0 0 5 10 15 20 25 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 29 Ø3 8.4 40x40x56 mm NEW 26.7 CFM Model P/N Bearing 2BALL Sleeve PMD1204PPBX-A (2).Z.GN PMD1204PPBX-A (2).Z.F.PWM.GN PMD1204PPBX-A (2).Z.R.PWM.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) 12 12 12 1.09 1.09 1.09 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 13.1 13.1 13.1 17600/13500 17600/13500 17600/13500 26.7 26.7 26.7 2.33 2.33 2.33 8- 66.6 66.6 66.6 Curve 86 86 86 1 1 1 Ø 3. 5± 0. 3 ROT A T I ON 8.6 Ø3 1 FAN2 1.5 56±0.5 28±0.3 2 UL1571 #28AWG 150±20 5±0.3 28±0.3 FAN1 AIR FLOW 2.5 OUTLET 8.4 Ø3 1 40±0.5 32±0.3 Static Pressure (Inch-H2O) 40±0.5 32±0.3 INLET 0.5 32±0.3 40±0.5 0 0 5 10 15 20 25 30 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 30 45x45x10 mm 9.2~11 CFM P/N Bearing VAPO KDE0545PFV1 KDE0545PFV2 KDE1245PFV1 KDE1245PFV2 11.MS.A.GN 11.MS.A.GN 11.MS.A.GN 11.MS.A.GN Model P/N KD0545PFS1 KD0545PFS2 KD1245PFS1 KD1245PFS2 2BALL Sleeve Rating Voltage Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 5 5 12 12 0.25 0.15 0.10 0.08 1.3 0.8 1.2 1.0 (VDC) (AMP) (WATTS) 1.4 0.9 1.4 1.2 5 5 12 12 11.GN 11.GN 11.GN 11.GN 0.279 0.172 0.114 0.097 Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 6000 5000 6000 5000 11.0 9.2 11.0 9.2 0.17 0.12 0.17 0.12 32 27 32 27 (RPM) (CFM) (Inch-H2O) (dBA) 6000 5000 6000 5000 11.0 9.2 11.0 9.2 0.17 0.12 0.17 0.12 32 27 32 27 Curve 19.0 19.0 18.5 18.5 (g) 1 2 1 2 Curve 19.0 19.0 18.5 18.5 1 2 1 2 INLET AIR FLOW T ROTA ION 4- 4.3 0.2 1 0.16 0.12 37±0.3 45±0.5 Static Pressure (Inch-H2O) .85 45 0.24 2 OUTLET 0.5 10 0 0.08 5±0.3 300±50 UL2468 #26AWG 0.04 0 2 4 6 8 10 12 14 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 31 .6 46 50x50x10 mm 11~13 CFM P/N Bearing Rating Voltage Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 5 5 12 12 0.27 0.16 0.11 0.09 1.4 0.8 1.3 1.1 (VDC) (AMP) (WATTS) 1.5 0.9 1.4 1.2 VAPO KDE0505PFV1 KDE0505PFV2 KDE1205PFV1 KDE1205PFV2 11.MS.A.GN 11.MS.A.GN 11.MS.A.GN 11.MS.A.GN Model P/N KD0505PFS1 KD0505PFS2 KD1205PFS1 KD1205PFS2 2BALL Sleeve 5 5 12 12 11.GN 11.GN 11.GN 11.GN 0.297 0.181 0.12 0.104 Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 5200 4300 5200 4300 13.0 11.0 13.0 11.0 0.14 0.11 0.14 0.11 30 26 30 26 21 21 20 20 1 2 1 2 (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 5200 4300 5200 4300 13.0 11.0 13.0 11.0 0.14 0.11 0.14 0.11 30 26 30 26 21 21 20 20 1 2 1 2 Curve INLET .62 ROTATION AIR FLOW 4- 4.3 0.16 1 UL2468 #26AWG 0.12 2 OUTLET 300±50 0.08 0.04 0 2 4 6 8 10 12 14 16 5±0.3 Static Pressure (Inch-H2O) 51 0.2 40±0.3 50±0.5 10 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 32 .64 51 50x50x15 mm NEW 10.2~17 CFM P/N Bearing VAPO KDE0505PHV2 KDE0505PHV3 KDE1205PHV1 KDE1205PHV2 KDE1205PHV3 KDE2405PHV1 KDE2405PHV2 MS.A.GN.C1500 MS.A.GN.C1500 MS.A.GN.C1500 MS.A.GN.C1500 MS.A.GN.C1500 MS.A.GN.C1500 MS.A.GN.C1500 Model P/N (2).GN.C1500 (2).GN.C1500 (2).GN.C1500 (2).GN.C1500 (2).GN.C1500 (2).GN.C1500 (2).GN.C1500 GN.C1500 GN.C1500 GN.C1500 GN.C1500 GN.C1500 GN.C1500 GN.C1500 KD0505PHB2 KD0505PHB3 KD1205PHB1 KD1205PHB2 KD1205PHB3 KD2405PHB1 KD2405PHB2 KD0505PHS2 KD0505PHS3 KD1205PHS1 KD1205PHS2 KD1205PHS3 KD2405PHS1 KD2405PHS2 Rating Voltage Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 0.8 0.5 1.0 0.7 0.5 1.5 1.0 (WATTS) 0.8 0.5 1.5 1.0 0.7 1.9 1.3 0.9 0.5 1.6 0.9 0.7 1.8 1.3 5 5 12 12 12 24 24 2BALL Sleeve (VDC) 5 5 12 12 12 24 24 5 5 12 12 12 24 24 0.146 0.09 0.087 0.054 0.035 0.063 0.042 (AMP) 0.161 0.102 0.127 0.081 0.055 0.08 0.054 0.169 0.105 0.129 0.078 0.055 0.076 0.053 Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 4700 3700 5800 4700 3700 5800 4700 13.0 10.2 17.0 13.0 10.2 17.0 13.0 0.17 0.12 0.23 0.17 0.12 0.23 0.17 29 22 33 29 22 33 29 39 39 38 38 38 39 39 2 3 1 2 3 1 2 (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 4700 3700 5800 4700 3700 5800 4700 4700 3700 5800 4700 3700 5800 4700 13.0 10.2 17.0 13.0 10.2 17.0 13.0 13.0 10.2 17.0 13.0 10.2 17.0 13.0 0.17 0.12 0.23 0.17 0.12 0.23 0.17 0.17 0.12 0.23 0.17 0.12 0.23 0.17 30 23 33 29 22 33 29 29 22 34 30 23 34 30 39 39 38 38 38 39 39 39 39 38 38 38 39 39 2 3 1 2 3 1 2 2 3 1 2 3 1 2 Curve INLET 54 ROT A T I ON 0.3 .3± AIR FLOW Ø4 4- 0.2 0.15 2 40±0.3 1 50±0.5 Static Pressure (Inch-H2O) 0.25 SUNON OUTLET 0.1 49 3 15.4±0.3 0.05 0 5±0.3 UL2468 #26AWG 0 5 10 15 20 300±50 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 33 55x55x15 mm NEW 21.1 CFM P/N Bearing VAPO GM1255PHV1-A 13.Z.X.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) 12 0.13 1.6 (RPM) (CFM) (Inch-H2O) (dBA) (g) 6400 21.1 0.25 39.8 29 1 6.1 Ø5 8- Ø ROT 4. 3± 0.25 A T I ON 0. 3 0.2 SUNON 0.15 45±0.3 55±0.5 55.5±0.5 Static Pressure (Inch-H2O) INLET 0.3 OUTLET 1 7.4 Ø5 0.1 UL1571 #28AWG 150±20 5±0.3 15+0.5 -0 0.05 0 0 5 10 15 20 25 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 34 Curve KD0506PHB2 KD0506PHB3 KD1206PHB1 KD1206PHB2 KD1206PHB3 (2).GN (2).GN GN GN (2).GN (2).GN (2).GN 5 5 5 5 12 12 12 0.195 0.119 1.0 0.6 0.154 0.094 0.062 1.9 1.1 0.7 3800 3000 3800 3000 4300 3800 3000 18 15 18 15 21 18 15 0.14 0.12 0.14 0.12 0.18 0.14 0.12 32 26 37 32 23 44 44 44 44 42 42 42 2 3 2 3 1 2 3 60x60x20 mm 27.5~30.5 CFM P/N Bearing VAPO PMD1206PKVX-A PMD1206PKV1-A PMD2406PKVX-A PMD2406PKV1-A Model GN GN GN GN 2BALL Sleeve P/N PMD1206PKBX-A PMD1206PKB1-A PMD2406PKBX-A PMD2406PKB1-A (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) 12 12 24 24 0.275 0.228 0.157 0.125 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 3.3 2.7 3.8 3.0 5500 5000 5500 5000 30.5 27.5 30.5 27.5 0.35 0.28 0.35 0.28 40 38 40 38 55 55 55 55 1 2 1 2 (VDC) (AMP) 12 12 24 24 0.274 0.22 0.151 0.122 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 3.3 2.6 3.6 2.9 5500 5000 5500 5000 30.5 27.5 30.5 27.5 0.35 0.28 0.35 0.28 41 39 41 39 55 55 55 55 1 2 1 2 Curve INLET 86 61. 0.3 8- R O TAT I O N AIR FLOW 4.3 0.25 50±0.3 60±0.5 Static Pressure (Inch-H2O) 0.35 0.2 0.15 OUTLET 1 5 0.1 4±0.3 UL1007 #26AWG 2 0.05 0 10 20 30 40 5±0.3 300±50 20 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 36 63. 60x60x20 mm 19~25.5 CFM P/N Bearing VAPO KDE1206PKV1 KDE1206PKV2 KDE2406PKV1 KDE2406PKV2 MS.A.GN MS.A.GN MS.A.GN MS.A.GN Model P/N (2).GN (2).GN GN GN KD1206PKB1 KD1206PKB2 KD1206PKS1 KD1206PKS2 Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 0.15 0.07 0.078 0.047 1.8 0.8 1.9 1.1 4500 3700 4500 3700 23.0 19.0 23.0 19.0 0.18 0.14 0.18 0.14 33.5 28.0 33.5 28.0 (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) 0.154 0.088 0.154 0.09 1.9 1.1 1.9 1.1 4500 3700 4500 3700 23.0 19.0 23.0 19.0 0.18 0.14 0.18 0.14 34.5 29.0 33.5 28.0 12 12 24 24 2BALL Sleeve (VDC) 12 12 12 12 52 52 52 52 (g) 52 52 52 52 INLET 63 .5 58 0.21 4- 4.3 0.18 1 0.15 50 +- 0.3 60 +- 0.5 0.12 2 OUTLET 0.09 4 +- 0.3 0.06 3 UL2468,#26AWG 0.03 0 5 10 15 20 25 30 5 +-0.3 300 +- 50 63 .5 20 +- 0.5 0 58 Static Pressure (Inch-H2O) 0.24 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 37 Curve 1 2 1 2 Curve 1 2 1 2 60x60x25 mm 29~40 CFM P/N Bearing VAPO PMD1206PTVX-A PMD1206PTV1-A PMD1206PTV2-A PMD1206PTV3-A PMD2406PTVX-A PMD2406PTV1-A PMD2406PTV2-A PMD2406PTV3-A PMD4806PTVX-A PMD4806PTV1-A PMD4806PTV2-A PMD4806PTV3-A U.GN U.GN U.GN U.GN U.GN U.GN U.GN U.GN U.GN U.GN U.GN U.GN Model 2BALL Sleeve P/N PMD1206PTBX-A PMD1206PTB1-A PMD1206PTB2-A PMD1206PTB3-A PMD2406PTBX-A PMD2406PTB1-A PMD2406PTB2-A PMD2406PTB3-A PMD4806PTBX-A PMD4806PTB1-A PMD4806PTB2-A PMD4806PTB3-A (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN (2).U.GN Rating Voltage Power Current Power Consumption (VDC) (AMP) Speed Air Flow Static Pressure Noise Weight Curve (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 12 24 24 24 24 48 48 48 48 0.446 0.357 0.269 0.235 0.207 0.181 0.131 0.114 0.114 0.099 0.078 0.069 5.4 4.3 3.2 2.8 5.0 4.3 3.1 2.7 5.5 4.8 3.7 3.3 7600 6900 6100 5600 7600 6900 6100 5600 7600 6900 6100 5600 40.0 36.0 31.5 29.0 40.0 36.0 31.5 29.0 40.0 36.0 31.5 29.0 0.64 0.54 0.42 0.36 0.64 0.54 0.42 0.36 0.64 0.54 0.42 0.36 45 43 41 37 45 43 41 37 45 43 41 37 75 75 75 75 75 75 75 75 75 75 75 75 1 2 3 4 1 2 3 4 1 2 3 4 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 12 12 12 12 24 24 24 24 48 48 48 48 0.41 0.325 0.258 0.217 0.197 0.158 0.121 0.104 0.112 0.09 0.072 0.068 4.9 3.9 3.1 2.6 4.7 3.8 2.9 2.5 5.4 4.3 3.5 3.3 7600 6900 6100 5600 7600 6900 6100 5600 7600 6900 6100 5600 40.0 36.0 31.5 29.0 40.0 36.0 31.5 29.0 40.0 36.0 31.5 29.0 0.64 0.54 0.42 0.36 0.64 0.54 0.42 0.36 0.64 0.54 0.42 0.36 46 44 42 38 46 44 42 38 46 44 42 38 75 75 75 75 75 75 75 75 75 75 75 75 1 2 3 4 1 2 3 4 1 2 3 4 .5 63 0.6 ROTATION 8- 0.5 AIR FLOW 4.3 1 0.4 50±0.3 60±0.5 Static Pressure (Inch-H2O) INLET 0.7 2 0.3 OUTLET 3 0.2 UL1007 #26AWG 0.1 10 20 25 0.5 0 300±50 4 0 5±0.3 30 40 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 38 .5 63 60x60x25 mm 19.3~27 CFM P/N Bearing VAPO KDE1206PTVX KDE1206PTV1 KDE1206PTV2 KDE2406PTVX KDE2406PTV1 KDE2406PTV2 MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN Model P/N KD1206PTB1 KD1206PTB2 KD1206PTS1 KD1206PTS2 Rating Voltage Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 2.8 1.7 0.8 2.7 1.9 1.2 (WATTS) 1.8 1.0 1.8 1.1 12 12 12 24 24 24 2BALL Sleeve (VDC) 12 12 12 12 (2).GN (2).GN GN GN 0.23 0.14 0.07 0.114 0.079 0.048 (AMP) 0.148 0.087 0.151 0.089 Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 5200 4500 3800 5200 4500 3800 27.0 23.5 19.3 27.0 23.5 19.3 0.31 0.21 0.15 0.31 0.21 0.15 (RPM) (CFM) (Inch-H2O) 4500 3800 4500 3800 23.5 19.3 23.5 19.3 0.21 0.15 0.21 0.15 36.5 33.5 29.0 36.5 33.5 29.0 (dBA) 34.5 30.0 33.5 29.0 Curve 55 55 55 56 56 56 1 2 3 1 2 3 (g) Curve 55 55 55 55 2 3 2 3 INLET .69 59 ROTATION 5±0.3 1 0.2 2 0.15 OUTLET .3 61 3 25 0.5 0 0.05 0 UL1007 #26AWG 84.3 0.25 0.1 AIR FLOW 300±50 0.3 50±0.3 60±0.5 Static Pressure (Inch-H2O) 0.35 5 10 15 20 25 30 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 39 60x60x38 mm 41.5~56.5 CFM P/N Bearing 2BALL Sleeve PMD1206PMB1-A PMD1206PMB2-A PMD1206PMB3-A PMD2406PMB1-A PMD2406PMB2-A PMD2406PMB3-A PMD4806PMB1-A PMD4806PMB2-A PMD4806PMB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) 12 12 12 24 24 24 48 48 48 0.88 0.58 0.43 0.43 0.31 0.22 0.24 0.18 0.13 10.6 7.0 5.2 10.3 7.4 5.3 11.5 8.6 6.2 (RPM) (CFM) (Inch-H2O) (dBA) (g) 8000 7000 6000 8000 7000 6000 8000 7000 6000 56.5 49.2 41.5 56.5 49.2 41.5 56.5 49.2 41.5 0.92 0.71 0.53 0.92 0.71 0.53 0.92 0.71 0.53 56 52 47 56 52 47 56 52 47 90 90 90 90 90 90 90 90 90 1 2 3 1 2 3 1 2 3 1 .3 8- 4.3 +- 0 57.2 0.8 2 OUTLET 0.4 4 +-0.3 0 5 +- 0.3 UL1007,#24AWG 10 20 30 40 50 60 300 +- 50 4 +-0.3 38 +-0.3 57.2 3 0.2 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 40 63 .2 0.6 50 +- 0.3 1 60 +- 0.5 Static Pressure (Inch-H2O) INLET Curve 63 .2 Model 60x60x60 mm NEW 67 CFM Model P/N Bearing 2BALL Sleeve PSD1206PWB1-A (2).Z.GN PSD1206PWB1-A (2).Z.F.PWM.GN PSD1206PWB1-A (2).Z.R.PWM.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 1.69 1.69 1.69 20.3 20.3 20.3 11500/11000 11500/11000 11500/11000 67 67 67 2.53 2.53 2.53 66.3 66.3 66.3 203 203 203 ROT A T I ON INLET 3.8 50±0.3 60±0.5 3 Curve 3 Ø 8- Ø6 2.5 5±0.3 1 5±0.3 1.5 150±20 ROT 1 0.5 0 FAN1 FAN2 AIR FLOW 2 30±0.5 30±0.5 60±0.5 UL1571 #28AWG OUTLET 7.8 A T I ON Ø5 50±0.3 60±0.5 Static Pressure (Inch-H2O) Weight 0. 5± 3. Noise 0 20 40 60 80 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 41 1 1 1 70x70x15 mm 19~27 CFM P/N Rating Voltage Bearing VAPO KDE0507PHV2 KDE0507PHV3 KDE1207PHV1 KDE1207PHV2 KDE1207PHV3 KDE2407PHV1 KDE2407PHV2 MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN MS.A.GN Model P/N KD0507PHB2 KD0507PHB3 KD0507PHS2 KD0507PHS3 KD1207PHB1 KD1207PHB2 KD1207PHB3 KD1207PHS1 KD1207PHS2 KD1207PHS3 2BALL Sleeve (2).GN (2).GN GN GN (2).GN (2).GN (2).GN GN GN GN Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5 5 12 12 12 24 24 0.2 0.11 0.16 0.09 0.05 0.086 0.054 1.0 0.6 1.9 1.1 0.6 2.1 1.3 2800 2300 3300 2800 2300 3300 2800 23 19 27 23 19 27 23 0.09 0.07 0.11 0.09 0.07 0.11 0.09 26.5 21.5 31.5 26.5 21.5 31.5 26.5 52 52 50 50 50 52 52 2 3 1 2 3 2 3 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 5 5 5 5 12 12 12 12 12 12 0.218 0.13 0.218 0.131 0.173 0.104 0.066 0.171 0.102 0.067 1.1 0.7 1.1 0.7 2.1 1.3 0.8 2.1 1.2 0.8 2800 2300 2800 2300 3300 2800 2300 3300 2800 2300 23 19 23 19 27 23 19 27 23 19 0.09 0.07 0.09 0.07 0.11 0.09 0.07 0.11 0.09 0.07 27.5 22.5 26.5 21.5 32.5 27.5 22.5 31.5 26.5 21.5 52 52 52 52 50 50 50 50 50 50 2 3 2 3 1 2 3 1 2 3 .4 74 68.6 0.12 8- 4.3 0.09 61.5 +- 0.3 70 +- 0.5 1 0.06 2 3 5 +UL2468,#26AWG 5 10 15 20 25 30 300 +- 50 .8 75 15 +0.5 -0 0.03 0 OUTLET 0.3 68.6 Static Pressure (Inch-H2O) INLET ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 42 Curve 70x70x20 mm 37~43 CFM P/N Bearing VAPO PMD1207PKV1-A PMD1207PKV2-A PMD1207PKV3-A PMD2407PKV1-A PMD2407PKV2-A PMD2407PKV3-A GN GN GN GN GN GN Model 2BALL Sleeve P/N PMD1207PKB1-A PMD1207PKB2-A PMD1207PKB3-A PMD2407PKB1-A PMD2407PKB2-A PMD2407PKB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) 12 12 12 24 24 24 0.39 0.31 0.26 0.21 0.17 0.14 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 4.7 3.7 3.1 5.0 4.1 3.4 4600 4300 4000 4600 4300 4000 43 40 37 43 40 37 0.28 0.24 0.21 0.28 0.24 0.21 41.5 40.0 37.5 41.5 40.0 37.5 80 80 80 80 80 80 1 2 3 1 2 3 (VDC) (AMP) 12 12 12 24 24 24 0.39 0.31 0.26 0.21 0.17 0.14 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 4.7 3.7 3.1 5.0 4.1 3.4 4600 4300 4000 4600 4300 4000 43 40 37 43 40 37 0.28 0.24 0.21 0.28 0.24 0.21 42.5 41.0 38.5 42.5 41.0 38.5 80 80 80 80 80 80 1 2 3 1 2 3 Curve INLET 4 .9 77 ROTATION 0.25 AIR FLOW 8- 4.3 +- 0.3 2 1 0.2 60 +- 0.3 70 +- 0.5 Static Pressure (Inch-H2O) 0.3 0.15 OUTLET 3 UL1007,#24AWG 0.05 0 10 4 .9 77 0.1 20 30 40 50 300 +- 50 20 +- 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 43 70x70x20 mm 23.5~29 CFM P/N Bearing VAPO KDE1207PKV1 KDE1207PKV2 KDE1207PKV3 KDE2407PKV1 KDE2407PKV2 KDE2407PKV3 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN Model P/N KD1207PKB1 KD1207PKB2 KD1207PKB3 KD1207PKS1 KD1207PKS2 KD1207PKS3 KD2407PKB1 KD2407PKB2 KD2407PKB3 KD2407PKS1 KD2407PKS2 KD2407PKS3 2BALL Sleeve 13.(2).GN 13.(2).GN 13.(2).GN 13.GN 13.GN 13.GN 13.(2).A.GN 13.(2).A.GN 13.(2).A.GN 13.A.GN 13.A.GN 13.A.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 24 24 24 0.12 0.10 0.07 0.07 0.05 0.04 1.4 1.2 0.8 1.7 1.2 1.0 3200 2900 2600 3200 2900 2600 29.0 27.0 23.5 29.0 27.0 23.5 0.14 0.12 0.09 0.14 0.12 0.09 33 30 26 33 30 26 66 66 66 68 68 68 1 2 3 1 2 3 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 12 12 12 12 12 12 24 24 24 24 24 24 0.13 0.1 0.08 0.14 0.11 0.08 0.06 0.05 0.04 0.06 0.05 0.04 1.6 1.2 1.0 1.7 1.3 1.0 1.4 1.2 1.0 1.4 1.2 1.0 3200 2900 2600 3200 2900 2600 3200 2900 2600 3200 2900 2600 29.0 27.0 23.5 29.0 27.0 23.5 29.0 27.0 23.5 29.0 27.0 23.5 0.14 0.12 0.09 0.14 0.12 0.09 0.14 0.12 0.09 0.14 0.12 0.09 66 66 66 66 66 66 68 68 68 68 68 68 1 2 3 1 2 3 1 2 3 1 2 3 33.5 31 27 33 30 26 33.5 31 27 33 30 26 Curve INTEL 4 .9 0.15 ROTATION 8- 4.3 +- 0.3 0.12 AIR FLOW 1 2 0.09 60 +- 0.3 70 +- 0.5 Static Pressure (Inch-H2O) 77 3 OUTEL 0.06 4 .9 77 0.03 UL1007,#24AWG 300 +- 50 20 +- 0.5 0 0 0 10 20 30 40 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 44 70x70x25 mm 40~49 CFM P/N Bearing VAPO PMD1207PTV1-A PMD1207PTV2-A PMD1207PTV3-A PMD2407PTV1-A PMD2407PTV2-A PMD2407PTV3-A PMD4807PTV1-A PMD4807PTV2-A PMD4807PTV3-A GN GN GN GN GN GN GN GN GN Model 2BALL Sleeve P/N PMD1207PTB1-A PMD1207PTB2-A PMD1207PTB3-A PMD2407PTB1-A PMD2407PTB2-A PMD2407PTB3-A PMD4807PTB1-A PMD4807PTB2-A PMD4807PTB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) 12 12 12 24 24 24 48 48 48 0.37 0.32 0.25 0.20 0.16 0.13 0.12 0.11 0.09 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 4.4 3.8 3.0 4.8 3.8 3.1 5.8 5.3 4.3 5100 4700 4200 5100 4700 4200 5100 4700 4200 49 45 40 49 45 40 49 45 40 0.36 0.31 0.25 0.36 0.31 0.25 0.36 0.31 0.25 44 42 38 44 42 38 44 42 38 90 90 90 90 90 90 90 90 90 1 2 3 1 2 3 1 2 3 (VDC) (AMP) 12 12 12 24 24 24 48 48 48 0.37 0.31 0.24 0.19 0.15 0.12 0.12 0.10 0.08 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 4.4 3.7 2.9 4.6 3.6 2.9 5.8 4.8 4.3 5100 4700 4200 5100 4700 4200 5100 4700 4200 49 45 40 49 45 40 49 45 40 0.36 0.31 0.25 0.36 0.31 0.25 0.36 0.31 0.25 45 43 39 45 43 39 45 43 39 90 90 90 90 90 90 90 90 90 1 2 3 1 2 3 1 2 3 Curve INLET .1 67 0.35 AIR FLOW 4.3 8- 0.3 1 0.25 UL1007,#24AWG 0.2 OUTLET 2 0.15 3 0.1 60 +-0.3 70 +-0.5 0.05 0 15 30 45 60 5 +- 0.3 300 +- 50 Static Pressure (Inch-H2O) 0.4 67 4+-0.3 25±0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 45 70x70x25 mm 24~32.5 CFM P/N Bearing VAPO KDE1207PTV1 KDE1207PTV2 KDE1207PTV3 KDE2407PTV1 KDE2407PTV2 KDE2407PTV3 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN Model P/N KD1207PTB1 KD1207PTB2 KD1207PTB3 KD1207PTS1 KD1207PTS2 KD1207PTS3 KD2407PTB1 KD2407PTB2 KD2407PTB3 KD2407PTS1 KD2407PTS2 KD2407PTS3 2BALL Sleeve 13.(2).GN 13.(2).GN 13.(2).GN 13.GN 13.GN 13.GN 13.(2).GN 13.(2).GN 13.(2).GN 13.GN 13.GN 13.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 24 24 24 0.12 0.09 0.06 0.06 0.05 0.04 1.4 1.1 0.7 1.4 1.2 1.0 3200 2900 2500 3200 2900 2500 31.0 28.0 24.0 31.0 28.0 24.0 0.15 0.13 0.10 0.15 0.13 0.10 32 29 25 32 29 25 70 70 70 72 72 72 1 2 3 1 2 3 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 12 12 12 12 12 12 24 24 24 24 24 24 0.12 0.1 0.07 0.13 0.1 0.08 0.06 0.05 0.04 0.06 0.05 0.04 1.4 1.2 0.8 1.6 1.2 1.0 1.4 1.2 1.0 1.4 1.2 1.0 3400 3100 2700 3200 2900 2500 3400 3100 2700 3200 2900 2500 32.5 29.5 26.0 31.0 28.0 24.0 32.5 29.5 26.0 31.0 28.0 24.0 0.16 0.14 0.10 0.15 0.13 0.10 0.16 0.14 0.10 0.15 0.13 0.10 33 31 28 32 29 25 33 31 28 32 29 25 70 70 70 70 70 70 72 72 72 72 72 72 4 5 6 1 2 3 4 5 6 1 2 3 Curve 0.15 1 2 8- 4.3 4 0.12 5 UL1007,#24AWG 0.09 6 3 0.06 60 +- 0.3 70 +- 0.5 0.03 0 10 20 30 40 5 +- 0.3 300 +- 50 Static Pressure (Inch-H2O) .1 67 0.18 67 4 +-0.3 0.5 25 +- 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 46 80x80x15 mm 32~40 CFM Model P/N Bearing 2BALL Sleeve KD1208PHB1 KD1208PHB2 KD1208PHB3 KD2408PHB1 KD2408PHB2 KD2408PHB3 Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 2.5 1.6 1.2 2.5 2.1 1.8 3000 2700 2400 3000 2700 2400 40 36 32 40 36 32 0.13 0.11 0.09 0.13 0.11 0.09 35 32 29 35 32 29 68 68 68 68 68 68 12 12 12 24 24 24 13.(2).GN 13.(2).GN 13.(2).GN 13.(2).GN 13.(2).GN 13.(2).GN 0.21 0.13 0.1 0.102 0.088 0.073 Curve INLET 89 0.12 8- AIR FLOW R O TAT I O N 4.3 0.1 71.5±0.3 80±0.5 Static Pressure (Inch-H2O) 0.14 1 0.08 0.06 OUTLET 2 0.04 86 3 15 UL1007 #24AWG 5±0.3 0.5 0 300±50 0.02 0 10 20 30 40 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 47 1 2 3 1 2 3 80x80x20 mm 45~53 CFM P/N Bearing VAPO PMD1208PKV1-A PMD1208PKV2-A PMD1208PKV3-A PMD2408PKV1-A PMD2408PKV2-A PMD2408PKV3-A Model PMD1208PKB1-A PMD1208PKB2-A PMD1208PKB3-A PMD2408PKB1-A PMD2408PKB2-A PMD2408PKB3-A GN GN GN GN GN GN 2BALL Sleeve P/N (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 24 24 24 0.39 0.31 0.26 0.21 0.17 0.14 4.7 3.7 3.1 5.0 4.1 3.4 4600 4200 3900 4600 4200 3900 53 49 45 53 49 45 0.36 0.31 0.26 0.36 0.31 0.26 48 45 43 48 45 43 85 85 85 85 85 85 1 2 3 1 2 3 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 12 12 12 24 24 24 0.39 0.31 0.26 0.21 0.17 0.14 4.7 3.7 3.1 5.0 4.1 3.4 4600 4200 3900 4600 4200 3900 53 49 45 53 49 45 0.36 0.31 0.26 0.36 0.31 0.26 49 46 44 49 46 44 85 85 85 85 85 85 1 2 3 1 2 3 .4 77 0.35 0.3 0.25 UL1007,#24AWG 1 0.2 2 0.15 0.1 8- 4.3 3 0.05 0 15 30 45 60 71.5 +- 0.3 80 +- 0.5 5 +- 0.3 300 +- 50 Static Pressure (Inch-H2O) 0.4 Curve .2 77 4 +-0.3 20 +- 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 48 80x80x20 mm 29~39 CFM P/N Bearing VAPO KDE1208PKV1 KDE1208PKV2 KDE1208PKV3 KDE2408PKV1 KDE2408PKV2 KDE2408PKV3 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN 13.MS.A.GN Model P/N 13.(2).GN 13.(2).GN 13.(2).GN 13.GN 13.GN 13.GN 13.(2).GN 13.(2).GN 13.(2).GN 13.GN 13.GN 13.GN KD1208PKB1 KD1208PKB2 KD1208PKB3 KD1208PKS1 KD1208PKS2 KD1208PKS3 KD2408PKB1 KD2408PKB2 KD2408PKB3 KD2408PKS1 KD2408PKS2 KD2408PKS3 2BALL Sleeve Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 24 24 24 0.13 0.10 0.07 0.07 0.05 0.04 1.6 1.2 0.8 1.7 1.2 1.0 3200 2900 2500 3200 2900 2500 36 33 29 36 33 29 0.18 0.16 0.12 0.18 0.16 0.12 38 35 30 38 35 30 72 72 72 72 72 72 1 2 3 1 2 3 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 1.6 1.3 1.0 1.7 1.3 1.0 1.5 1.1 0.8 1.5 1.2 1.0 3300 3000 2600 3200 2900 2500 3300 3000 2600 3200 2900 2500 39 35 31 36 33 29 39 35 31 36 33 29 0.19 0.17 0.14 0.18 0.16 0.12 0.19 0.17 0.14 0.18 0.16 0.12 39 37 33 38 35 30 39 37 33 38 35 30 72 72 72 72 72 72 72 72 72 72 72 72 4 5 6 1 2 3 4 5 6 1 2 3 12 12 12 12 12 12 24 24 24 24 24 24 0.13 0.11 0.08 0.14 0.11 0.08 0.062 0.047 0.035 0.061 0.05 0.041 Curve .4 0.21 77 1 0.18 2 0.15 3 UL1007,#24AWG 0.12 0.09 OUTLET 4 6 0.06 5 8- 4.3 0.03 71.5 +-0.3 80 +-0.5 0 10 20 30 40 5 +-0.3 300 +-50 Static Pressure (Inch-H2O) INLET .2 77 4 +-0.3 20 0.5 + -0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 49 80x80x25 mm 49~60 CFM P/N Bearing VAPO PMD1208PTV1-A PMD1208PTV2-A PMD1208PTV3-A PMD2408PTV1-A PMD2408PTV2-A PMD2408PTV3-A PMD4808PTV1-A PMD4808PTV2-A PMD4808PTV3-A GN GN GN GN GN GN GN GN GN Model 2BALL Sleeve P/N PMD1208PTB1-A PMD1208PTB2-A PMD1208PTB3-A PMD2408PTB1-A PMD2408PTB2-A PMD2408PTB3-A PMD4808PTB1-A PMD4808PTB2-A PMD4808PTB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption (VDC) (AMP) 12 12 12 24 24 24 48 48 48 0.42 0.34 0.27 0.22 0.17 0.14 0.13 0.11 0.09 (VDC) (AMP) 12 12 12 24 24 24 48 48 48 0.40 0.34 0.26 0.21 0.17 0.13 0.13 0.11 0.09 Weight Speed Air Flow Static Pressure Noise Curve (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5.0 4.1 3.2 5.3 4.1 3.4 6.2 5.3 4.3 4700 4300 3900 4700 4300 3900 4700 4300 3900 60 55 49 60 55 49 60 55 49 0.43 0.36 0.30 0.43 0.36 0.30 0.43 0.36 0.30 46 44 41 46 44 41 46 44 41 100 100 100 100 100 100 100 100 100 1 2 3 1 2 3 1 2 3 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) Curve 4.8 4.1 3.1 5.0 4.1 3.1 6.2 5.3 4.3 4700 4300 3900 4700 4300 3900 4700 4300 3900 60 55 49 60 55 49 60 55 49 0.43 0.36 0.30 0.43 0.36 0.30 0.43 0.36 0.30 47 45 42 47 45 42 47 45 42 100 100 100 100 100 100 100 100 100 1 2 3 1 2 3 1 2 3 INLET .4 77 0.4 AIR FLOW 1 0.35 8- 0.3 4.3 2 0.25 3 0.2 UL1007,#24AWG OUTLET 300 +- 50 0.15 0.1 80 +- 0.5 0.05 0 15 30 45 60 .2 77 4 +-0.3 71.5 +- 0.3 5 +- 0.3 Static Pressure (Inch-H2O) 0.45 25 +- 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 50 80x80x25 mm NEW 53~60 CFM Bearing VAPO PF80251V1-0000-A99 PF80251V2-0000-A99 PF80251V3-0000-A99 Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 4.1 3.4 2.7 4800 4500 4200 60 57 53 0.41 0.35 0.30 (WATTS) (RPM) (CFM) (Inch-H2O) 4.1 3.4 2.7 4800 4500 4200 60 57 53 0.41 0.35 0.30 12 12 12 2BALL Sleeve Model (VDC) PF80251B1-0000-A99 PF80251B2-0000-A99 PF80251B3-0000-A99 12 12 12 0.341 0.285 0.223 (AMP) 0.341 0.285 0.223 46.5 45.0 43.5 (dBA) 47.5 46.0 44.5 Curve 91 91 91 1 2 3 (g) Curve 91 91 91 1 2 3 * PWM available. INLET 7.2 Ø7 ROT A T I ON AIR FLOW 3 4. Ø 8- 0.4 80±0.5 71.5±0.3 Static Pressure (Inch-H2O) 0.5 0.3 1 SUNON OUTLET 1.6 Ø9 0.2 2 3 5±0.3 UL1007 #24AWG 0.1 0 0 10 20 30 40 50 60 25 +- 0.5 0 300±50 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 51 80x80x25 mm NEW 33~45 CFM Bearing VAPO ME80251VX-0000-A99 ME80251V1-0000-A99 ME80251V2-0000-A99 ME80251V3-0000-A99 ME80252VX-0000-A99 ME80252V1-0000-A99 ME80252V2-0000-A99 ME80252V3-0000-A99 Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 1.9 1.7 1.4 1.1 2.2 1.8 1.4 1.2 3600 3200 2900 2600 3600 3200 2900 2600 45 41 37 33 45 41 37 33 0.23 0.18 0.15 0.11 0.23 0.18 0.15 0.11 (WATTS) (RPM) (CFM) (Inch-H2O) 1.80 1.74 1.40 1.10 1.92 1.80 1.50 1.20 1.70 1.40 1.10 1.80 1.50 1.30 3600 3200 2900 2600 3600 3200 2900 2600 3200 2900 2600 3200 2900 2600 45 41 37 33 45 41 37 33 41 37 33 41 37 33 0.23 0.18 0.15 0.11 0.23 0.18 0.15 0.11 0.18 0.15 0.11 0.18 0.15 0.11 12 12 12 12 24 24 24 24 2BALL Sleeve Model EE80251BX-0000-A99 EE80251B1-0000-A99 EE80251B2-0000-999 EE80251B3-0000-999 EE80252BX-0000-A99 EE80252B1-0000-A99 EE80252B2-0000-999 EE80252B3-0000-999 EE80251S1-0000-A99 EE80251S2-0000-999 EE80251S3-0000-999 EE80252S1-0000-A99 EE80252S2-0000-999 EE80252S3-0000-999 (VDC) 12 12 12 12 24 24 24 24 12 12 12 24 24 24 0.160 0.145 0.120 0.081 0.090 0.073 0.059 0.049 (AMP) 0.150 0.145 0.120 0.090 0.080 0.073 0.064 0.050 0.145 0.120 0.090 0.073 0.064 0.052 37.0 33.0 30.0 28.0 37.0 33.0 30.0 28.0 (dBA) 38.0 33.0 30.0 28.0 38.0 33.0 30.0 28.0 33.0 30.0 28.0 33.0 30.0 28.0 Curve 89 77 75 75 89 75 75 75 1 2 3 4 1 2 3 4 (g) Curve 89 75 75 74 89 75 75 75 75 75 75 75 75 75 1 2 3 4 1 2 3 4 2 3 4 2 3 4 7.2 Ø7 0.3 ROT A T I ON AIR FLOW Ø 8- 0.25 0.2 80±0.5 71.5±0.3 Static Pressure (Inch-H2O) INLET 1 2 0.15 3 4. SUNON OUTLET 1.6 Ø9 0.1 5±0.3 3 UL1007 #24AWG 0.05 25 +- 0.5 0 300±50 4 0 0 10 20 30 40 50 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 52 80x80x32 mm NEW 50.3~59.4 CFM Model P/N Bearing 2BALL Sleeve Rating Voltage Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 12 12 12 0.31 0.23 0.20 3.7 2.8 2.4 PF80321B1-0000-A99 PF80321B2-0000-A99 PF80321B3-0000-A99 Noise Weight (Inch-H2O) (dBA) (g) 0.36 0.32 0.27 45.2 43.1 41.1 Air Flow Static Pressure (RPM) (CFM) 4800 4500 4100 59.4 55.9 50.3 Curve 1 2 3 * PWM available. 7.2 Ø7 0.4 8- Ø 0.35 1 4. AIR FLOW 3± 0. 3 ROT A T I ON 0.3 0.25 2 80±0.5 72±0.3 Static Pressure (Inch-H2O) INLET 0.2 SUNON OUTLET 0.15 Ø7 3 0.1 32+0.5 -0 #24AWG 0.05 0 0 10 20 30 40 50 60 70 5±0.3 300±50 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 53 7.4 80x80x38 mm 59.5~84.1 CFM P/N Bearing 2BALL Sleeve PMD1208PMB1-A PMD1208PMB2-A PMD1208PMB3-A PMD2408PMB1-A PMD2408PMB2-A PMD2408PMB3-A PMD4808PMB1-A PMD4808PMB2-A PMD4808PMB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption (VDC) (AMP) 12 12 12 24 24 24 48 48 48 0.76 0.53 0.37 0.40 0.30 0.20 0.19 0.14 0.10 Noise Weight (Inch-H2O) (dBA) (g) 0.74 0.57 0.43 0.74 0.57 0.43 0.74 0.57 0.43 55.2 51.6 47.3 55.2 51.6 47.3 55.2 51.6 47.3 175 175 175 175 175 175 175 175 175 Speed Air Flow Static Pressure (WATTS) (RPM) (CFM) 9.1 6.4 4.4 9.6 7.2 4.8 9.1 6.7 4.8 5700 4900 4200 5700 4900 4200 5700 4900 4200 84.1 74.5 59.5 84.1 74.5 59.5 84.1 74.5 59.5 INLET Curve 1 2 3 1 2 3 1 2 3 85 Model 4.3 +- 0.3 AIR FLOW 76.8 8- 0.6 2 OUTLET 3 4 +-0.3 0.2 UL1007,#24AWG 300 +- 50 5 +- 0.3 4 +-0.3 38+- 0.3 0 0 20 40 60 80 100 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 54 85 0.4 76.8 80 +- 0.5 1 71.5 +- 0.3 Static Pressure (Inch-H2O) 0.8 92x92x25 mm 65~77 CFM P/N Bearing VAPO PMD1209PTV1-A PMD1209PTV2-A PMD1209PTV3-A PMD2409PTV1-A PMD2409PTV2-A PMD2409PTV3-A PMD4809PTV1-A PMD4809PTV2-A PMD4809PTV3-A Model GN GN GN GN GN GN GN GN GN 2BALL Sleeve P/N PMD1209PTB1-A PMD1209PTB2-A PMD1209PTB3-A PMD2409PTB1-A PMD2409PTB2-A PMD2409PTB3-A PMD4809PTB1-A PMD4809PTB2-A PMD4809PTB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) 12 12 12 24 24 24 48 48 48 48 48 0.47 0.40 0.31 0.25 0.20 0.16 0.15 0.12 0.09 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 5.6 4.8 3.7 6.0 4.8 3.8 7.2 5.8 4.3 4200 3900 3600 4200 3900 3600 4200 3900 3600 77 73 65 77 73 65 77 73 65 0.37 0.33 0.28 0.37 0.33 0.28 0.37 0.33 0.28 47 44 42 47 44 42 47 44 42 (VDC) (AMP) 12 12 12 24 24 24 48 48 48 0.46 0.38 0.30 0.24 0.19 0.15 0.14 0.12 0.09 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) 5.5 4.6 3.6 5.8 4.6 3.6 6.7 5.8 4.3 4200 3900 3600 4200 3900 3600 4200 3900 3600 77 73 65 77 73 65 77 73 65 0.37 0.33 0.28 0.37 0.33 0.28 0.37 0.33 0.28 48 45 43 48 45 43 48 45 43 Curve 120 120 120 120 120 120 120 120 120 (g) 1 2 3 1 2 3 1 2 3 Curve 120 120 120 120 120 120 120 120 120 1 2 3 1 2 3 1 2 3 0.4 .8 87 0.35 ROTATION 8- 0.3 0.25 AIR FLOW 4.3 1 UL1007,#24AWG 0.2 OUTLET 0.15 2 0.1 82.5 +- 0.3 92 +- 0.5 3 0.05 0 20 40 60 80 5 +- 0.3 300 +- 50 Static Pressure (Inch-H2O) INLET .6 87 4 +-0.3 25 +- 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 55 92x92x25 mm NEW 65~75 CFM Bearing VAPO Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) 4500 4200 3900 75 70 65 0.35 0.30 0.25 (RPM) (CFM) (Inch-H2O) 4500 4200 3900 75 70 65 0.35 0.30 0.25 PF92251V1-0000-A99 PF92251V2-0000-A99 PF92251V3-0000-A99 12 12 12 2BALL Sleeve Model 0.393 0.325 0.26 (VDC) PF92251B1-0000-A99 PF92251B2-0000-A99 PF92251B3-0000-A99 12 12 12 4.7 3.9 3.1 (AMP) (WATTS) 0.393 0.325 0.26 4.7 3.9 3.1 46 44 42 Weight Curve (g) 103 103 103 1 2 3 (dBA) (g) Curve 47 45 43 98 98 98 1 2 3 INLET Ø9 1. 3 * PWM available. ROT 8- Ø4 A T I ON AIR FLOW .3 0.3 SUNON UL1007 #24AWG 300±50 OUTLET 03 1 .5 0.4 92±0.5 82.5±0.3 0.2 Ø1 Static Pressure (Inch-H2O) 0.5 2 3 0.1 5±0.3 25± 0.5 0 0 0 10 20 30 40 50 60 70 80 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 56 92x92x25 mm NEW 39.5~55 CFM VAPO ME92251VX-0000-A99 ME92251V1-0000-A99 ME92251V2-0000-A99 ME92251V3-0000-A99 ME92252VX-0000-A99 ME92252V1-0000-A99 ME92252V2-0000-A99 ME92252V3-0000-A99 Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) 3400 3000 2700 2400 3400 3000 2700 2400 55.0 51.5 45.0 39.5 55.0 51.5 45.0 39.5 0.21 0.15 0.13 0.10 0.21 0.15 0.13 0.10 (RPM) (CFM) (Inch-H2O) 3400 3000 2700 2400 3400 3000 2700 2400 3000 2700 2400 3000 2700 2400 55.0 51.5 45.0 39.5 55.0 51.5 45.0 39.5 51.5 45.0 39.5 51.5 45.0 39.5 0.21 0.15 0.13 0.10 0.21 0.15 0.13 0.10 0.15 0.13 0.10 0.15 0.13 0.10 12 12 12 12 24 24 24 24 2BALL Sleeve Model (VDC) EE92251BX-0000-A99 EE92251B1-0000-A99 EE92251B2-0000-999 EE92251B3-0000-999 EE92252BX-0000-A99 EE92252B1-0000-A99 EE92252B2-0000-999 EE92252B3-0000-999 EE92251S1-0000-A99 EE92251S2-0000-999 EE92251S3-0000-999 EE92252S1-0000-A99 EE92252S2-0000-999 EE92252S3-0000-999 12 12 12 12 24 24 24 24 12 12 12 24 24 24 2.28 2.00 1.60 1.30 2.40 2.10 1.60 1.30 0.190 0.165 0.135 0.091 0.100 0.087 0.068 0.056 (AMP) (WATTS) 2.28 1.98 1.60 1.30 2.40 2.10 1.70 1.40 2.00 1.60 1.30 2.10 1.70 1.40 0.190 0.165 0.135 0.105 0.100 0.087 0.070 0.057 0.165 0.135 0.105 0.087 0.072 0.060 37.5 34.0 32.0 28.0 37.5 34.0 32.0 28.0 (dBA) 37.5 34.0 32.0 28.0 37.5 34.0 32.0 28.0 34.0 32.0 28.0 34.0 32.0 28.0 Weight (g) 103.0 96.0 94.0 94.0 103.0 94.0 94.0 94.0 1 2 3 4 1 2 3 4 (g) Curve 89.0 96.0 94.0 94.0 97.4 96.0 94.0 94.0 94.0 94.0 94.0 94.0 94.0 94.0 ROT 8- Ø4 A T I ON 1 2 3 4 1 2 3 4 2 3 4 2 3 4 AIR FLOW .3 1 0.15 SUNON UL1007 #24AWG 300±50 OUTLET Ø1 03 .5 2 0.1 92±0.5 82.5±0.3 Static Pressure (Inch-H2O) INLET 0.25 0.2 Curve Ø9 1. 3 Bearing 3 0.05 4 0 0 10 20 30 40 50 60 5±0.3 25± 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 57 92x92x32 mm NEW 79 CFM P/N Bearing VAPO PSD1209PLV2-A PSD1209PLV2-A Z.GN Z.F.PWM.GN Rating Voltage Power Current Power Consumption (VDC) (AMP) 12 12 0.35 0.35 Weight Speed Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 4.2 4.2 4000 4000 79 79 0.36 0.36 42.1 42.1 186 186 Curve 1 1 0.4 9.1 Ø8 0.35 3 4. Ø 8- UL1007 #24AWG 32 +0.5 -0 4±0.3 0.3 1 0.2 SUNON 0.15 5±0.3 300±50 0.25 92±0.5 82.5±0.3 Static Pressure (Inch-H2O) INLET AIR FLOW OUTLET 9.1 0.1 82.5±0.3 92±0.5 Ø8 0.05 0 0 20 40 60 80 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 58 92x92x38 mm 91.7~120.2 CFM Model P/N Bearing 2BALL Sleeve PMD1209PMB1-A PMD1209PMB2-A PMD1209PMB3-A PMD2409PMB1-A PMD2409PMB2-A PMD2409PMB3-A PMD4809PMB1-A PMD4809PMB2-A PMD4809PMB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption (VDC) (AMP) (WATTS) 12 12 12 24 24 24 48 48 48 1.04 0.71 0.47 0.51 0.40 0.25 0.24 0.16 0.12 12.5 8.5 5.6 12.2 9.6 6.0 11.5 7.7 5.8 Speed Noise Weight (Inch-H2O) (dBA) (g) 0.71 0.56 0.43 0.71 0.56 0.43 0.71 0.56 0.43 57.6 53.8 50.3 57.6 53.8 50.3 57.6 53.8 50.3 190 190 190 190 190 190 190 190 190 Air Flow Static Pressure (RPM) (CFM) 4900 4400 3800 4900 4400 3800 4900 4400 3800 120.2 106.3 91.7 120.2 106.3 91.7 120.2 106.3 91.7 Curve 1 2 3 1 2 3 1 2 3 INLET 97 ROTATION 8- 0.6 0.5 1 + 0.3 4.3 - 88.8 0.7 92 +- 0.5 82.5 +- 0.3 0.4 2 OUTLET 0.3 97 3 4.2+- 0.3 0.2 5 +-0.3 UL1007,#24AWG 300 +- 50 0.1 0 50 100 150 4.2+- 0.3 38 +- 0.3 88.8 Static Pressure (Inch-H2O) 0.8 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 59 120x120x25 mm 120~150 CFM Model P/N Bearing 2BALL Sleeve (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) 12 12 12 24 24 24 48 48 48 1.0 0.72 0.54 0.49 0.36 0.28 0.26 0.19 0.14 (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12.0 8.6 6.5 11.8 8.6 6.7 12.5 9.1 6.7 4500 4000 3600 4500 4000 3600 4500 4000 3600 150 133 120 150 133 120 150 133 120 0.62 0.50 0.41 0.62 0.50 0.41 0.62 0.50 0.41 54 51 48 54 51 48 54 51 48 0.7 0.6 4.3± 0.5 0.3 220 220 220 220 220 220 220 220 220 1 2 3 1 2 3 1 2 3 .6 23 Ø1 AIR FLOW TATION RO 1 0.4 SUNON 2 UL1007 #24AWG 0.3 OUTLET 300±50 3 0.2 30 60 90 120 150 105±0.3 120±0.5 4±0.3 25+ 0.5 0 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 60 .5 28 Ø1 0.1 0 Curve INLET 8- Ø 5±0.3 Static Pressure (Inch-H2O) PMD1212PTB1-A PMD1212PTB2-A PMD1212PTB3-A PMD2412PTB1-A PMD2412PTB2-A PMD2412PTB3-A PMD4812PTB1-A PMD4812PTB2-A PMD4812PTB3-A Rating Voltage 120x120x25 mm NEW 75~108.2 CFM Bearing VAPO MEC0251V1-0000-A99 MEC0251V2-0000-A99 MEC0251V3-0000-A99 MEC0252V1-0000-A99 MEC0252V2-0000-A99 MEC0252V3-0000-A99 MEC0254V1-0000-A99 MEC0254V2-0000-A99 MEC0254V3-0000-A99 Rating Voltage Power Current Power Consumption (VDC) (AMP) (WATTS) 5.4 3.4 1.9 5.0 3.5 2.0 5.7 3.8 2.6 (WATTS) (RPM) (CFM) 5.4 3.4 1.9 5.0 3.5 2.0 5.7 3.8 2.6 3100 2700 2200 3100 2700 2200 3100 2700 2200 108.2 93.0 75.0 108.2 93.0 75.0 108.2 93.0 75.0 12 12 12 24 24 24 48 48 48 2BALL Sleeve Model EEC0251B1-0000-A99 EEC0251B2-0000-A99 EEC0251B3-0000-A99 EEC0252B1-0000-A99 EEC0252B2-0000-A99 EEC0252B3-0000-A99 EEC0254B1-0000-A99 EEC0254B2-0000-A99 EEC0254B3-0000-A99 (VDC) 12 12 12 24 24 24 48 48 48 0.451 0.279 0.161 0.207 0.146 0.084 0.119 0.079 0.054 (AMP) 0.451 0.279 0.161 0.207 0.146 0.084 0.119 0.079 0.054 Speed Weight Air Flow Static Pressure Noise Curve (RPM) (CFM) (Inch-H2O) (dBA) (g) 3100 2700 2200 3100 2700 2200 3100 2700 2200 108.2 93.0 75.0 108.2 93.0 75.0 108.2 93.0 75.0 0.28 0.22 0.16 0.28 0.22 0.16 0.28 0.22 0.16 44.5 40.5 34.0 44.5 40.5 34.0 44.5 40.5 34.0 162 162 162 162 162 162 162 162 162 1 2 3 1 2 3 1 2 3 (Inch-H2O) (dBA) (g) Curve 0.28 0.22 0.16 0.28 0.22 0.16 0.28 0.22 0.16 44.5 40.5 34.0 44.5 40.5 34.0 44.5 40.5 34.0 157 157 157 157 157 157 157 157 157 1 2 3 1 2 3 1 2 3 INLET 0.25 UL1007 #24AWG 330±15 5±0.3 3 4. AIR FLOW Ø 8- 0.2 1 0.15 SUNON 2 0.1 105±0.3 120±0.5 Static Pressure (Inch-H2O) .4 15 Ø1 0.3 OUTLET .2 25 Ø1 3 0.05 25+ 0.5 0 0 0 30 60 90 120 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 61 120x120x38 mm 153~190 CFM Model P/N Bearing 2BALL Sleeve PMD1212PMB1-A PMD1212PMB2-A PMD1212PMB3-A PMD2412PMB1-A PMD2412PMB2-A PMD2412PMB3-A PMD4812PMB1-A PMD4812PMB2-A PMD4812PMB3-A (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Power Current Power Consumption (VDC) (AMP) 12 12 12 24 24 24 48 48 48 1.6 1.2 0.83 0.76 0.57 0.42 0.4 0.3 0.22 Speed Air Flow Static Pressure Noise (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) 19.2 14.4 10.0 18.2 13.7 10.1 19.2 14.4 10.6 4200 3800 3400 4200 3800 3400 4200 3800 3400 190 170 153 190 170 153 190 170 153 0.65 0.54 0.43 0.65 0.54 0.43 0.65 0.54 0.43 Weight 54 51 48 54 51 48 54 51 48 Curve (g) 330 330 330 330 330 330 330 330 330 1 2 3 1 2 3 1 2 3 INLET 8-Ø 4.3 ±0 SUNON UL1007 #24AWG 105±0.3 120±0.5 .3 .6 36 Ø1 AIR FLOW OUTLET 300±50 5±0.3 4±0.3 38 0.5 0 *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 62 .2 25 Ø1 120x120x38 mm NEW 93~138 CFM Bearing VAPO MEC0381V1-0000-A99 MEC0381V2-0000-A99 MEC0381V3-0000-A99 MEC0382V1-0000-A99 MEC0382V2-0000-A99 MEC0382V3-0000-A99 MEC0384V1-0000-A99 MEC0384V2-0000-A99 MEC0384V3-0000-A99 2BALL Sleeve Model EEC0381B1-0000-A99 EEC0381B2-0000-A99 EEC0381B3-0000-A99 EEC0382B1-0000-A99 EEC0382B2-0000-A99 EEC0382B3-0000-A99 EEC0384B1-0000-A99 EEC0384B2-0000-A99 EEC0384B3-0000-A99 Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) 12 12 12 24 24 24 48 48 48 0.833 0.421 0.241 0.383 0.224 0.130 0.203 0.120 0.068 10.0 5.1 2.9 9.2 5.4 3.1 9.7 5.8 3.3 3100 2600 2100 3100 2600 2100 3100 2600 2100 138 116 93 138 116 93 138 116 93 0.36 0.26 0.18 0.36 0.26 0.18 0.36 0.26 0.18 (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) 12 12 12 24 24 24 48 48 48 0.833 0.421 0.241 0.383 0.224 0.130 0.203 0.120 0.069 10.0 5.1 2.9 9.2 5.4 3.1 9.7 5.8 3.3 3100 2600 2100 3100 2600 2100 3100 2600 2100 138 116 93 138 116 93 138 116 93 0.36 0.26 0.18 0.36 0.26 0.18 0.36 0.26 0.18 Weight Curve (g) 48 44 37 48 44 37 48 44 37 (dBA) 48 44 37 48 44 37 48 44 37 218 218 218 218 218 218 218 218 218 1 2 3 1 2 3 1 2 3 (g) Curve 214 214 214 214 214 214 214 214 214 1 2 3 1 2 3 1 2 3 INLET 0.4 0.35 UL1007 #24AWG 330±15 5±0.3 3 0.3 AIR FLOW 4. Ø 8- 0.25 1 0.2 2 SUNON 0.15 0.1 OUTLET 105±0.3 120±0.5 Static Pressure (Inch-H2O) .5 15 Ø1 . 25 Ø1 3 0.05 38+0.5 0 0 0 30 60 90 120 150 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications are subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 63 2 35x35x7 mm NEW 0.9 CFM P/N Bearing VAPO GB1235PDV3-8 Z.X.GN Rating Voltage Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 0.065 0.8 6300 0.9 0.27 22.2 8 5±0.3 0.3 0.25 1 0.15 0.1 AIR FLOW 35±0.5 0.2 .5 Ø2 2- 35±0.5 0.05 0 0 0.2 0.4 0.6 0.8 1 ( Units : mm ) 7+0.5 -0.2 Static Pressure (Inch-H2O) 150±20 UL1571,#28AWG Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 64 Curve 1 45x45x20 mm NEW 4.6 CFM P/N Rating Voltage Bearing VAPO GB1245PKV1-8AY 11.Z.X.GN Power Current Power Consumption Speed Air Flow Static Pressure Noise (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) 12 0.04 3500 4.6 0.22 21 0.48 Weight Curve (g) 22.64 1 300±50 5±0.3 22.3±0.3 45±0.5 0.15 UL1061,#26AWG 21.4±0.3 0.2 20.4±0.3 0.25 2-Ø3± 0.3 25.5±0.3 0.1 16.25±0.3 45±0.5 0 20 +0.5 -0 0.05 0 1 2 3 4 5 ( Units : mm ) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 65 50x50x15 mm 2.3~4.7 CFM P/N Rating Voltage Bearing VAPO GB1205PHVX-8AY GB1205PHV1-8AY GB1205PHV2-8AY GB1205PHV3-8AY GN GN GN GN Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 12 0.17 0.10 0.06 0.044 2.0 1.2 0.7 0.5 6000 5000 4000 3000 4.7 4.0 3.0 2.3 0.97 0.67 0.40 0.16 42.2 39.8 33.4 27.0 30 30 30 30 Curve 1 2 3 4 51.6 +- 0.5 25.4 +- 2 300 +- 50 0.6 0.3 0.7 20.1 +- 0.3 UL1061,#26AWG 1 0.8 0.5 0.4 2- 20 +- 0.3 51.6 +- 0.5 4 5 +- 0.3 0.2 27.7 +- 0.3 5 3 0.3 4. 0.1 0 0 1 2 3 4 5 ( Units : mm ) 15 +- 0.5 Static Pressure (Inch-H2O) 1 0.9 Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 66 50x50x20 mm 4.8~5.7 CFM Rating Voltage Bearing VAPO GN GN GN Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 0.124 0.104 0.088 1.5 1.3 1.1 5200 4800 4400 5.7 5.2 4.8 0.66 0.56 0.46 35 33 30 33 33 33 2- 0.6 1 50 +- 0.5 0.5 2 25 +- 0.3 0.4 3 0.3 UL1061,#26AWG 23 +- 0.3 20 +- 0.3 5 4. 26.8 +- 0.3 0.2 20 +- 0.3 50 +- 0.5 0.1 0 0 1 2 3 4 5 6 ( Units : mm ) 20 +- 0.5 0 Static Pressure (Inch-H2O) 0.7 5 +- 0.3 GB1205PKV1-8AY GB1205PKV2-8AY GB1205PKV3-8AY Power Current 300 +- 50 P/N Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 67 Curve 1 2 3 60x60x15 mm 3.5~5.2 CFM P/N Bearing VAPO GN GN GN Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 12 12 0.105 0.07 0.04 1.3 0.8 0.5 4800 4200 3200 5.2 4.7 3.5 0.44 0.32 0.18 40.5 36.0 29.0 45 45 45 Curve 1 2 3 0.45 27 +- 0.3 0.4 23 +- 0.3 5.6 3- 3 0.05 0 2 4 6 ( Units : mm ) 23 +- 0.3 5 60 +- 0.5 4. 33.2 +- 0.3 0.1 3- 0.15 300 +- 50 0.2 5 +- 0.3 2 60 +- 0.5 0.25 UL2468,#26AWG 29.1 +- 0.3 1 0.3 25 +- 0.3 0.35 15.4 +- 0.5 Static Pressure (Inch-H2O) GB1206PHV1-AY GB1206PHV2-AY GB1206PHV3-AY Rating Voltage Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 68 60x60x25 mm NEW 7.3 CFM P/N Bearing VAPO 13.Z.X.GN Power Current Power Consumption Speed Air Flow Static Pressure Noise Weight (VDC) (AMP) (WATTS) (RPM) (CFM) (Inch-H2O) (dBA) (g) 12 0.14 1.7 3600 7.3 0.58 32.4 55 Curve 1 0.6 2.75±0.3 2-Ø4 1 5±0.3 0.3 0.2 53.75±0.3 25±0.5 0.1 0 8.9±0.3 UL1061,#26AWG 0.4 54.9±0.3 0.5 300±50 .5±0.3 AIR FLOW Static Pressure (Inch-H2O) GB1206PTV2-AY Rating Voltage 0 2 4 6 8 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 69 75x75x30 mm 7.5~13.6 CFM Model P/N Bearing 2BALL Sleeve PMB1275PNB1-AY PMB1275PNB2-AY PMB1275PNB3-AY PMB1275PNB4-AY PMB2475PNB1-AY PMB2475PNB2-AY PMB2475PNB3-AY PMB2475PNB4-AY (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 3400 3000 2400 1900 3400 3000 2400 1900 13.6 12.3 9.6 7.5 13.6 12.3 9.6 7.5 0.60 0.48 0.27 0.15 0.60 0.48 0.27 0.15 43.5 40.5 33.9 28.0 43.5 40.5 33.9 28.0 86.5 86.5 86.5 86.5 86.5 86.5 86.5 86.5 Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 12 12 12 12 24 24 24 24 0.30 0.23 0.13 0.08 0.17 0.14 0.08 0.05 3.6 2.8 1.6 1.0 4.1 3.4 1.9 1.2 1 2 3 4 1 2 3 4 UL1007,#26AWG 0.7 0.6 37.9 +- 0.3 0.4 2 2- 0.3 4.5 3 0.2 5 +- 0.3 4 0.1 0 3 6 9 12 15 ( Units : mm ) Airflow (CFM) 39.9 +- 0.3 75.7 +- 0.5 30 +- 0.3 0 30.9 +- 0.3 *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 70 75.7 +- 0.5 24.1 +- 0.3 1 0.5 300 +- 50 Static Pressure (Inch-H2O) Curve 97x94x33 mm 22.4~30.5 CFM Model P/N Bearing 2BALL Sleeve PMB1297PYB1-AY PMB1297PYB2-AY PMB1297PYB3-AY PMB2497PYB1-AY PMB2497PYB2-AY PMB2497PYB3-AY PMB4897PYB1-AY PMB4897PYB2-AY PMB4897PYB3-AY (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN (2).GN Rating Voltage Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 3600 3200 2700 3600 3200 2700 3600 3200 2700 30.5 26.6 22.4 30.5 26.6 22.4 30.5 26.6 22.4 0.92 0.65 0.43 0.92 0.65 0.43 0.92 0.65 0.43 55.8 53.1 50.0 55.8 53.1 50.0 55.8 53.1 50.0 185 185 185 185 185 185 185 185 185 Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 12 12 12 24 24 24 48 48 48 0.72 0.56 0.30 0.39 0.25 0.16 0.17 0.13 0.09 8.6 6.7 3.6 9.4 6.0 3.8 8.2 6.2 4.3 1 2 3 1 2 3 1 2 3 0.8 1 0.7 0.5 50 +- 0.3 0.6 97.2 +- 0.5 39 +- 0.3 UL1007,#24AWG 300 +- 50 2 2- 0.4 0.3 4. 5 3 5 +- 0.3 Static Pressure (Inch-H2O) 1 0.9 32 +- 0.3 51.9 +- 0.3 94.4 +- 0.5 0.2 33 +- 0.3 0.1 0 0 7 14 21 28 35 ( Units : mm ) Airflow (CFM) *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 71 Curve 120x120x32 mm 31.4~35.9 CFM Model P/N Bearing 2BALL Sleeve (2).GN (2).GN (2).GN (2).GN (2).GN Air Flow Static Pressure Noise Weight (RPM) (CFM) (Inch-H2O) (dBA) (g) 2500 2100 2500 2100 2100 35.9 31.4 35.9 31.4 31.4 0.89 0.64 0.89 0.64 0.64 53.8 49.6 53.8 49.6 49.6 250 250 250 250 250 Power Current Power Consumption Speed (VDC) (AMP) (WATTS) 12 12 24 24 48 0.82 0.45 0.38 0.24 0.12 9.8 5.4 9.1 5.8 5.8 5 +- 0.3 300 +- 50 UL1007,#24AWG 9- 65.2 +- 0.3 43.25 +- 0.3 48.75 +- 0.3 50.25 +- 0.3 41.75 +- 0.3 105 +- 0.3 120 +- 0.5 105 +- 0.3 3 0.45 42.6 +- 0.3 37.9 +- 0.3 45.4 +- 0.3 52.9 +- 0.3 2 0.6 45.4 +- 0.3 0.75 59.6 +- 0.3 0.3 7.5 21.75 +- 0.3 120 +- 0.5 47.3 +- 0.3 0 10 20 30 40 ( Units : mm ) 2 +- 0.3 2 +- 0.3 2 +- 0.3 Airflow (CFM) 32 +- 0.3 61 +- 0.3 2 +- 0.3 37.7 +- 0.3 0.15 5 +- 0.3 Static Pressure (Inch-H2O) 0.9 4.3 + - 0.3 PMB1212PLB2-A PMB1212PLB3-A PMB2412PLB2-A PMB2412PLB3-A PMB4812PLB3-A Rating Voltage *All model could be customized. Please contact with Sunon Sales. *Specifications subject to change without notice. Please Visit SUNON web site at http://www.sunon.com for update information. 72 Curve 1 2 1 2 2 Headquarters: Sunonwealth Electric Machine Industry Co., Ltd. No.30, Lane 296, Sinya Rd., Cianjhen District, Kaohsiung City 806, Taiwan TEL : +886-7-8135888 FAX :+886-7-8230505/8230606/8231010 URL: http://www.sunon.com E-mail: sunon@email.sunon.com.tw Sunon Inc. (U.S.A.) 1075 West Lambert Road Suite A, Brea, California 92821, U.S.A TEL : +1-714-255-0208 FAX :+ 1-714-255-0802 URL : http://www.sunonusa.com E-mail : info@sunon.com Sunon SAS (Europe) Parc Medicis, 66, Ave Des Pepinieres 94832, Fresnes Cedex-France TEL : +33-1-46154515 FAX : +33-1-46154510 URL: http://www.sunoneurope.com E-mail : info@sunoneurope.com Sunonwealth Electric Machine Industry (HK) Ltd. (Hong Kong) 1210 Grand City Plaza, 1 Sai Lau Kok Road, Tsuen Wan, Hong Kong ,China TEL : + 852-24-111-388 FAX : + 852-24-050-707 E-mail : info@sunon.com.hk Sunon Shen Zhen Office (Shen Zhen, China) TEL : +86-755-26880688 FAX :+86-755-26880288 E-mail : info@sunon.com.cn Sunon Guangzhou Office (Guangzhou, China) TEL : +86-20-87788928 FAX :+86-20-87786786 Sunon Taipei Office(Taipei) 5F., No.194, Jhouzih St., Neihu District, Taipei City 114, Taiwan TEL: 02-27992383 FAX: 02-27972190 Sunon Corporation (Japan) Stork Minami Otsuka 4Fl.33-1, 2 Chome, Minami Otsuka Toshimaku, Tokyo, Japan 170-0005 TEL : +81-3-5395-3069 FAX: +81-3-5395-3080 URL: http://www.sunon.co.jp E-mail : info@sunon.co.jp 2009 2009/8/20(131-4)
PMD1212PMB1-A(2).GN.IP55 价格&库存
很抱歉,暂时无法提供与“PMD1212PMB1-A(2).GN.IP55”相匹配的价格&库存,您可以联系我们找货
