Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
74LVT162374
3.3 V 16-bit edge-triggered D-type flip-flop with 30 Ω
termination resistors; 3-state
Rev. 03 — 17 January 2005
Product data sheet
1. General description
The 74LVT162374 is a high performance BiCMOS product designed for VCC operation at
3.3 V.
The 74LVT162374 is designed with 30 Ω series resistance in both the HIGH and LOW
states of the output. This design reduces line noise in applications such as memory
address drivers, clock drivers, and bus receivers/transmitters.
This device is a 16-bit edge-triggered D-type flip-flop featuring non-inverting 3-state
outputs. The device can be used as two 8-bit flip-flops or one 16-bit flip-flop. On the
positive transition of the clock (CP), the Q outputs of the flip-flop take on the logic levels
set up at the D inputs.
2. Features
16-bit edge-triggered flip-flop
3-state buffers
Output capability: +12 mA and −12 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Bus-hold data inputs eliminate the need for external pull-up resistors to hold unused
inputs
Live insertion and extraction permitted
Outputs include series resistance of 30 Ω making external resistors unnecessary
Power-up reset
Power-up 3-state
No bus current loading when output is tied to 5 V bus
Latch-up protection exceeds 500 mA per JESD78
ESD protection:
◆ MIL STD 883 method 3015: exceeds 2000 V
◆ Machine model: exceeds 200 V
74LVT162374
3. Quick reference data
Table 1:
Tamb = 25 °C.
Symbol
Parameter
tPLH, tPHL propagation delay
nCP to nQn
Conditions
Min
Typ
Max
Unit
CL = 50 pF; VCC = 3.3 V
3.0
ns
CI
input capacitance
VI = 0 V or 3.0 V
3
pF
CO
output capacitance
outputs disabled;
VO = 0 V or 3.0 V
9
pF
ICC
supply current
outputs disabled;
VCC = 3.6 V
70
µA
4. Ordering information
Table 2:
Type number
Package
Temperature range Name
74LVT162374DGG −40 °C to +85 °C
74LVT162374DL
−40 °C to +85 °C
Description
Version
TSSOP48
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
SSOP48
plastic shrink small outline package; 48 leads;
body width 7.5 mm
SOT370-1
9397 750 14401
Product data sheet
© Koninklijke Philips Electronics N.V. 2005. All rights reserved.
2 of 17
74LVT162374
5. Functional diagram
47
46
44
43
41
40
38
37
1
1OE
48
1CP
24
2OE
25
2CP
1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7
48
1CP
1
1OE
1D0
1D1
1D2
1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7
1D3
2
3
5
6
8
9
11
1D4
12
1D5
36
35
33
32
30
29
27
1D6
26
1D7
2D0
2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7
2D1
25
2D2
2CP
2D3
24
2OE
2D4
2D5
2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7
2D6
2D7
13
14
16
17
19
1EN
C3
2EN
C4
47
3D
2
1
46
3
44
5
43
6
41
8
40
9
38
11
37
12
36
2
4D
13
35
14
33
16
32
17
30
19
29
22
26
23
23
1Q0
1Q1
1Q2
1Q3
1Q4
1Q5
1Q6
1Q7
2Q0
2Q1
2Q2
2Q3
2Q4
2Q5
2Q6
2Q7
001aaa254
001aac369
Fig 1. Logic symbol
nD0
Fig 2. IEC logic symbol
nD1
D
CP
nD2
D
Q
CP
nD3
D
Q
CP
nD4
D
Q
CP
nD5
D
Q
CP
nD6
D
Q
CP
nD7
D
Q
CP
D
Q
CP
Q
nCP
nOE
nQ0
nQ1
nQ2
nQ3
nQ4
nQ5
nQ6
nQ7
001aac371
Fig 3. Logic diagram
9397 750 14401
Product data sheet
3 of 17
74LVT162374
VCC
27 Ω
output
27 Ω
001aac372
Fig 4. Output schematic (one output)
6. Pinning information
6.1 Pinning
1OE
1
48 1CP
1Q0
2
47 1D0
1Q1
3
46 1D1
GND
4
45 GND
1Q2
5
44 1D2
1Q3
6
43 1D3
VCC
7
42 VCC
1Q4
8
41 1D4
1Q5
9
40 1D5
GND 10
39 GND
1Q6 11
38 1D6
1Q7 12
2Q0 13
37 1D7
162374
36 2D0
2Q1 14
35 2D1
GND 15
34 GND
2Q2 16
33 2D2
2Q3 17
32 2D3
VCC 18
31 VCC
2Q4 19
30 2D4
2Q5 20
29 2D5
GND 21
28 GND
2Q6 22
27 2D6
2Q7 23
26 2D7
2OE 24
25 2CP
001aac370
Fig 5. Pin configuration
9397 750 14401
Product data sheet
4 of 17
74LVT162374
6.2 Pin description
Table 3:
Pin description
Symbol
Pin
Description
1OE
1
output enable input (active LOW)
1Q0
2
data output
1Q1
3
data output
GND
4
ground (0 V)
1Q2
5
data output
1Q3
6
data output
VCC
7
supply voltage
1Q4
8
data output
1Q5
9
data output
GND
10
ground (0 V)
1Q6
11
data output
1Q7
12
data output
2Q0
13
data output
2Q1
14
data output
GND
15
ground (0 V)
2Q2
16
data output
2Q3
17
data output
VCC
18
supply voltage
2Q4
19
data output
2Q5
data output
GND
21
ground (0 V)
2Q6
22
data output
2Q7
23
data output
2OE
24
2CP
25
clock pulse input (active rising edge)
2D7
26
data input
2D6
27
data input
GND
28
ground (0 V)
2D5
29
data input
2D4
30
data input
VCC
31
supply voltage
2D3
32
data input
2D2
33
data input
GND
34
ground (0 V)
2D1
35
data input
2D0
36
data input
1D7
37
data input
1D6
38
data input
GND
39
ground (0 V)
9397 750 14401
Product data sheet
5 of 17
74LVT162374
Table 3:
Pin description
Symbol
Pin
Description
1D5
40
data input
1D4
41
data input
VCC
42
supply voltage
1D3
43
data input
1D2
44
data input
GND
45
ground (0 V)
1D1
46
data input
1D0
47
data input
1CP
48
7. Functional description
7.1 Function table
Table 4:
Function table [1]
Operating mode
Input
Internal register Output
nOE
nCP
nDn
Load and read
register
L
l
L
L
L
h
H
H
Hold
L
NC
X
NC
NC
Disable outputs
[1]
nQ0 to nQ7
H
NC
X
NC
Z
H
nDn
nDn
Z
H = HIGH voltage level;
h = HIGH voltage level one set-up time prior to the HIGH-to-LOW clock transition;
L = LOW voltage level;
l = LOW voltage level one set-up time prior to the HIGH-to-LOW clock transition;
NC = no change;
X = don’t care;
Z = high-impedance OFF-state;
↑ = LOW-to-HIGH clock transition.
8. Limiting values
Table 5:
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to
GND (ground = 0 V)
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input diode current
VI < 0 V
[1]
VI
input voltage
IOK
output diode current
VO < 0 V
VO
output voltage
output in OFF-state or
HIGH-state
9397 750 14401
Product data sheet
[1]
Min
Max
Unit
−0.5
+4.6
V
−50
mA
−0.5
+7.0
V
−50
mA
−0.5
+7.0
V
6 of 17
74LVT162374
Table 5:
Limiting values …continued
GND (ground = 0 V)
Symbol
Parameter
Conditions
Min
Max
Unit
IO
output current
output in LOW-state
128
mA
−64
mA
Tstg
storage temperature
−65
+150
°C
150
°C
output in HIGH-state
[2]
junction temperature
Tj
[1]
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings
are observed.
[2]
The performance capability of a high-performance integrated circuit in conjunction with its thermal
9. Recommended operating conditions
Table 6:
Symbol
Parameter
VCC
VI
Conditions
Min
Typ
Max
Unit
supply voltage
2.7
3.6
V
input diode voltage
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
IOH
HIGH-level output
current
−12
mA
IOL
LOW-level output current
12
mA
∆t/∆V
input transition rise or fall outputs enabled
rate
10
ns/V
Tamb
ambient temperature
−40
+85
°C
10. Static characteristics
Table 7:
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Tamb = −40 °C to +85
Conditions
Min
Typ
Max
Unit
°C [1]
VIK
input clamp voltage
VCC = 2.7 V; IIK = −18 mA
−0.85
−1.2
V
VOH
HIGH-level output voltage
VCC = 3.0 V; IOH = −12 mA
2.0
V
VOL
LOW-level output voltage
VCC = 3.0 V; IOL = 12 mA
0.8
V
0.1
0.55
V
0.1
±1
µA
VRST
power-up output low voltage VCC = 3.6 V; IO = 1 mA;
VI = GND or VCC
ILI
input leakage current
control pins
I/O data pins
IOFF
output off current
VCC = 3.6 V; VI = VCC or GND
VCC = 0 V or 3.6 V; VI = 5.5 V
0.4
10
µA
0.1
1
µA
VCC = 3.6 V; VI = 0 V
−0.4
−5
µA
VCC = 0 V; VI or VO = 0 V to 4.5 V
0.1
±100
µA
9397 750 14401
Product data sheet
[2]
7 of 17
74LVT162374
Table 7:
Static characteristics …continued
Symbol
IHOLD
Parameter
bus hold current D inputs
Conditions
VCC = 3 V; VI = 0.8 V
[4]
VCC = 3 V; VI = 2.0 V
Min
Typ
Max
Unit
75
135
µA
−75
−135
µA
VCC = 0 V to 3.6 V; VI = 3.6 V
±500
µA
IEX
external current into output
output in HIGH-state when
VO > VCC; measured at VO = 5.5 V
and VCC = 3.0 V
50
125
µA
IPU, IPD
power-up or power-down
3-state output current
VCC ≤ 1.2 V; VO = 5.0 V to VCC;
VI = GND or VCC; nOE and
nOE = don’t care
1
±100
µA
IOZH
3-state output HIGH current
VCC = 3.6 V; VO = 3.0 V;
VI = VIH or VIL
0.5
5
µA
IOZL
3-state output LOW current
VCC = 3.6 V; VO = 0.5 V;
VI = VIH or VIL
+0.5
−5
µA
ICC
quiescent supply current
VCC = 3.6 V; VI = GND or VCC;
IO = 0 A
0.07
0.12
mA
[5]
outputs HIGH
outputs LOW
outputs disabled
4
6
mA
[6]
0.07
0.12
mA
[7]
0.1
0.2
mA
∆ICC
additional supply current per VCC = 3 V to 3.6 V; one input at
input pin
VCC − 0.6 V; other inputs at
VCC or GND
CI
input capacitance
VI = 0 V or 3.0 V
3
pF
CO
output capacitance
outputs disabled; VO = 0 V or 3.0 V
9
pF
[1]
All typical values are at VCC = 3.3 V and Tamb = 25 °C.
[2]
For valid test results, data must not be loaded into the flip-flops (or latches) after applying power.
[3]
Unused pins at VCC or GND.
[4]
This is the bus-hold overdrive current required to force the input to the opposite logic state.
[5]
This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V
a transition time of 100 µs is permitted. This parameter is valid for Tamb = 25 °C only.
[6]
ICC is measured with outputs pulled to VCC or GND.
[7]
This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
Table 8:
Dynamic characteristics
GND = 0 V; tr = tf = 2.5 ns; CL = 50 pF; RL = 500 Ω; for test circuit see Figure 10.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
150
MHz
VCC = 3.3 V ± 0.3 V
1.5
3.0
5.3
ns
VCC = 2.7 V
6.2
ns
°C [1]
fmax
maximum clock frequency
VCC = 3.3 V ± 0.3 V; see Figure 6
tPLH
propagation delay
nCP to nQn
see Figure 6
9397 750 14401
Product data sheet
8 of 17
74LVT162374
Table 8:
Dynamic characteristics …continued
Symbol
Parameter
Conditions
tPHL
propagation delay
nCP to nQn
see Figure 6
output enable time to
HIGH-level
see Figure 7
tPZH
LOW-level
tPZL
output disable time from
HIGH-level
tPHZ
LOW-level
tPLZ
[1]
Min
Typ
Max
Unit
VCC = 3.3 V ± 0.3 V
1.5
3.0
4.9
ns
VCC = 2.7 V
5.1
ns
VCC = 3.3 V ± 0.3 V
1.5
3.5
5.6
ns
VCC = 2.7 V
6.9
ns
VCC = 3.3 V ± 0.3 V
1.5
3.2
4.9
ns
VCC = 2.7 V
6.0
ns
see Figure 8
see Figure 7
VCC = 3.3 V ± 0.3 V
1.5
3.5
5.4
ns
VCC = 2.7 V
5.7
ns
VCC = 3.3 V ± 0.3 V
1.5
3.2
5.0
ns
VCC = 2.7 V
5.1
ns
Min
Typ
Max
Unit
see Figure 8
Table 9:
Dynamic characteristics set-up requirements
GND = 0 V; tr = tf = 2.5 ns; CL = 50 pF; RL = 500 Ω.
Symbol
Parameter
tsu(H), tsu(L) set-up time nDn to nCP
th(H), th(L)
tW(H)
tW(L)
[1]
Conditions
°C [1]
hold time nDn to nCP
nCP pulse width HIGH
nCP pulse width LOW
see Figure 9
VCC = 3.3 V ± 0.3 V
2.0
0.7
ns
VCC = 2.7 V
2.0
ns
VCC = 3.3 V ± 0.3 V
0.8
ns
VCC = 2.7 V
0.1
ns
VCC = 3.3 V ± 0.3 V
1.5
0.6
ns
VCC = 2.7 V
1.5
ns
VCC = 3.3 V ± 0.3 V
3.0
1.6
ns
VCC = 2.7 V
3.0
ns
see Figure 9
see Figure 6
see Figure 6
9397 750 14401
Product data sheet
9 of 17
74LVT162374
12. Waveforms
1/fmax
2.7 V
nCP
VM
VM
VM
0V
tW(H)
tW(L)
tPHL
tPLH
VOH
nQn
VM
VM
VOL
001aac373
VM = 1.5 V; VI = GND to 3.0 V.
VOL and VOH are typical voltage output drop that occur with the output load.
Fig 6. Propagation delay clock input to output, clock pulse width and maximum clock
frequency
2.7 V
nOE
VM
VM
t PZH
t PHZ
VOH
nQn
VOH − 0.3 V
VM
0V
001aac374
VOH is typical voltage output drop that occur with the output load.
Fig 7. 3-state output enable time to HIGH-level and output disable time from HIGH-level
2.7 V
nOE
VM
VM
tPZL
tPLZ
3.0 V
nQn
VM
VOL + 0.3 V
VOL
001aac375
VOL is typical voltage output drop that occur with the output load.
Fig 8. 3-state output enable time to LOW-level and output disable time from LOW-level
9397 750 14401
Product data sheet
10 of 17
74LVT162374
2.7 V
nDn
VM
VM
VM
VM
0V
tsu(H)
th(H)
tsu(L)
th(L)
2.7 V
nCP
VM
VM
0V
001aac376
Remark: The shaded areas indicate when the input is permitted to change for predictable
output performance.
Fig 9. Data set-up and hold times
VI
tW
90 %
negative
pulse
90 %
VM
10 %
0V
VI
tTHL(tf)
tTLH(tr)
tTLH(tr)
tTHL(tf)
90 %
positive
pulse
0V
VM
VM
VM
10 %
10 %
tW
001aac221
VM = 1.5 V.
a. Input pulse definition
VEXT
VCC
PULSE
GENERATOR
VI
RL
VO
D.U.T.
RT
CL
RL
mna616
Test data is given in Table 10.
Definitions:
RL = Load resistor.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = Test voltage for switching times.
b. Test circuit
Fig 10. Load circuitry for switching times
9397 750 14401
Product data sheet
11 of 17
74LVT162374
Table 10:
Test data
Supply
voltage
Repetition rate Input
2.7 V
≤ 10 MHz
tW
Load
tr, tf
CL
500 ns ≤ 2.5 ns 50 pF
9397 750 14401
Product data sheet
VEXT
RL
tPHZ, tPZH tPLZ, tPZL tPLH, tPHL
500 Ω
GND
6V
open
12 of 17
74LVT162374
13. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
E
D
A
X
c
HE
y
v M A
Z
48
25
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
detail X
24
w M
bp
e
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
12.6
12.4
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.8
0.4
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT362-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 11. Package outline SOT362-1 (TSSOP48)
9397 750 14401
Product data sheet
13 of 17
74LVT162374
SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm
SOT370-1
D
E
A
X
c
y
HE
v M A
Z
25
48
Q
A2
A1
A
(A 3)
θ
pin 1 index
Lp
L
24
1
detail X
w M
bp
e
10 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2.8
0.4
0.2
2.35
2.20
0.25
0.3
0.2
0.22
0.13
16.00
15.75
7.6
7.4
0.635
10.4
10.1
1.4
1.0
0.6
1.2
1.0
0.25
0.18
0.1
0.85
0.40
8
o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT370-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-118
Fig 12. Package outline SOT370-1 (SSOP48)
9397 750 14401
Product data sheet
14 of 17
74LVT162374
14. Revision history
Table 11:
Revision history
Document ID
Release date
Data sheet status
Change notice
Doc. number
Supersedes
74LVT162374_3
20050117
Product data sheet
9397 750 14401
74LVT162374_2
Modifications:
The format of this data sheet is redesigned to comply with the current presentation and
information standard of Philips Semiconductors.
Section 2 “Features”: Changed JEDEC Std 17 into JESD78
Table 1 “Quick reference data”:Changed tPLH and tPHL propagation delays nCP to nQn to 3.0 ns
Table 9 “Dynamic characteristics set-up requirements”: Changed the minimum values of th(H)
and th(L) hold time nDn to nCP to 0.8 ns
74LVT162374_2
20040922
Product specification
9397 750 14087
74LVT162374_1
74LVT162374_1
19990923
9397 750 06508
9397 750 14401
Product data sheet
15 of 17
74LVT162374
15. Data sheet status
Level
Data sheet status [1]
Product status [2] [3]
Definition
I
Objective data
Development
This data sheet contains data from the objective specification for product development. Philips
Semiconductors reserves the right to change the specification in any manner without notice.
II
Preliminary data
Qualification
This data sheet contains data from the preliminary specification. Supplementary data will be published
at a later date. Philips Semiconductors reserves the right to change the specification without notice, in
order to improve the design and supply the best possible product.
III
Product data
Production
This data sheet contains data from the product specification. Philips Semiconductors reserves the
right to make changes at any time in order to improve the design, manufacturing and supply. Relevant
changes will be communicated via a Customer Product/Process Change Notification (CPCN).
[1]
Please consult the most recently issued data sheet before initiating or completing a design.
[2]
The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at
URL http://www.semiconductors.philips.com.
[3]
For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status.
16. Definitions
17. Disclaimers
Short-form specification — The data in a short-form specification is
extracted from a full data sheet with the same type number and title. For
detailed information see the relevant data sheet or data handbook.
Life support — These products are not designed for use in life support
appliances, devices, or systems where malfunction of these products can
reasonably be expected to result in personal injury. Philips Semiconductors
customers using or selling these products for use in such applications do so
at their own risk and agree to fully indemnify Philips Semiconductors for any
damages resulting from such application.
Limiting values definition — Limiting values given are in accordance with
the Absolute Maximum Rating System (IEC 60134). Stress above one or
more of the limiting values may cause permanent damage to the device.
These are stress ratings only and operation of the device at these or at any
other conditions above those given in the Characteristics sections of the
specification is not implied. Exposure to limiting values for extended periods
may affect device reliability.
Application information — Applications that are described herein for any
of these products are for illustrative purposes only. Philips Semiconductors
make no representation or warranty that such applications will be suitable for
the specified use without further testing or modification.
Right to make changes — Philips Semiconductors reserves the right to
make changes in the products - including circuits, standard cells, and/or
software - described or contained herein in order to improve design and/or
performance. When the product is in full production (status ‘Production’),
relevant changes will be communicated via a Customer Product/Process
Change Notification (CPCN). Philips Semiconductors assumes no
responsibility or liability for the use of any of these products, conveys no
license or title under any patent, copyright, or mask work right to these
products, and makes no representations or warranties that these products are
free from patent, copyright, or mask work right infringement, unless otherwise
specified.
18. Contact information
For additional information, please visit: http://www.semiconductors.philips.com
For sales office addresses, send an email to: sales.addresses@www.semiconductors.philips.com
9397 750 14401
Product data sheet
16 of 17
74LVT162374
19. Contents
1
2
3
4
5
6
6.1
6.2
7
7.1
8
9
10
11
12
13
14
15
16
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5
Functional description . . . . . . . . . . . . . . . . . . . 6
Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6
Recommended operating conditions. . . . . . . . 7
Static characteristics. . . . . . . . . . . . . . . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 16
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Contact information . . . . . . . . . . . . . . . . . . . . 16
All rights are reserved. Reproduction in whole or in part is prohibited without the prior
written consent of the copyright owner. The information presented in this document does
not form part of any quotation or contract, is believed to be accurate and reliable and may
be changed without notice. No liability will be accepted by the publisher for any
consequence of its use. Publication thereof does not convey nor imply any license under
patent- or other industrial or intellectual property rights.
Date of release: 17 January 2005
Document number: 9397 750 14401
Published in The Netherlands
