SUNON
SPECIFICATION FOR APPROVAL
CUSTOMER
DESCRIPTION
DC BRUSHLESS FAN
DIMENSIONS
50x50x10 mm
MODEL
KD1205PFB2
P/N
H
APPROVED NO
APPROVED BY
(AUTHORIZED)
DAWN.
Fanny 11/8
CHKD.
Kiddy
APPD.
Tanill
SPEC.NO
D500680
ISSUE DATE
11.08.2000
EDITION
REVISE DATE
E.SPEC
ED50143
建準電機工業股份有限公司
SUNONWEALTH ELECTRIC MACHINE INDUSTRY CO., LTD.
12FL., 120 CHUNG CHENG 1ST RD.,
TEL:886-7-7163069(41 LINES)
KAOHSIUNG, TAIWAN, R. O. C.
FAX:886-7-7163086~89
SUNON
DC BRUSHLESS FAN
MODEL: KD1205PFB2
:H
P/N
CHARACTERISTICS
1. Motor Design
Patented single-coil DC brushless 4 poles motor
Design.
2. Insulation Resistance
More than 500M ohm between internal stator and
lead wire(+) measured by DC 500V.
3. Dielectric Strength
Applied AC 500V for one minute or AC 600V for
2 seconds between housing and lead wire(+)
4. Noise Level
Measured in an semi-anechoic chamber
with background noise level below 15
dB(A). The fan is running in free air with
Microphone at a distance of one meter
from the fan intake.
5. Input power, Current & Speed
Measured after continuous 30 minutes
Operation at rated voltage in clean air
at ambient temperature of 25 degrees C.
6. Tolerances
±15% on rated power and current.
7. Motor Protection
Locked rotor protected.
8. Air Performance
Measured by a double chamber. The value
are recorded when the fan speed is stabilized
at rated voltage.
SPEC.NO
D500680
建準電機工業股份有限公司
ISSUE DATE 11. 08. 2000
PA G E
2 OF 6
REVISE DATE
E D I T I O N 0
SUNON
SPECIFICATIONS
MODEL: KD1205PFB2
P/N
:H
1-1. Rated Voltage
12 VDC
1-2. Operating Voltage Range
5-13.8 VDC
1-3. Starting Voltage
5 VDC
1-4. Rated Speed
5000 RPM ± 700 RPM
1-5. Air Delivery
9.5 CFM
1-6. Static Pressure
0.10 Inch-H2O
1-7. Rated Current
0.10 AMP
1-8. Rated Power
1.2 WATTS
1-9. Noise Level
28.9 dB(A)
1-10. Direction of Rotation
Counter-clockwise viewed front fan blade
1-11. Operating Temperature
-10 to +70 Deg.C
1-12. Storage Temperature
-40 to +70 Deg.C
1-13. Bearing System
Precise ball bearing system
1-14. Weight
23 g
1-15. Safety
UL/CUR/TUV/CE Approvals
1-16. Vibration
Vibration of acceleration 1.5G and
Frequency 5~50~5Hz is applied in the
3 directions(X,Y,Z) for 30 minutes, each
Direction at the cycle of 1 minute.
SPEC.NO
D500680
建準電機工業股份有限公司
PA G E
3 OF 6
REVISE DATE
E D I T I O N 0
SUNON
MODEL : KD1205PFB2
:H
P/N
PERFORMANCE CURVES
STATIC
PRESSURE
mm-H2O
Inch-H2O
3
0.10
12 VDC
2
0.05
1
CFM
10
0.14
0.28
m3/min
SPEC.NO
D500680
建準電機工業股份有限公司
PA G E
4 OF 6
REVISE DATE
E D I T I O N 0
SUNON
MATERIAL
2-1. Frame
Thermoplastic PBT of UL 94V-0
2-2. Impeller
2-3. Bobbin
2-4. Lead Wire
UL2468,26AWG,+RED;-BLACK
DIMENSIONS
1.Air Flow Direction: Label side.
2.The Best Mounting Direction: In any orientation.
:mm
UNITS:
SPEC.NO
D500680 REVISE DATE
建準電機工業股份有限公司
ISSUE DATE 11. 08. 2000 E D I T I O N 0
PA G E
5 OF 6
SUNON
Notes
1. SUNON will not guarantee the products if the application of our products is exceeded
the limitation which is specified on this specification.
2. In case of change of the specification specified on this document, a written notice is
requested in advance.
3. Please do not touch the impeller with pressure and never bring the fan with lead wire.
The bearings and lead wire may be damaged.
4. No guarantee on the products against the safety problem or failure caused by powder
dust, drop of water or insect.
5. If there is any data or related documentation different from this data sheet, this data
sheet is the principal reference.
6. For the purpose of MIS, please indicate SPEC No. on every order.
7. In case of the fan has no polarity protection function, wires with same color (electrode)
must be connected together during the assembly. (i.e. red + red, black + black)
or the fan will be damaged immediately.
8. Please do not use the fan in the environment of corrosive gas or liquid or any detrimental
gas.
9. Please do not store the fan in the environment of high / low temperature, high humidity
or any detrimental gas. Please store the fan within 6 months, every 6 months, there
shall be a linkage of electric current to the fan, even though the fan is stored in room
temperature.
10.While the fan is in operation, please do not lock the fan intentionally for a long period of
time, since the continuous stoppage will result in over-heat and damage of the fan.
11.During the installation of the fan, please pay substantial attention to possible noise
cause by resonance vibration and vibration.
12.During the testing of the fan, please be sure to use finger guard to insure safety.
13.Unless otherwise specified, if there is any doubt in the judgement, the temperature and
relative humidity range of environment will be take in according to the standard test
℃ and 65%.
condition as 25℃
SPEC.NO
D500680 REVISE DATE
建準電機工業股份有限公司
PA G E
6 OF 6
很抱歉,暂时无法提供与“KD1205PFB2H”相匹配的价格&库存,您可以联系我们找货
