FBA06T12HS
FBA06T12HS
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 60X15MM 12VDC WIRE
FBA06T12HS 数据手册
FBA06T (60mm Thin) 60 15 50 Panaflo FLOW 4-ø4 ROTATION CUT OUT 58 58 50 ø6 5 50 Inlet/Outlet 4-ø4.2 Features • Operating Temperature: -10°C — +70°C (65% RH) • Aerodynamic blade and venturi design • Storage Temperature: -40°C — +75°C (65% RH) • Locked rotor protection and auto-start function • Bearing Type: Hydro Wave • Lower circuit noise by new IC • Optional third lead wire signal (Locked rotor alarm sensor) Basic Data (nominal at room temperature) 10 3 50 60 3 Rated Voltage (V) Operating Voltage (V) Rated Current (mA) Rated Input (W) Nominal Speed (r/min) Maximum Air Flow FBA06T12L 12 7 — 13.8 88 1.06 3200 0.34 12.0 2.80 27.5 24.0 FBA06T12H 12 7 — 13.8 145 1.74 4200 0.47 16.6 4.75 46.6 32.0 FBA06T24L 24 14 — 27.6 56 1.34 3200 0.34 12.0 2.80 27.5 24.0 FBA06T24H 24 14 — 27.6 83 1.99 4200 0.47 16.6 4.75 46.6 32.0 (m3/min) (CFM) Maximum Air Pressure (mmH2O) (Pa) Noise (dB-A) FBA06T (60mm Thin) 3 6 (r/min) 60 FBA06T12L / FBA06T24L 6000 4 20 2 12V (24V) 4000 10.2V (20.4V) 0 2000 0.2 0.4 0.6 N 7V (14V) (m3/min) 10 300 + (red) - (black) 40 P Air Pressure 13.8V (27.6V) Nominal Speed (mmH20) Panaflo® (Pa) Characteristics 20 10 Q (CFM) Air Flow (r/min) 6000 Air Pressure 12V (24V) 40 4 20 2 0 10.2V (20.4V) 7V (14V) 0.2 0.4 Q 0.6 20 10 Weight 50 grams ( 1.76 ounces) Case Quantity 100 per box 13.8V (27.6V) 4000 Nominal Speed 6 2000 N Size 60.0 x 60.0 x 15.0 (2.36 x 2.36 x 0.59) 60 FBA06T12H / FBA06T24H P Lead Wire All lead wires are 325 mm. in length ± 15 mm. Housing and Fan Blade: Plastic (PET, PBT, ABS) (mmH20) All dimensions in mm. (Pa) strip and tin (m3/min) (CFM) Air Flow P— Q N— Q Conversion Factors 1 mm H2O = 9.8 PA 1 m3/min = 35.313 CFM 13
FBA06T12HS 价格&库存
很抱歉,暂时无法提供与“FBA06T12HS”相匹配的价格&库存,您可以联系我们找货
