FBA08T12HS
FBA08T12HS
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X15MM 12VDC WIRE
FBA08T12HS 数据手册
FBA08T (80mm Thin) 15 80 3 80 Panaflo 4-ø4.5 FLOW ROTATION CUT OUT 78 71.5 ø ø8 84 I 9 O nle utl t et 78 71.5 Inlet/Outlet 4-ø4.7 Features • Operating Temperature: -10°C — +70°C (65% RH) • Aerodynamic blade and venturi design • Storage Temperature: -40°C — +75°C (65% RH) • Locked rotor protection and auto-start function • Bearing Type: Hydro Wave • Lower circuit noise by new IC • Optional third wire lead signal (Locked rotor alarm sensor) Basic Data (nominal at room temperature) 14 3 71.5 71.5 Rated Voltage (V) Operating Voltage (V) Rated Current (mA) Rated Input (W) Nominal Speed (r/min) Maximum Air Flow FBA08T12L 12 7 — 13.8 79 0.95 2000 0.62 21.9 1.55 15.2 23.0 FBA08T12H 12 7 — 13.8 200 2.40 3100 0.95 33.5 3.20 31.4 34.0 FBA08T24L 24 14 — 27.6 47 1.13 2000 0.62 21.9 1.55 15.2 23.0 FBA08T24H 24 14 — 27.6 110 2.64 3100 0.95 33.5 3.20 31.4 34.0 (m3/min) (CFM) Maximum Air Pressure (mmH2O) (Pa) Noise (dB-A) FBA08T (80mm Thin) 3.0 15 1.5 10.2V (20.4V) 7V (14V) 1.0 1.5 50 25 (mmH20) Lead Wire All lead wires are 325 mm in length ± 15 mm. 45 4.5 (m3/min) (CFM) Air Flow FBA08T12H/FBA08T24H 13.8V (27.6V) (r/min) (Pa) 6.0 3000 3.0 15 1.5 10.2V (20.4V) 7V (14V) 2000 1000 N 30 P Air Pressure 12V (24V) 0 0.5 1.0 1.5 50 25 Q Case Quantity 100 per box 1000 N 0.5 Q 60 Weight 70 grams (2.47 ounces) 2000 Nominal Speed 0 All dimensions in mm. Size 80.0 x 80.0 x 15.0 (3.15 x 3.15 x 0.59) 3000 12V (24V) strip and tin Housing and Fan Blade: Plastic (PET, PBT, ABS) (r/min) 30 13.8V (27.6V) Nominal Speed (mmH20) 4.5 10 300 + (red) - (black) 45 FBA08T12L/FBA08T24L P Air Pressure Panaflo® (Pa) Characteristics (m3/min) (CFM) Air Flow P— Q N— Q Conversion Factors 1 mm H2O = 9.8 PA 1 m3/min = 35.313 CFM 15
FBA08T12HS 价格&库存
很抱歉,暂时无法提供与“FBA08T12HS”相匹配的价格&库存,您可以联系我们找货
