L37-3L-100-100-1.0-1A
    T-GLOBAL
    L37-3 SHEET 100X100X1MM W/ADH
L37-3L-100-100-1.0-1A 数据手册
L37-3 Thermal Conductive Pad on rolls Features Good thermal conductivity Ultra soft and high compresibility Natural tack Easy to assemble Good insulator Applications Electronic components: IC / CPU / MOS LED / M/B / P/S / Heat Sink / LCD-TV / Notebook PC / PC / Telecom Device / Wireless Hub etc.... DDR II Module / DVD Applications / Hand-Set applications etc... Thermal Resistance V.S Pressure V.S Deflection Properties Thermal Conductivity: 1.7 W/m.k (W / m.k - Z Axis) REACH Compliant RoHS Compliant Hardeness: 5 (Shore A) (Shore A) In the thermal resistance vs pressure vs deflection charts L37-3 provides low thermal impedance.  As the pressure increases the thermal impedance decreases. L37-3 provides good compliance and softness. Property L37-3 Unit Test Method Colour Yellow - Visual Reinforcement carrier Fibreglass mesh Thickness 0.5 mm ASTM D374 Roll Length / Width 50 - 320 Metres / mm ASTM D5470 Thermal Conductivity 1.7 W/m.k ASTM D5470 Flame Rating V-0 - UL 94 Dielectric Breakdown Voltage ›10 kV/mm ASTM D149 Weight Loss ‹1 % ASTM E595 Specific Gravity 2.17 g/cm3 ASTM D792 Working Temperature -40~ +200 ˚C - Volume Resistance ›10 Ohm-cm ASTM D257 Elongation - % ASTM D412 Tensile Strength 66.4 Kgf/cm Standard Shape - Sheet ones - Hardness 5 Shore A ASTM D2240 12 2 ASTM D412 Available with an adhesive backing 1. Part Number 2. Size X-Y-Z 3. Adhesive backing – 0-None, 1A-one side, 2A-two sides 4. Quantity Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
1. 物料型号:L37-3 Thermal Conductive Pad。 2. 器件简介:该垫具有良好的热导性、超软性、高压缩性、自然粘性,易于组装,并且是良好的绝缘体。 3. 应用信息:适用于电子元件,如IC、CPU、MOS、LED、主板、个人电脑、笔记本、电信设备、无线中心等,以及DDR II模块、DVD应用、手机应用等。 4. 参数特性:包括热阻与压力和偏转的关系图,显示随着压力的增加,热阻降低。垫子具有良好的顺应性和柔软性。热导率为1.7 W/m.k,硬度为5(邵氏A)。 5. 功能详解:文档提供了热阻与压力和偏转的详细图表,以及REACH合规性和RoHS合规性。 6. 封装信息:包括颜色、增强载体、厚度、卷长/宽、热导率、阻燃等级、介电强度、重量损失、比重、工作温度、体积电阻、伸长率、拉伸强度、标准形状和硬度等详细物理和化学属性。 7. 附加信息:产品可带背胶,提供定制服务,包括部件编号、尺寸、背胶选项和数量。
L37-3L-100-100-1.0-1A 价格&库存
很抱歉,暂时无法提供与“L37-3L-100-100-1.0-1A”相匹配的价格&库存,您可以联系我们找货
