TflexTM 200T V0 Series
Thermal Gap Filler
Innovative Technology
for a Connected World
THIN THERMALLY CONDUCTIVITY ELASTOMERIC INTERFACE MATERIAL
Tflex™ 200T V0 is a specially formulated thin gap filler thermal interface material designed
for thin interfaces that require a combination good thermal performance with great reliability. The elastomeric property of Tflex™ 200T V0 provides good thermal performance in
a thin interface where reliability, shock and vibration considerations, are critical performance
considerations in addition to low thermal resistance.
Tflex™ 200T V0’s unique silicone and ceramic filler technology allows a combination of
great reliability, good thermal performance, and easy handling.
Tflex™ 200T V0 is slightly tacky, and requires no additional adhesive coating that inhibits
thermal performance. Tflex™ 200T V0 is electrically insulating, stable from -40ºC thru 200ºC
and meets UL 94V0 flame rating.
FEATURES AND BENEFITS
• Thermal Conductivity 1.5 W/mK
• Compliant Elastomeric based thin interface material
• Available in 0.008-inch (0.2mm), 0.010-inch (0.25mm), 0.012-inch (0.30mm), 0.015-inch
(0.38mm) , and 0.020-inch (0.51mm) thicknesses
• Slightly tacky for adhesion during assembly and transport
• Competitive price for high volume applications
• Available as individual custom parts, sheets, or custom parts converted on a roll
APPLICATIONS
• Memory Modules:
DDR2, DDR3, SDRAM, SRAM, RAM, NVRAM
• LED solid state lighting
• Power electronics
global solutions: local support
Americas: +1.800.843.4556
Europe: +49.8031.2460.0
Asia: +86.755.2714.1166
CLV-customerservice@lairdtech.com
www.lairdtech.com/thermal
TM
Thermal Gap Filler
8 MIL
10 MIL
15 MIL
Ceramic filled
silicone elastomer
Ceramic filled
silicone elastomer
Ceramic filled
silicone elastomer, reinforced
Color
Light Grey
Light Grey
Light Grey
Thickness
0.008”
(0.203mm)
0.010”
(0.254mm)
0.015”
(0.381mm)
Thickness tolerance
±0.0015”
(±0.038mm)
±0.0015”
(±0.038mm)
±0.00225”
(±0.057mm)
2.32 g/cc
2.32 g/cc
2.32 g/cc
Helium
Pycnometer
55
55
55
ASTM D2240
Outgassing TML
(Post Cured)
0.38%
0.38%
0.38%
ASTM E595
Outgassing CVCM
(Post Cured )
0.11%
0.11%
0.11%
ASTM E595
UL Flammability Rating
94 V0
94 V0
94 V0
E180840
Temperature Range
-45ºC to 200ºC
-45ºC to 200ºC
-45ºC to 200ºC
1.5 W/mK
1.5 W/mK
1.5 W/mK
Hot Disk
Thermal Impedance
@ 10 psi
@ 69 KPa
0.384°C-in²/W
2.48°C-cm²/W
0.488°C-in²/W
3.14°C-cm²/W
0.714°C-in²/W
4.60°C-cm²/W
ASTM D5470
(modified)
Thermal Expansion
(30-150°C)
231.19ppm/°C
231.19ppm/°C
231.19ppm/°C
IPC-TM-650
2.4 2.4
Volume Resistivity
3.5x1010 ohm-cm
3.5x1010 ohm-cm
3.5x1010 ohm-cm
ASTM D257
5.0
5.1
5.1
ASTM D150
Construction &
Composition
Specific Gravity
(Density)
Hardness
(Shore 00)
Dielectric Constant @
1 MHz
TEST METHOD
Visual
Data for design engineer guidance only. Observed performance varies in application.
Engineers are reminded to test the material in application.
THR-DS-Tflex-200T-V0 1209
Any information furnished by Laird Technologies and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies
materials rests with the end user since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness,
merchantability, or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies terms and conditions of sale in effect from time to time, a copy
of which will be furnished upon request.damages of any kind. All Laird Technologies’ products are sold pursuant to the Laird Technologies’ terms and conditions of sale in
effect from time to time, a copy of which will be furnished upon request. A15922-00 Rev C., 12/2009.
© 2009 All Rights Reserved. Laird Technologies is a registered trademark of Laird Technologies, Inc.
很抱歉,暂时无法提供与“A15641-15”相匹配的价格&库存,您可以联系我们找货
