74HC4020; 74HCT4020
14-stage binary ripple counter
Rev. 8 — 7 September 2021
Product data sheet
1. General description
The 74HC4020; 74HCT4020 is a 14-stage binary ripple counter with a clock input (CP), an
overriding asynchronous master reset input (MR) and 12 buffered parallel outputs (Q0, and Q3
to Q13). The counter advances on the HIGH-to-LOW transition of CP. A HIGH on MR clears all
counter stages and forces all outputs LOW, independent of the state of CP. Each counter stage is a
static toggle flip-flop. Inputs include clamp diodes. This enables the use of current limiting resistors
to interface inputs to voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
Input levels:
• For 74HC4020: CMOS level
• For 74HCT4020: TTL level
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Applications
Frequency dividing circuits
Time delay circuits
Control counters
74HC4020; 74HCT4020
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
74HC4020D
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
-40 °C to +125 °C
DHVQFN16
plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 16 terminals;
body 2.5 × 3.5 × 0.85 mm
SOT763-1
74HCT4020D
74HC4020PW
74HCT4020PW
74HC4020BQ
74HCT4020BQ
5. Functional diagram
CP
MR
10
T
11
14-STAGE COUNTER
CD
9
7
5
4
6
13
12
14
15
1
2
3
Q0 Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q10 Q11 Q12 Q13
001aal201
Fig. 1.
Functional diagram
10
11
CP
MR
CTR14
Q0
9
10
Q3
7
11
CT = 0
Q4
5
5
Q5
4
4
Q6
6
6
Q7
13
Q8
12
Q9
14
14
Q10
15
15
Q11
1
1
Q12
2
Q13
3
CP
2
3
001aal203
Fig. 3.
RD
12
13
Logic symbol
FF
T 1
13
CT
001aal202
Fig. 2.
9
Q
FF
T 2
Q
RD
Q
Q
FF
T 3
RD
Q
IEC logic symbol
FF
T 4
Q
RD
Q
FF
T 6
Q
RD
Q
Q
MR
Q0
Q3
Q13
001aal204
Fig. 4.
Logic diagram
74HC_HCT4020
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 16
74HC4020; 74HCT4020
Nexperia
6. Pinning information
6.1. Pinning
1
terminal 1
index area
Q12
2
15 Q10
Q13
3
14 Q9
Q5
4
13 Q7
Q4
5
12 Q8
Q6
6
11 MR
Q3
7
10 CP
GND
8
9
3
14 Q9
Q5
4
13 Q7
Q4
5
Q6
6
Q3
7
12 Q8
VCC(1)
11 MR
10 CP
001aal206
Transparent top view
(1) This is not a supply pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to VCC.
Q0
001aal205
Fig. 5.
Q13
9
16 VCC
15 Q10
Q0
1
2
8
Q11
Q12
GND
74HC4020
74HCT4020
16 VCC
Q11
74HC4020
74HCT4020
Pin configuration SOT109-1 (SO16) and
SOT403-1 (TSSOP16)
Fig. 6.
Pin configuration SOT763-1 (DHVQFN16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
Q0, Q3 to Q13
9, 7, 5, 4, 6, 13, 12, 14, 15, 1, 2, 3
output
GND
8
ground (0 V)
CP
10
clock input (HIGH-to-LOW, edge-triggered)
MR
11
master reset input (active HIGH)
VCC
16
positive supply voltage
74HC_HCT4020
Product data sheet
3 / 16
74HC4020; 74HCT4020
Nexperia
7. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care;
↑ = LOW-to-HIGH clock transition; ↓ = HIGH-to-LOW clock transition.
Output
Input
CP
MR
Q0, Q3 to Q13
L
no change
L
count
X
H
L
7.1. Timing diagram
CP input
1
2
4
8
16
32
64
128
256
512 1024 2048 4096 8192 16384
MR input
Q0
Q3
Q4
Q5
Q6
Q7
Q8
Q9
Q10
Q11
Q12
Q13
001aal207
Fig. 7.
Timing diagram
74HC_HCT4020
Product data sheet
4 / 16
74HC4020; 74HCT4020
Nexperia
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
VCC
supply voltage
-0.5
+7
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
IO
output clamping current
±20
mA
output current
-0.5 V < VO < VCC + 0.5 V
±25
mA
ICC
supply current
±50
mA
IGND
ground current
±50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
Conditions
Tamb = -40 °C to +125 °C
[1]
Unit
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC4020
74HCT4020
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Δt/ΔV
input transition rise
and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
ns/V
except for Schmitt trigger inputs
VCC = 6.0 V
Tamb
ambient temperature
74HC_HCT4020
Product data sheet
83
-40
+25
+125
-40
+25
+125 °C
5 / 16
74HC4020; 74HCT4020
Nexperia
10. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
VCC = 4.5 V
3.15
2.4
1.5
3.15
1.5
V
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
74HC4020
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
LOW-level
output voltage
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
±0.1
±1
±1
μA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT4020
Product data sheet
VI = VCC or GND; VCC = 6.0 V
6 / 16
74HC4020; 74HCT4020
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
74HCT4020
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
VI = VIH or VIL; VCC = 4.5 V
HIGH-level
output voltage
IO = -20 μA
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
±0.1
±1
±1
μA
8.0
80
160
μA
pin MR
110
396
495
539
μA
pin CP
85
306
383
417
μA
3.5
pF
IO = -4.0 mA
VOL
LOW-level
output voltage
II
input leakage
current
ICC
VCC = 5.5 V
ΔICC
VI = VCC - 2.1 V; IO = 0 A;
additional
supply current other inputs at VCC or GND;
CI
VI = VCC or GND; VCC = 5.5 V
input
capacitance
11. Dynamic characteristics
Table 7. Dynamic characteristics
GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 10
Symbol Parameter
Conditions
25 °C
Min
Typ Max
Min
Max
Min
Max
74HC4020
tpd
propagation
delay
CP to Q0; see Fig. 8
[1]
VCC = 2.0 V
39
140
175
210
ns
VCC = 4.5 V
14
28
35
42
ns
VCC = 5.0 V; CL = 15 pF
11
ns
VCC = 6.0 V
11
24
30
36
ns
VCC = 2.0 V
22
75
95
110
ns
VCC = 4.5 V
8
15
19
22
ns
6
ns
VCC = 6.0 V
6
13
16
19
ns
55
170
215
225
ns
43
51
ns
17
ns
VCC = 6.0 V
16
29
37
43
ns
Qn to Qn+1; see Fig. 9
tPHL
HIGH to LOW MR to Qn; see Fig. 8
propagation
VCC = 2.0 V
delay
VCC = 4.5 V
74HC_HCT4020
Product data sheet
7 / 16
74HC4020; 74HCT4020
Nexperia
Symbol Parameter
Conditions
25 °C
Min
tt
tW
transition time Qn; see Fig. 8
Typ Max
Min
Max
Min
Max
[2]
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
80
14
100
120
ns
VCC = 4.5 V
16
4
ns
VCC = 6.0 V
14
3
17
ns
VCC = 2.0 V
80
17
100
120
ns
VCC = 4.5 V
16
6
ns
VCC = 6.0 V
14
5
17
ns
VCC = 2.0 V
50
6
65
75
ns
VCC = 4.5 V
10
2
13
15
ns
VCC = 6.0 V
9
2
11
13
ns
VCC = 2.0 V
6.0
30
4.8
4.0
MHz
VCC = 4.5 V
30
92
24
MHz
101
MHz
35
109
28
24
MHz
19
pF
VCC = 4.5 V
18
36
45
54
ns
15
ns
VCC = 4.5 V
8
15
19
22
ns
6
ns
propagation
VCC = 4.5 V
delay
22
45
56
68
ns
19
ns
7
15
19
22
ns
25
30
ns
25
30
ns
10
2
13
15
ns
pulse width
CP HIGH or LOW; see Fig. 8
MR HIGH; see Fig. 8
trec
fmax
recovery time MR to CP; see Fig. 8
maximum
frequency
see Fig. 8
VCC = 6.0 V
CPD
power
dissipation
capacitance
[3]
74HCT4020
tpd
propagation
delay
[1]
tPHL
tt
tW
pulse width
[2]
VCC = 4.5 V
VCC = 4.5 V
MR HIGH; see Fig. 8
VCC = 4.5 V
trec
VCC = 4.5 V
74HC_HCT4020
Product data sheet
8 / 16
74HC4020; 74HCT4020
Nexperia
Symbol Parameter
Conditions
25 °C
Min
fmax
maximum
frequency
[1]
[2]
[3]
Typ Max
Min
Max
Min
Max
see Fig. 8
VCC = 4.5 V
CPD
power
dissipation
capacitance
[3]
25
47
MHz
52
MHz
pF
tpd is the same as tPHL and tPLH.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi + Σ (CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
2
Σ (CL x VCC x fo) = sum of outputs;
CL = output load capacitance in pF;
VCC = supply voltage in V.
11.1. Waveforms and test circuit
VI
VM
MR input
tW
trec
VI
1/fmax
VM
CP input
tPHL
Q0 or Qn
output
tPLH
tW
90 %
tPHL
90 %
10 %
VM
10 %
tTLH
tTHL
001aad590
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 8.
Clock timing, propagation delays and pulse widths
74HC_HCT4020
Product data sheet
9 / 16
74HC4020; 74HCT4020
Nexperia
VOH
Qn output
VM
VOL
tPLH
VOH
tPHL
VM
Qn+1 output
VOL
001aai120
Fig. 9.
Waveforms showing the output Qn to output Qn+1 propagation delays
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC4020
0.5 x VCC
0.5 x VCC
74HCT4020
1.3 V
1.3 V
VI
negative
pulse
VM
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
Fig. 10. Test circuit for measuring switching times
Table 9. Test data
Type
Load
Input
VI
tr, tf
CL
74HC4020
VCC
6 ns
15 pF, 50 pF
74HCT4020
3V
6 ns
15 pF, 50 pF
74HC_HCT4020
Product data sheet
10 / 16
74HC4020; 74HCT4020
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 11. Package outline SOT109-1 (SO16)
74HC_HCT4020
Product data sheet
11 / 16
74HC4020; 74HCT4020
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 12. Package outline SOT403-1 (TSSOP16)
74HC_HCT4020
Product data sheet
12 / 16
74HC4020; 74HCT4020
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 13. Package outline SOT763-1 (DHVQFN16)
74HC_HCT4020
Product data sheet
13 / 16
74HC4020; 74HCT4020
Nexperia
13. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT4020 v.8
20210907
Product data sheet
74HC_HCT4020 v.7
Modifications:
74HC_HCT4020 v.7
20200618
Modifications:
Type number 74HC4020DB (SOT338-1/SSOP16) removed.
20160203
Modifications:
74HC_HCT4020 v.5
20120806
Modifications:
74HC_HCT4020 v.4
20111213
Modifications:
74HC_HCT4020 v.3
20100120
74HC_HCT4020 v.2
19970901
Product data sheet
74HC_HCT4020 v.6
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74HCT4020DB (SOT338-1/SSOP16) removed.
Section 1 and Section 2 updated.
Table 4: Derating values for Ptot total power dissipation have been updated.
74HC_HCT4020 v.6
74HC_HCT4020
Product data sheet
Product data sheet
74HC_HCT4020 v.5
Type numbers 74HC4020N and 74HCT4020N (SOT38-4) removed.
Product data sheet
74HC_HCT4020 v.4
74HC_HCT4020 v.3
Product data sheet
74HC_HCT4020 v.2
Product specification
Measurement points added to Fig. 8 (errata).
Product data sheet
Legal pages updated.
14 / 16
74HC4020; 74HCT4020
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT4020
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74HC4020; 74HCT4020
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 4
7.1. Timing diagram............................................................ 4
8. Limiting values............................................................. 5
9. Recommended operating conditions..........................5
10. Static characteristics..................................................6
11. Dynamic characteristics.............................................7
11.1. Waveforms and test circuit........................................ 9
12. Package outline........................................................ 11
13. Abbreviations............................................................ 14
14. Revision history........................................................14
15. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 7 September 2021
74HC_HCT4020
Product data sheet
16 / 16
