74HC4060-Q100;
74HCT4060-Q100
14-stage binary ripple counter with oscillator
Rev. 4 — 8 September 2021
Product data sheet
1. General description
The 74HC4060-Q100; 74HCT4060-Q100 is a 14-stage ripple-carry counter/divider and oscillator
with three oscillator terminals (RS, RTC and CTC), ten buffered parallel outputs (Q3 to Q9 and Q11
to Q13) and an overriding asynchronous master reset (MR). The oscillator configuration allows
design of either RC or crystal oscillator circuits. The oscillator may be replaced by an external
clock signal at input RS. In this case, keep the oscillator pins (RTC and CTC) floating. The counter
advances on the HIGH-to-LOW transition of RS. A HIGH level on MR clears all counter stages and
forces all outputs LOW, independent of the other input conditions. Inputs include clamp diodes.
This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
All active components on chip
RC or crystal oscillator configuration
Input levels:
• For 74HC4060-Q100: CMOS level
• For 74HCT4060-Q100: TTL level
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
3. Applications
Control counters
Timers
Frequency dividers
Time-delay circuits
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74HC4060PW-Q100
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
74HC4060BQ-Q100
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
74HC4060D-Q100
74HCT4060D-Q100
74HCT4060BQ-Q100
SOT763-1
5. Functional diagram
10
9
CTR14
RTC CTC
11
12
RS
MR
Q3
7
Q4
5
Q5
4
Q6
6
Q7
14
Q8
13
Q9
15
Q11
1
Q12
2
Q13
3
!G
CTC
9
Logic symbol
11
RS
6
11
12
MR
14
12
CT
4
AND
9
15
11
1
6
14
CT
13
13
CT = 0
13
9
15
11
1
2
3
13
(a)
Fig. 2.
(b)
3
001aai468
IEC logic symbol
9
CTC
RS
CP
MR
MR
14-STAGE BINARY COUNTER
Q3
7
Fig. 3.
4
7
5
RTC
2
RTC
12
3
5
CT = 0
10
11
7
10
001aai467
Fig. 1.
CTR14
3
Q4
5
Q5
4
Q6
6
Q7
14
Q8
13
Q9
15
Q11 Q12 Q13
1
2
3
001aai113
Functional diagram
CTC
RTC
RS
FF
1
FF
4
CP
CP
Q
MR
MR
FF
10
FF
12
CP
Q
CP
Q
MR
CP
Q
MR
Q3
FF
14
Q
MR
Q9
MR
Q11
Q13
001aai114
Fig. 4.
Logic diagram
74HC_HCT4060_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 19
Nexperia
6. Pinning information
6.1. Pinning
1
16 VCC
terminal 1
index area
74HC4060-Q100
74HCT4060-Q100
Q12
2
15 Q9
Q11
1
16 VCC
Q13
3
14 Q7
Q12
2
15 Q9
Q5
4
13 Q8
Q4
5
Q6
6
Q3
7
12 MR
Q5
4
13 Q8
Q4
5
12 MR
9
VCC(1)
Q6
6
11 RS
CTC
14 Q7
8
3
GND
Q13
Q3
7
10 RTC
GND
8
9
11 RS
10 RTC
aaa-004007
Transparent top view
(1) This is not a supply pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to VCC.
CTC
aaa-004006
Fig. 5.
Q11
74HC4060-Q100
74HCT4060-Q100
Pin configuration SOT109-1 (SO16) and
SOT403-1 (TSSOP16)
Fig. 6.
Pin configuration SOT763-1 (DHVQFN16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
Q11, Q12, Q13
1, 2, 3
counter output
Q3, Q4, Q5, Q6, Q7, Q8, Q9
7, 5, 4, 6, 14, 13, 15
counter output
GND
8
ground (0 V)
CTC
9
external capacitor connection
RTC
10
external resistor connection
RS
11
clock input /oscillator pin
MR
12
master reset input (active HIGH)
VCC
16
supply voltage
74HC_HCT4060_Q100
Product data sheet
3 / 19
Nexperia
7. Functional description
1
2
4
8
16
32
64
128
256
512
1024
2048
4096
8192 16384
RS
MR
Q3
Q4
Q5
Q6
Q7
Q8
Q9
Q11
Q12
Q13
001aai117
Fig. 7.
Timing diagram
8. Limiting values
Table 3. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
-0.5
+7
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±25
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
74HC_HCT4060_Q100
Product data sheet
4 / 19
Nexperia
9. Recommended operating conditions
Table 4. Recommended operating conditions
Symbol Parameter
Conditions
74HC4060-Q100
74HCT4060-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+125
-40
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
10. Static characteristics
Table 5. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
MR input
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.3
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.1
4.2
4.2
V
VCC = 2.0 V
1.7
1.7
1.7
V
VCC = 4.5 V
3.6
3.6
3.6
V
VCC = 6.0 V
74HC4060-Q100
VIH
RS input
VIL
4.8
4.8
4.8
V
MR input
LOW-level
input voltage
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VCC = 2.0 V
0.3
0.3
0.3
V
VCC = 4.5 V
0.9
0.9
0.9
V
VCC = 6.0 V
1.2
1.2
1.2
V
RS input
74HC_HCT4060_Q100
Product data sheet
5 / 19
Nexperia
Symbol Parameter
VOH
HIGH-level
output
voltage
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -2.6 mA; VCC = 4.5 V
3.98
3.84
3.7
V
IO = -3.3 mA; VCC = 6.0 V
5.48
5.34
5.2
V
1.9
2.0
1.9
1.9
V
4.4
4.5
4.4
4.4
V
5.9
6.0
5.9
5.9
V
IO = -0.65 mA; VCC = 4.5 V
3.98
3.84
3.7
V
IO = -0.85 mA; VCC = 6.0 V
5.48
5.34
5.2
V
IO = -3.2 mA; VCC = 4.5 V
3.98
3.84
3.7
V
IO = -4.2 mA; VCC = 6.0 V
5.48
5.34
5.2
V
1.9
2.0
1.9
1.9
V
4.4
4.5
4.4
4.4
V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 2.6 mA; VCC = 4.5 V
0.26
0.33
0.4
V
IO = 3.3 mA; VCC = 6.0 V
0.26
0.33
0.4
V
IO = 3.2 mA; VCC = 4.5 V
0.26
0.33
0.4
V
IO = 4.2 mA; VCC = 6.0 V
0.26
0.33
0.4
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.26
0.33
0.4
V
RTC output; RS = MR = GND
RTC output; RS = MR = VCC
CTC output; RS = VIH; MR = VIL
VI = VIH or VIL; except RTC output
VI = VIH or VIL;
except RTC and CTC outputs
VOL
LOW-level
output
voltage
RTC output; RS = VCC; MR = GND
CTC output; RS = VIL; MR = VIH
VI = VIH or VIL;
74HC_HCT4060_Q100
Product data sheet
6 / 19
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
II
input leakage VI = VCC or GND; VCC = 6.0 V
current
±0.1
±1.0
±1.0
μA
ICC
supply
current
8.0
80
160
μA
CI
input
capacitance
3.5
pF
2.0
2.0
2.0
V
3.6
3.6
3.6
V
0.8
0.8
0.8
V
0.9
0.9
0.9
V
4.4
4.5
4.4
4.4
V
3.98
3.84
3.7
V
4.4
4.5
4.4
4.4
V
3.98
3.84
3.7
V
3.98
3.84
3.7
V
4.4
4.5
4.4
4.4
V
3.98
3.84
3.7
V
0.1
0.1
V
0.26
0.33
0.4
V
0.26
0.33
0.4
V
0.1
0.1
V
0.26
0.33
0.4
V
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
74HCT4060-Q100
VIH
MR input; VCC = 4.5 V to 5.5 V
HIGH-level
input voltage RS input; V = 4.5 V
CC
[1]
VIL
LOW-level
CC
[1]
VOH
HIGH-level
output
voltage
VI = VIH or VIL;
VOL
LOW-level
output
voltage
VI = VIH or VIL;
II
input leakage VI = VCC or GND; VCC = 5.5 V
current
±0.1
±1.0
±1.0
μA
ICC
supply
current
VI = VCC or GND; VCC = 5.5 V;
IO = 0 A
8.0
80
160
μA
ΔICC
additional
supply
current
per input pin; VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
40
144
180
196
μA
CI
input
capacitance
3.5
pF
[1]
For HCT4060, only input MR (pin 12) has TTL input switching levels.
74HC_HCT4060_Q100
Product data sheet
7 / 19
Nexperia
11. Dynamic characteristics
Table 6. Dynamic characteristics
GND = 0 V; CL = 50 pF unless otherwise specified; for test circuit see Fig. 11.
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
99
300
375
450
ns
VCC = 4.5 V
36
60
75
90
ns
VCC = 5.0 V; CL = 15 pF
31
ns
29
51
64
77
ns
VCC = 2.0 V
22
80
100
120
ns
VCC = 4.5 V
8
16
ns
6
ns
VCC = 6.0 V
6
14
17
ns
55
175
220
265
ns
44
53
ns
17
ns
16
30
37
45
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
80
17
100
120
ns
VCC = 4.5 V
16
6
ns
VCC = 6.0 V
14
5
17
ns
VCC = 2.0 V
80
25
100
120
ns
VCC = 4.5 V
16
9
ns
VCC = 6.0 V
14
7
17
ns
VCC = 2.0 V
100
28
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
8
21
26
ns
74HC4060-Q100
tpd
propagation RS to Q3; see Fig. 8
delay
VCC = 2.0 V
[1]
VCC = 6.0 V
Qn to Qn+1; see Fig. 9
tPHL
[2]
MR to Qn; see Fig. 10
HIGH
to LOW
VCC = 2.0 V
propagation
VCC = 4.5 V
delay
VCC = 6.0 V
tt
tW
transition
time
Qn; see Fig. 8
[3]
pulse width RS (HIGH or LOW); see Fig. 8
MR (HIGH); see Fig. 10
trec
recovery
time
74HC_HCT4060_Q100
Product data sheet
MR to RS; see Fig. 10
8 / 19
Nexperia
Symbol Parameter
fmax
Conditions
25 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
6
26
4.8
4
MHz
VCC = 4.5 V
30
80
24
MHz
87
MHz
35
95
28
24
MHz
40
pF
33
66
83
99
ns
31
ns
VCC = 4.5 V
8
16
ns
6
ns
HIGH
to LOW
VCC = 4.5 V
propagation
delay
21
44
55
66
ns
18
ns
7
15
19
22
ns
16
6
ns
16
6
ns
26
13
33
39
ns
30
80
24
MHz
88
MHz
40
pF
maximum
frequency
RS; see Fig. 8
VCC = 6.0 V
CPD
-40 °C to
+85 °C
power
VI = GND to VCC; VCC = 5 V;
dissipation fi = 1 MHz
capacitance
[4]
74HCT4060-Q100
tpd
delay
VCC = 4.5 V
[1]
tPHL
tt
tW
transition
time
[2]
Qn; see Fig. 8
[3]
VCC = 4.5 V
VCC = 4.5 V
VCC = 4.5 V
trec
fmax
recovery
time
maximum
frequency
RS; see Fig. 8
VCC = 4.5 V
VCC = 4.5 V
CPD
[1]
[2]
[3]
[4]
power
VI = GND to VCC - 1.5 V;
dissipation VCC = 5 V; fi = 1 MHz
capacitance
[4]
tpd is the same as tPHL and tPLH.
Qn+1 is the next Qn output.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
74HC_HCT4060_Q100
Product data sheet
9 / 19
Nexperia
11.1. Waveforms and test circuit
1/fmax
VI
RS input
VM
GND
tW
tPHL
VOH
tPLH
90 %
90 %
VM
Q3 output
10 %
VOL
10 %
tTHL
tTLH
001aai118
Measurement points are given in Table 7.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 8.
Waveforms showing the clock (RS) to output (Q3) propagation delays, the clock pulse width, the output
transition times and the maximum clock frequency
VOH
Qn output
VM
VOL
tPLH
VOH
tPHL
VM
Qn+1 output
VOL
001aai120
Fig. 9.
Waveforms showing the output Qn to output Qn+1 propagation delays
VI
MR input
VM
GND
tW
trec
VI
RS input
VM
GND
VOH
tPHL
VM
Qn output
VOL
001aai119
Fig. 10. Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation
delays and the master reset to clock (RS) recovery time
74HC_HCT4060_Q100
Product data sheet
10 / 19
Nexperia
Table 7. Measurement points
Type
Input
Output
VM
VM
74HC4060-Q100
0.5 × VCC
0.5 × VCC
74HCT4060-Q100
1.3 V
1.3 V
VI
negative
pulse
VM
tf
tr
tr
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
Test data is given in Table 8.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
Fig. 11. Test circuit for measuring switching times
Table 8. Test data
Type
Load
Input
VI
tr, tf
CL
74HC4060-Q100
VCC
6 ns
15 pF, 50 pF
74HCT4060-Q100
3V
6 ns
15 pF, 50 pF
12. RC oscillator
12.1. Timing component limitations
The oscillator frequency is mainly determined by RtCt, provided R2 ≈ 2Rt and R2C2 50 pF, up to any practical value and 10 kΩ < Rt < 1 MΩ.
In order to avoid start-up problems, Rt ≥ 1 kΩ.
12.2. Typical crystal oscillator circuit
In Fig. 13, R2 is the power limiting resistor. For starting and maintaining oscillation a minimum
transconductance is necessary, so R2 should not be too large. A practical value for R2 is 2.2 kΩ.
MR (from logic)
74HC4060-Q100
74HCT4060-Q100
11 RS
Rbias
Rbias
100 k
RTC
10
560 kΩ
VDD
to 1 M
0.47 pF
R2
2.2 k
C3
22 pF to 37 pF
VI
(fi = 1 kHz)
output
A
IO
001aai123
Fig. 13. External component connection for a crystal
oscillator
Product data sheet
input
GND
C2
100 pF
aaa-004009
74HC_HCT4060_Q100
100 µF
gfs = ΔIO / ΔVI at VO is constant; MR = LOW.
See also Fig. 15.
Fig. 14. Test set-up for measuring forward
transconductance
12 / 19
Nexperia
001aai124
14
(1)
gfs
(mA/V)
(2)
10
(3)
6
2
4
VCC (V)
6
(1) Maximum.
(2) Typical.
(3) Minimum.
Tamb = 25 °C.
Fig. 15. Typical forward transconductance as function of the supply voltage
001aai125
105
fosc
(Hz)
001aai127
105
fosc
(Hz)
Rt
104
104
Ct
103
103
102
102
10
103
104
105
Rt (Ω)
106
VCC = 2.0 V to 6.0 V; Tamb = 25 °C.
For Rt curve: Ct = 1 nF; R2 = 2 × Rt.
Product data sheet
10- 3
10- 2
Ct (µF)
10- 1
For Ct curve: Rt = 100 kΩ; R2 = 200 kΩ.
Fig. 16. RC oscillator frequency as a function of Rt
74HC_HCT4060_Q100
10
10- 4
Fig. 17. RC oscillator frequency as a function of Ct
13 / 19
Nexperia
13. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 18. Package outline SOT109-1 (SO16)
74HC_HCT4060_Q100
Product data sheet
14 / 19
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 19. Package outline SOT403-1 (TSSOP16)
74HC_HCT4060_Q100
Product data sheet
15 / 19
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 20. Package outline SOT763-1 (DHVQFN16)
74HC_HCT4060_Q100
Product data sheet
16 / 19
Nexperia
14. Abbreviations
Table 9. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT4060_Q100 v.4
20210908
Product data sheet
Modifications:
74HC_HCT4060_Q100 v.3
20200508
Modifications:
Type number 74HC4060DB-Q100 (SSOP16/SOT338-1) removed.
Section 2 updated.
20130410
Modifications:
74HC_HCT4060_Q100 v.1
20120802
Product data sheet
Product data sheet
74HC_HCT4060_Q100 v.2
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 1 and Section 2 updated.
Fig. 2: Pinnames corrected. (errata)
Table 3: Derating values for Ptot total power dissipation updated.
Table 5: HIGH and LOW input levels added for 74HCT4060-Q100. (errata)
Type number 74HCT4060DB-Q100 (SSOP16/SOT338-1) removed.
74HC_HCT4060_Q100
Product data sheet
74HC4060DB-Q100 and 74HCT4060DB-Q100 added.
Product data sheet
17 / 19
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
16. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT4060_Q100
Product data sheet
18 / 19
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 4
8. Limiting values............................................................. 4
9. Recommended operating conditions..........................5
10. Static characteristics..................................................5
11. Dynamic characteristics.............................................8
11.1. Waveforms and test circuit.......................................10
12. RC oscillator............................................................. 11
12.1. Timing component limitations.................................. 11
12.2. Typical crystal oscillator circuit................................ 12
13. Package outline........................................................ 14
14. Abbreviations............................................................ 17
15. Revision history........................................................17
16. Legal information......................................................18
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 8 September 2021
74HC_HCT4060_Q100
Product data sheet
19 / 19
