NJM2902N
NJM2902N
    NJR(新日本无线)
    DIP14
    IC OPAMP GP 4 CIRCUIT 14DIP
NJM2902N 数据手册
NJM2902 QUAD SINGLE-SUPPLY OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM2902 consists of four independent high-gain operational amplifiers that are designed for single-supply operation. Operation from split power supplies is also possible and the low power supply drain is independent of the magnitude of the power supply voltage. Used with a dual supply the circuit will operate over a wide range of supply voltages. However, a large amount of crossover distortion may occur with loads to ground. An external current-sinking resistor to-VS will reduce crossover distortion. There is no crossover distortion problem in single-supply operation if the load is direct-coupled to ground. ■ FEATURES ● Single Supply ● Operating Voltage ● High Output Voltage ● Slew Rate ● Low Operating Current ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM2902N NJM2902M NJM2902V ( +3V~+30V ) ( V+-2V ) ( 0.5V/µs typ. ) ( 1mA typ. ) DIP14,DMP14,SSOP14 ■ PIN CONFIGURATION PIN FUNCTION 1.A OUTPUT 2.A –INPUT 3.A +INPUT + 4.V 5.B +INPUT 6.B –INPUT 7.B OUTPUT 8.C OUTPUT 9.C -INPUT 10.C +INPUT 11.GND 12.D +INPUT 13.D -INPUT 14.D OUTPUT NJM2902N NJM2902M NJM2902V ■ EQUIVALENT CIRCUIT ( 1/4 Shown ) Ver.2003-03-20 -1- NJM2902 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL + + V (V /V ) VID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS 32 ( or ± 16 ) 32 -0.3~+32 ( DIP14 ) 570 ( DMP14 ) 300 ( SSOP14 ) 300 -40~+85 -50~+125 UNIT V V V mW ˚C ˚C ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C,V+=5V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Large Signal Voltage Gain Maximum Output Voltage Swing Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Output Source Current Output Sink Current Channel Separation Operating Current Slew Rate Gain Bandwidth Product -2- SYMBOL VIO IIO IB AV VOM VICM CMR SVR ISOURCE ISINK CS ICC SR GB TEST CONDITION RS=0Ω + IIN -IIN + IIN or IIN RL>2kΩ RL=2kΩ + - VIN =1V,VIN =0V + VIN =0V,VIN =1V f=1k~20kHz,Input Referred RL=∞ + V /V =±15V + V /V =±15V MIN. 3.5 0~3.5 20 8 - TYP. 2 5 20 100 85 100 40 20 120 1 0.5 0.5 MAX. 10 50 500 2 - UNIT mV nA nA V/mV V V dB dB mA mA dB mA V/µs MHz Ver.2003-03-20 NJM2902 ■ TYPICAL CHARACTERISTICS Ver.2003-03-20 -3- NJM2902 ■ TYPICAL CHARACTERISTICS -4- Ver.2003-03-20 NJM2902 ■ TYPICAL CHARACTERISTICS Ver.2003-03-20 -5- NJM2902 ■ APPLICATION Improvement of Cross-over Distortion Equivalent circuit at the output stage NJM2902,in its static state ( No in and output condition ) when design, QU being biassed by constant current ( break down beam ) yet, QL stays OFF. While using with both power source mode, the cross-over distortion might occur instantly when QL ON. There might be cases when application for amplifier of audio signals, not only distortion but also the apparent frequency bandwidth being narrowed remarkably. It is adjustable especially when using both power source mode, constantly to use with higher current on QU than the load current ( including feedback current ),and then connect the pull-down resister RP at the part between output and GND pins. [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -6- Ver.2003-03-20
NJM2902N
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm,共有24个引脚。
NJM2902N 价格&库存
很抱歉,暂时无法提供与“NJM2902N”相匹配的价格&库存,您可以联系我们找货
