NJM2136/37/38
ULTRA WIDE BAND, HIGH SLEW RATE SINGLE OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
■ PACKAGE OUTLINE
The NJM2136, NJM2137 and NJM2138 are single, dual and
quad operational amplifiers operated from low voltage (±1.35V).
A 200MHz gain bandwidth and 45V/µs high slew rate make them
suitable for use as active filter, high-speed analog and digital signal
NJM2136M
processor, industrial measurement equipment and others.
It can also suitable to portable communication items because of
low operating voltage and low operating current.
■ FEATURES
● Operating Voltage
±1.35V~±6V
● Wide Bandwidth
200MHz typ.
● High Slew Rate
45V/µs typ.
● Input Offset Voltage Balance (only NJM2136)
● Operating Current
NJM2136: 0.63mA typ.
NJM2137: 1.14mA typ.
NJM2138: 2.27mA typ.
● Bipolar Technology
● Package Outline
NJM2136: DMP8, SSOP8
NJM2137: DIP8, DMP8, SSOP8
NJM2138: DMP14, SSOP14
NJM2137D
NJM2136V
NJM2137M
NJM2137V
NJM2138M
NJM2138V
■ PIN CONFIGURATION
1
8
2
7
3
6
4
5
NJM2136M
NJM2136V
PIN FUNCTION
1.BAL
2.–INPUT
3.+INPUT
4.V
5.NC
6.OUTPUT
7. V
8.BAL
1
2
3
8
7
4
6
5
NJM2137D
NJM2137M
NJM2137V
PIN FUNCTION
1.A OUTPUT
2.A –INPUT
3.A +INPUT
4.V
5.B +INPUT
6.B -INPUT
7.B OUTPUT
8.V
1
14
2
13
3
12
4
11
5
10
6
7
9
8
NJM2138M
NJM2138V
■ EQUIVALENT CIRCUIT (each amplifier)
V+
-INPUT
PIN FUNCTION
1.A OUTPUT
2.A –INPUT
3.A +INPUT
4.V
5.B +INPUT
6.B -INPUT
7.B OUTPUT
8. C OUTPUT
9. C -INPUT
10.C +INPUT
11.V
12.D +INPUT
13.D -INPUT
14.D OUTPUT
OUTPUT
+INPUT
V-
Ver.2008-02-27
-1-
NJM2136/37/38
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
SYMBOL
+ V /V
VID
Supply Voltage
Differential Input Voltage
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
± 6.75
±3
(DIP8) 500
(DMP8) 300
(SSOP8) 250
(DMP14) 300
(SSOP14) 300
-40~+85
-50~+125
UNIT
V
V
mW
˚C
˚C
■ ELECTRICAL CHARACTERISTICS
( V+/V-=±2.5V,Ta=25˚C )
PARAMETER
Operating Voltage
Input Bias Current
Input Offset Current
Large Signal Voltage Gain
Input Common Mode Voltage Range
Common Mode Rejection Ratio
SYMBOL
+ V /V
VIO
IB
IIO
AV
VICM
CMR
+SVR
-SVR
+SVR
-SVR
Supply Voltage Rejection Ratio
Maximum Output Voltage Swing
VOM
Operating Current (all Amp.)
ICC
Slew Rate
Gain Bandwidth Product
Phase Margin
Unity Gain Bandwidth
SR
GB
ØM
fT
TEST CONDITION
RS=0Ω
RL≥2kΩ
-1V≤Vcm≤+1V
NJM2136
NJM2137/NJM2138
RL=1kΩ
NJM2136, RL=∞
NJM2137, RL=∞
NJM2138, RL=∞
AV=0dB
60dB • 500kHz
40dB
40dB
MIN.
± 1.35
65
±1.2
45
70
50
50
70
1.1
-0.9
120
TYP.
1.0
0.5
±1.5
60
80
60
60
80
1.4
-1.2
0.63
1.14
2.27
45
200
25
40
MAX.
± 6.00
5.0
2.0
200
0.82
1.50
3.00
UNIT
V
mV
µA
nA
dB
V
dB
dB
V
mA
V/µs
MHz
deg.
MHz
■ OFFSET ADJUSTMENT METHOD (only NJM2136)
V+
Rp=200Ω
Rp
2
1
8
7
6
3
4
V
( note ) The electrical characteristics change a little, in case the RP is connected.
-2-
Ver.2008-02-27
NJM2136/37/38
■ TYPICAL CHARACTERISTICS
Operating Current vs. Temperature
Operating Current vs. Supply Voltage
GV=0dB, Ta=25ºC
3.0
2.5
Operating Current [mA]
NJM2138
NJM2138
2.5
V+/V-=±2.5V, GV=0dB
3.0
2.0
1.5
NJM2137
1.0
NJM2136
0.5
2.0
1.5
NJM2137
1.0
0.5
0.0
NJM2136
0.0
2
3
4
Supply Voltage [V+/V-]
5
6
-50
Input Offset Voltage vs. Temperature
125
V+/V-=±2.5V, GV=0dB, Ta=25ºC
60
2.0
Input offset Current [nA]
Input Offset Voltage [mV]
50
75
100
Ambient Temperature [ºC]
Input Offset Current vs. Temperature
3.0
-25
1.0
0.0
-1.0
-2.0
-3.0
40
-40
-60
-50
-25
50
75
100
125
-50
-25
50
75
100
125
Input Bias Current vs. Temperature
Input Bias Current [nA]
-100
-200
-300
-400
-500
-600
-50
Ver.2008-02-27
-25
50
75
100
125
-3-
NJM2136/37/38
Maximum Output Voltage vs. Temperature
Output Voltage vs. Load Resistance
V+/V-=±2.5V, Gv=OPEN, RL=1KΩ
2.5
2
1.5
1.0
0.5
0.0
-0.5
-1.0
-VOM
1
0.5
-1
-1.5
-1.5
-2.0
-2
-2.5
-50
-25
50
75
100
-VOM
-2.5
100
0k
125
Output Voltage vs. Output Source Current
0.0
V+/V-=±2.5V, Gv=OPEN, Ta=25ºC
-0.5
Output Voltage [V]
2.0
1.5
1.0
0.5
-1.0
-1.5
-2.0
0.0
0.001
0.01
0.1
1
Output Source Current [mA]
-2.5
0.001
10
Voltage Gain,Phase vs. Frequency
50
V+/V-=±2.5V, Gv=40dB, RL=2kΩ, CL=10pF, Ta=25ºC
0.01
0.1
1
Output Sink Current [mA]
15
90
V+/V-=±2.5V, Gv=0dB, RL=2kΩ, Ta=25ºC
Phase
10
-90
100k
0M
1M
10M
Frequency [Hz]
-180
100M
Voltage Gain [dB]
Phase [deg]
Voltage Gain [dB]
-4-
CL=100pF
45
30
10
Voltage Follower Peak vs. Frequency
Gain
40
-10
10k
0M
1M
1000k
1k
10k
100k
Load Resistance [Ω]
Output Voltage vs. Output Sink Current
2.5
+VOM
1.5
+VOM
Output Voltage [V]
Maximum Output Voltage [V]
2.0
Output Voltage [V]
2.5
10
CL=50pF
CL=200pF
CL=10pF
5
100k
0M
1M
10M
Frequency [Hz]
100M
Ver.2008-02-27
NJM2136/37/38
Total Harmonic Distortion vs. Output Voltage
10kHz
1
100kHz
0.1
1kHz
0.01
0.001
0.001
0.01
0.1
1
Output Voltage [Vrms]
Gv=0dB, V+/V-=±2.5V, RL=2KΩ, Ta=25ºC
10
Total Harmonic Distortion [%]
10
GV=20dB, V+/V-=±2.5V, RL=2KΩ, Ta=25ºC
1
100kHz
0.1
0.01
0.001
0.001
10
10kHz
1kHz
0.01
0.1
1
10
Pulse Response
V+/V-=±2.5V, Gv=0dB, RL=2kΩ, CL=10pF, Ta=25ºC
1.5
7.5
6.0
INPUT
0.0
4.5
-1.5
3.0
-3.0
1.5
OUTPUT
-4.5
0.0
-6.0
-1.5
-7.5
Output Voltage [V]
Input Voltage [V]
3.0
-3.0
Time [0.2µsec./Div.]
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
Ver.2008-02-27
-5-
