62A11-02-040CH
62A11-02-040CH
    GRAYHILLINC.
    OPTICAL ENCODER
62A11-02-040CH 数据手册
Optical Encoders SERIES 62A,V,D 1/2'' Package APPLICATIONS • Global Positioning/Driver Information Systems • Medical Equipment Optical and Mechanical Encoders FEATURES • Low Cost • Long Life • Available in 3.3 or 5.0 Vdc Operating Voltages • High Torque Version to Emphasize Rotational Feel • Economical Size • Optically Coupled for More than a Million Cycles • Optional Integral Pushbutton • Compatible with CMOS, TTL and HCMOS Logic • Available in 12,16, 20, 24 and 32 Detent Positions (Non-detent also available) • Choice of Cable Lengths and Terminations DIMENSIONS in inches (and millimeters) Cable Version .540 (13,72) .250 (6,35) .500 (12,70) .250 (6,35) .066±.002 (1,68±0,05 .152±.002 (3,9±0,05) .219±.003 (5,6±0,08) .390 (9,91) Ø.250±.002 (6,35±0,05) .250 (6,35) .375±.015 (9,52±0,38) 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 (0,76) OF SHOULDER. .312 (7,92) .525±.015 (13,34±0,38) .510±.015 (12,95±0,38) 62AXX-XX-XXXC XXXX X-X .320 REF. (8,13) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois GRAYHILL 28 AWG CABLE WIRES ON .050 (1.27) CENTERS CONNECTOR IS AMP P/N 215083-6 654321 4.000 ±.20 (±5,1) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders DIMENSIONS in inches (and millimeters) Pin Version Unless otherwise specified, standard tolerance is ±.010 (0.25) .540 (13,72) .250 (6,35) .066 ±.002 (1,68±0,05) .250 (6,35) .500 (12,70) .602 (15,29) .152±.002 (3,9±0,05) .219±.003 (5,6±0,08) .100 (2,54) TYP. .522 Ø.250 ±.002 (6,32±0,05) 3/8-32 UNEF-2A THREAD. THREADS TO BE WITHIN .030 (0,76) OF SHOULDER. .375 ±.015 (9,52±0.38) .250 (6,35) .312 (7,9) GRAYHILL 62AXX-XX-P XXXX X-X .797 (20,2) .817 (20,8) 654321 .940±.050 (24,0±1,3) .470±.020 (12,0±0,5) .140±.015 (3,6±0,4) Optical and Mechanical Encoders .450±.010 (11,43±0,3) .620 (15,7) CIRCUITRY, TRUTH TABLE, AND WAVEFORM Standard Quadrature 2-Bit Code Standard 5.0 Volt (Styles A and D) Clockwise Rotation Position Output A Output B PIN # POWER +5V 6 R* 5 OUTPUT A R* OUTPUT B 4 N.O. PUSHBUTTON SWITCH 3 GROUND 1 • 1 2 3 4 • • • • Indicates logic high; blank indicates logic low. Code repeats every 4 positions. 2 3.3 Volt (Style V only) PIN # POWER +3.3V 6 R* OUTPUT A OUTPUT B OUTPUT A 100 Ω 5% 5 R* 100 Ω 5% OUTPUT B HIGH LOW HIGH LOW 4 1 N.O. PUSHBUTTON SWITCH GROUND 3 2 3 4 5 6 POSITION NUMBER 2 1 * External pull-up resisitors required for operation (2.2k Ω) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders SPECIFICATIONS Electrical and Mechanical Ratings Optical and Mechanical Encoders Rating: 5 Vdc, 10 mA, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations min. Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 1000 ±300 grams Pushbutton Travel: .010/.025 inch Coding: 2-bit quadrature coded output Operating Voltage: 5.0 ±.25 Vdc, 3.30±.125 Vdc (style V only) Voltage Breakdown: 250 Vac between mutually insulated parts Supply Current: 30 mA maximum Logic Output Characterisitics: Logic High: 3.8 Vdc (5.0 Vdc); 2.3 (3.3 Vdc) minimum Logic Low: 0.8 Vdc maximum Rotational Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Minimum Sink Current: 2.0 mA for 5 Vdc; 1.0 mA for 3.3 Vdc Power Consumption: 150 mW maximum for 5 Vdc; 80 mW for 3.3 Vdc Optical Rise and Fall Times: less than 30 mS maximum Operating Torque: Style A and V: 2.0 ±1.4 in-oz. initially Style D: 3.5 ±1.4 in-oz initially Non-detent: less than 1.5 in-oz initially Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs cable pull-out force minimum Operating Speed: 100 RPM maximum Axial Shaft Play: .010 maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Relative Humidity: 90–95% at 40°C for 96 hours Vibration Resistance: Harmonic motion with amplitude of 15G, within a varied 10 to 2000 Hz frequency for 12 hours per MIL-STD-202, Method 204 Mechanical Shock: Test 1: 100G for 6 mS, half sine, 12.3 ft/s; Test 2: 100G for 6 mS, sawtooth, 9.7 ft/s Materials and Finishes Code Housing: Reinforced thermoplastic Shaft: Zinc or aluminum Bushing: Zinc casting Shaft Retaining Ring: Stainless steel Detent Spring: Stainless steel Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and zinc-plated spring steel with clear trivalent chromate finish lockwasher supplied with each switch. Nut is 0.094 inches thick by 0.435 inches across flats. Rotor: Thermoplastic Code Housing: Thermoplastic Pushbutton Dome: Stainless steel Dome Retaining Disk: Thermoplastic Pushbutton Housing: Thermoplastic Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Pushbutton Contact: Brass, nickel-plated Flex Cable: 28 AWG, stranded/top coated wire, PVC coated on .050 or .100" centers (cabled version) Header Pins: Phospher bronze, tin-plated Spacer: ABS Backplate/Strain Relief: Stainless steel ORDERING INFORMATION Series Style: A = 1/2" package, 5.0 Vdc Input, D = high torque w/5.0 Vdc input, V = 3.3 Vdc input Angle of Throw: Detent Non-detent (Styles A&V only) 11 = 11.25° or 32 positions 01 = 11.25° or 32 positions 15 = 15° or 24 positions 05 = 15° or 24 positions 18= 18° or 20 positions 08= 18° or 20 positions 22 = 22.5° or 16 positions 02 = 22.5° or 16 positions 30 = 30° or 12 positions 03 = 30° or 12 positions Pushbutton Option: 01 = w/o pushbutton, 02 = with pushbutton 62A22-01-040S Termination: S = Stripped cable; .050" centers SH = Stripped cable; .100" centers C = Connector; .050" centers CH = Connector; .100" centers P = Pin; .100" centers Cable Length: Cable Terminination: 040 = 4.0in. Cable is terminated with Amp P/N 215083-6. See Amp Mateability Guide for Mating Connector details. *Eliminate cable length if ordering pins. (Ex: 62A22-02-P). These switches have Quadrature 2-bit code output and an optional shaft actuated pushbutton switch. Custom materials, styles, colors, and markings are available. Control knobs available. Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
62A11-02-040CH
物料型号:62A22-01-040S
器件简介:Grayhill的光学编码器,具有低成本、长寿命、高扭矩版本、经济尺寸等特点。
引脚分配:文档中提供了两种版本的引脚分配,包括3.3伏和5.0伏的配置,包括电源、输出A/B、非锁定式按钮开关和地线。
参数特性:包括操作扭矩、轴向轴向间隙、电压击穿、环境等级、供应电流、逻辑输出特性、旋转寿命、振动抵抗、功耗、光学上升和下降时间、机械冲击等。
功能详解:编码器提供标准正交2位编码输出,可选的轴向激活非锁定式按钮开关。
应用信息:适用于全球定位系统/驾驶员信息系统、医疗设备等。
封装信息:提供了详细的尺寸信息,包括电缆版本和引脚版本,以及材料和完成代码。
订购信息:提供了如何根据风格、角度、按钮选项、终止类型和电缆长度来订购产品的信息。
62A11-02-040CH 价格&库存
很抱歉,暂时无法提供与“62A11-02-040CH”相匹配的价格&库存,您可以联系我们找货
