62HS22-H0-150S
62HS22-H0-150S
    GRAYHILLINC.
    OPTICAL ENCODER
62HS22-H0-150S 数据手册
Optical Encoders SERIES 62HS High Torque FEATURES • High Rotational Torque Provides Positive Tactile Feedback • Optically Coupled for More than a Million Cycles • Optional Integral Pushbutton • Compatible with CMOS, TTL and HCMOS Logic DIMENSIONS • Available in 8,12 and 16 Detent Positions • Choice of Cable Length and Terminations APPLICATIONS • Avionics In inches (and millimeters) Unless otherwise specified, standard tolerance is ±.010 (0,25). Cable Version .236 [ 5,99 ] .219 ±.002 [ 5,56 ±0,05 ] CONNECTOR IS AMP P/N 215083-6 OR EQUIVALENT .110 [ 2,79 ] Optical and Mechanical Encoders .250 ±.002 [ 6,34 ±0,05 ] .066 ±.002 [ 1,68 ±0,05 ] .400 .200 [ 10,15 ] [ 5,08 ] 4.000 ±.200 4.000±5,08 .250 [ 6,35 ] .650 [ 16,5 ] .540 [ 13,72 ] .250 [ 6,35 ] .152 ±.002 [ 3,86 ±0,05 ] .500 [ 12,7 ] .750 [ 19,05 ] .375 [ 9,53 ] .511 [ 12,98 ] .312 [ 7,92 ] .530 ±.015 [ 13,46 ±0,38 ] Stripped Version Pin Version 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 (0, 76) OF SHOULDER .230 [ 5,84 ] .100 [ 2,54] 4.000 ±.200 4.000±5,08 .690 .015 [ 17,53 0,38 ] WAVEFORM AND TRUTH TABLE OUTPUT A OUTPUT B Clockwise Rotation Position Output A Output B HIGH 1 LOW 2 3 4 HIGH LOW 1 2 3 4 5 • • • • 6 POSITION NUMBER logic high; blank indicates • Indicates logic low. Code repeats every 4 positions. Encoder 10 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders CIRCUITRY PIN # POWER +5V 6 R* 5 OUTPUT A 100 : R* OUTPUT B 4 N.O. PUSHBUTTON SWITCH 3 2 1 GROUND * External pull-up resistors required for operation (2.2 k:). SPECIFICATIONS Pushbutton Switch Ratings Encoder Ratings Coding: 2-bit quadrature coded output Operating Voltage: 5.0 ±.25 Vdc Supply Current: 30 mA maximum@5.0 Vdc Logic Output Characterisitics: Logic High: 3.0 Vdc minimum Logic Low: 1.0 Vdc maximum Mechanical Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Minimum Sink Current: 2.0 mA for 5 Vdc Power Consumption: 150mW maximum Output: open collector phototransistor Logic Rise and Fall: less than 30 mS max Operating Torque: 5.0 in-oz +/- 1.5 in-oz initial Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs cable pull-out force minimum Operating Speed: 100 RPM maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Vibration Resistance: Harmonic motion with amplitude of 15G, within a varied 10 to 2000 Hz frequency for 12 hours Mechanical Shock: Test 1: 100G, 6 mS, half sine, 12.3 ft/s; Test 2: 100G, 6 mS, sawtooth, 9.7 ft/s Relative Humidity: 90–95% at 40°C for 96 hours Materials and Finishes Code Housing: Reinforced thermoplastic Shaft: Stainless Steel Bushing: Zinc casting Shaft Retaining Ring: Stainless steel Detent Spring: Stainless steel Detent Ball: Stainless steel Detent Section: Hiloy 610 Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and stainless steel lockwasher supplied with each switch. Nut is 0.094 inches thick by 0.562 inches across flats Rotor: Thermoplastic Pushbutton Dome: Stainless steel Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Flex Cable: 28 AWG, stranded/top coated wire, PVC coated on .050" centers (cabled version) Header Pins: Brass, tin-plated Spacer: Hiloy 610 Shim: Stainless Steel Backplate/Strain Relief: Stainless steel ORDERING INFORMATION Series Style: HS = High Torque Angle of Throw: 45 = 45° or 8 positions,30 = 30° or 12 positions, 22 = 22.5° or 16 positions 62HSXX-XX-XXXX Termination: S = stripped cable, C = connector, P = pins Cable Termination: 040 = 4.0in. Cable is terminated with Amp P/N 215083-6. See Amp Mateability Guide for mating connector details. *Eliminate cable length if ordering pins. (Ex: 62HS22-H9-P) Pushbutton Option: 0 = w/o pushbutton, 9 = 1100g Rotational Torque: H = High Torque Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Encoder 11 Optical and Mechanical Encoders Rating: at 5 Vdc, 10 mA, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations minimum Voltage Breakdown: 250 Vac between mutually insulated parts Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 1100 ±300g
62HS22-H0-150S
1. 物料型号:Grayhill系列62HS 2. 器件简介: - 符合RoHS标准 - 提供正向的触觉反馈 - 有8、12和16个定位点 - 光学耦合,耐用超过百万次循环 - 可选择电缆长度和端子 3. 引脚分配: - 电源+5V - 输出A和B - 常开按钮开关 - 地线 4. 参数特性: - 编码:2位正交编码输出 - 工作电压:5.0 ±0.25 Vdc - 供电电流:最大30 mA @ 5.0 Vdc - 逻辑输出特性:高电平至少3.0 Vdc,低电平最高1.0 Vdc - 机械寿命:至少100万次循环 5. 功能详解: - 编码器提供正交编码输出,用于位置和运动控制 - 可选的集成按钮开关 - 兼容CMOS、TTL和HCMOS逻辑 6. 应用信息: - 可用于航空电子等领域 7. 封装信息: - 尺寸详细描述,包括电缆版本和引脚版本 - 标准公差±0.010英寸(0.25毫米)
62HS22-H0-150S 价格&库存
很抱歉,暂时无法提供与“62HS22-H0-150S”相匹配的价格&库存,您可以联系我们找货
