62S11-M9-050C
62S11-M9-050C
    GRAYHILLINC.
    OPTICAL ENCODER
62S11-M9-050C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62S Compact 1/2'' Package FEATURES • Compact Size • Requires Minimal Behind Panel Space • 1 Million Rotational Cycles for Low and Medium Torque, 1/2 Million for High • 3 Million Rotations for Non-Detent Styles • Optional Integral Pushbutton • Choices of Cable Length and Terminations APPLICATIONS • Global Positioning/Driver Information Systems • Medical Equipment DIMENSIONS in inches (and millimeters) Unless otherwise specified, standard tolerance is ±.010 (0,25) Termination: -C .152±.002 (3,86±0,05) Termination: -P .066.002 (1,680,05) .152.002 (3,860,05) .066±.002 (1,68±0,05) .500 (12,7) Optical and Mechanical Encoders .500 (12,7) .250 (6,35) .540 (13,72) .249.002 (6,320,05) .250 (6,35) .687±.015 (17,45±0,38) .050 REF. (1,27) .540 (13,72) .250 (6,36) .219±.003 (5,56±0,07) .312 (7,92) .290 (7,34) .125 (3,18) .250 (6,35) .400 (10,15) .250 (6,35) .312 (7,92) 3/8-32 UNEF-2A THREAD .219.003 (5,560,07) 3/8-32 UNEF-2A THREAD .687.015 (17,450,38) CONNECTOR IS AMP P/N 215083-6 OR EQUIVALENT Ø.249.002 (6,320,05) .130 (3,3) .434.015 (11,020,38) .290 (7,37) .350.015 (8,880,38) CABLE LENGTH XXX.20 (XXX5,1) PINS ARE .016 SQUARE (0,41) Termination: -PH Termination: -CH .152.002 (3,860,05) .066.002 (1,680,05) .152.002 (3,860,05) .066.002 (1,680,05) .670 (17,02) .500 (12,7) .540 (13,72) .250 (6,35) .312 (7,92) .687.015 (17,450,38) .500 (12,7) .250 (6,35) 4.000.20 CABLE LENGTH IS MEASURED FROM THE PCB TO THE BOTTOM OF THE CONNECTOR .630 .500 (16) .250 (12,7) (6,35) .500 (12,7) .249.002 (6,320,05) .219.003 (5,560,07) .250 (6,35) .540 (13,72) 3/8-32 UNEF-2A THREAD .290 (7,37) CONNECTOR IS AMP P/N 640442-6 OR EQUIVALENT Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .100 REF. (2,54) .455 (11,56) .250 (6,35) .312 (7,92) Ø.249.002 (6,320,05) .219.003 (5,560,07) 3/8-32 UNEF-2A THREAD .687.015 (17,450,38) .574.015 (14,580,38) .230 (5,84) .290 (7,37) .400.015 (10,160,38) PINS ARE .025 SQUARE (0,64) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders Termination: -PV Environmental Specifications Operating Temp. Range: -40°C to 85°C Storage Temp. Range: -55°C to 100°C Humidity: 96 Hours at 90–95% humidity at 40°C Mechanical Vibration: Harmonic motion with amplitude of 15G's, within a varied frequency of 10 to 2000 Hz Mechanical Shock: Test 1: 100G for 6 mS, half sine wave with a velocity change of 12.3 ft/s; Test 2: 100G for 6 mS, sawtooth wave with a velocity change of 9.7 ft/s Rotary Electrical and Mechanical Specifications Operating Voltage: 5.00 ±0.25 Vdc Supply Current: 25mA max at 5.25Vdc Output: Open collector phototransistor, external pull up resistors are required Output Code: 2-Bit quadrature, channel A leads channel B by 90° electrically during clockwise rotation of the shaft Logic Output Characteristics: Logic High shall be no less than 3.8 Vdc Logic Low shall be no greater than 0.8Vdc Minimum Sink Current: 2.0 mA Power Consumption: 132mW maximum (includes power in 2 pull-up resistors) Mechanical Life: Non-Detent 3 Million Cycles Low & Medium 1 Million Cycles High 1/2 Million Cycles 1 cycle is a rotation through all positions and a full return Torque shall be within 50% of initial value throughout life Mounting Torque: 15 in-lbs maximum Shaft Push-Out Force: 45 lbs minimum Shaft Pull-Out Force: 45 lbs minimum Terminal Strength: 15 lbs minimum terminal pull-out force for cable or header termination Solderability: 95% free of pin holes and voids Pushbutton Electrical & Mechanical Specifications Rating: 10 mA at 5 Vdc Contact Resistance:
62S11-M9-050C 价格&库存
很抱歉,暂时无法提供与“62S11-M9-050C”相匹配的价格&库存,您可以联系我们找货
62S11-M9-050C
