62S22-L5-PV
62S22-L5-PV
    GRAYHILLINC.
    OPTICAL ENCODER
62S22-L5-PV 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62S Compact 1/2'' Package FEATURES • Compact Size • Requires Minimal Behind Panel Space • 1 Million Rotational Cycles for Low and Medium Torque, 1/2 Million for High • 3 Million Rotations for Non-Detent Styles • Optional Integral Pushbutton • Choices of Cable Length and Terminations APPLICATIONS • Global Positioning/Driver Information Systems • Medical Equipment .161 ± .002 [ 4,09 ± 0,05 ] .057 ± .002 [ 1,45 ± 0,05 ] Unless otherwise specified, standard tolerance is ±.010 (0,25) .066.002 (1,680,05) .152.002 (3,860,05) .066±.002 (1,68±0,05) .500 (12,7) .125 (3,18) .250 (6,35) Optical and Mechanical Encoders .500 (12,7) .250 (6,35) .540 (13,72) .250 (6,35) .312 (7,92) .687±.015 (17,45±0,38) .290 (7,34) Ø .380 ± .003 [ 9,65 ± 0,07 ] DIMENSIONS in inches (and millimeters) .152±.002 (3,86±0,05) RECOMMENDED PANEL CUTOUT .249.002 (6,320,05) .050 REF. (1,27) .540 (13,72) .250 (6,36) .219±.003 (5,56±0,07) .400 (10,15) .250 (6,35) .312 (7,92) 3/8-32 UNEF-2A THREAD .219.003 (5,560,07) 3/8-32 UNEF-2A THREAD .687.015 (17,450,38) CONNECTOR IS AMP P/N 215083-6 OR EQUIVALENT Ø.249.002 (6,320,05) .130 (3,3) .434.015 (11,020,38) .290 (7,37) .350.015 (8,880,38) CABLE LENGTH XXX.20 (XXX5,1) .152.002 (3,860,05) .066.002 (1,680,05) SCALE 0.500 .670 (17,02) .500 (12,7) .540 (13,72) .250 (6,35) .312 (7,92) .687.015 (17,450,38) .500 (12,7) .250 (6,35) 4.000.20 CABLE LENGTH IS MEASURED FROM THE PCB TO THE BOTTOM OF THE CONNECTOR .290 (7,37) CONNECTOR IS AMP P/N 640442-6 OR EQUIVALENT .066.002 (1,680,05) .152.002 (3,860,05) .219.003 (5,560,07) .250 (6,35) .100 REF. (2,54) .630 .500 (16) .250 (12,7) (6,35) .500 (12,7) .249.002 (6,320,05) PINS ARE .016 SQUARE (0,41) .540 (13,72) 3/8-32 UNEF-2A THREAD .455 (11,56) .250 (6,35) .312 (7,92) SCALE 0.500 Ø.249.002 (6,320,05) .219.003 (5,560,07) 3/8-32 UNEF-2A THREAD .687.015 (17,450,38) .574.015 (14,580,38) .230 (5,84) .290 (7,37) .400.015 (10,160,38) PINS ARE .025 SQUARE (0,64) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders CIRCUITRY, TRUTH TABLE, AND WAVEFORM Standard Quadrature 2-Bit Code PIN # POWER +5V 6 R* 5 OUTPUT A OUTPUT A R* OUTPUT B 4 N.O. PUSHBUTTON SWITCH 3 GROUND 1 OUTPUT B HIGH LOW HIGH LOW 1 2 SPECIFICATIONS Environmental Specifications Rotary Electrical and Mechanical Specifications Operating Voltage: 5.00 ±0.25 Vdc Supply Current: 25mA max at 5.25Vdc Output: Open collector phototransistor, external pull up resistors are required Output Code: 2-Bit quadrature, channel A leads channel B by 90° electrically during clockwise rotation of the shaft Logic Output Characteristics: Logic High shall be no less than 3.8 Vdc Logic Low shall be no greater than 0.8Vdc Minimum Sink Current: 2.0 mA Power Consumption: 132mW maximum (includes power in 2 pull-up resistors) Mechanical Life: Non-Detent 3 Million Cycles Low & Medium 1 Million Cycles High 1/2 Million Cycles 1 cycle is a rotation through all positions and a full return 3 4 5 POSITION NUMBER AVERAGE ROTATIONAL TORQUE SPECIFICATIONS LOW MEDIUM HIGH 8 POSITION 12 POSITION 16 POSITION 20 POSITION 24 POSITION 32 POSITION ±0.50 IN-OZ ±1.40 IN-OZ ±1.60 IN-OZ 1.10 1.00 1.40 1.35 1.25 0.95 1.85 1.70 2.35 2.05 1.95 1.40 2.75 2.95 3.40 2.80 2.95 2.15 Torque shall be within 50% of initial value throughout life Mounting Torque: 15 in-lbs maximum Shaft Push-Out Force: 45 lbs minimum Shaft Pull-Out Force: 45 lbs minimum Terminal Strength: 15 lbs minimum terminal pull-out force for cable or header termination Solderability: 95% free of pin holes and voids Pushbutton Electrical & Mechanical Specifications Rating: 10 mA at 5 Vdc Contact Resistance:
62S22-L5-PV 价格&库存
很抱歉,暂时无法提供与“62S22-L5-PV”相匹配的价格&库存,您可以联系我们找货
62S22-L5-PV
