61B22-01-02-060
61B22-01-02-060
    GRAYHILLINC.
    OPTICAL ENCODER
61B22-01-02-060 数据手册
Optical Encoders SERIES 61B 16, 24, or 32 Position, Optional Pushbutton FEATURES • Positions Screen Cursor • More Friendly than Keyboards • Permits Visual Concentration • Economic Touchscreen Alternative • Pushbutton for Entry Function • Detent for Tactile Feedback and Minimal Backlash • Optical Coupled for Long Life • Rugged Construction APPLICATIONS Optical and Mechanical Encoders Display Input Incremental Input The Series 61 rotary encoder switch can move cursor or icon on a display. Use the rotary and pushbutton switch to simply select a menu item and enter it, or write more elaborate display software. Use the Series 61 to input limit settings for a monitored function. Change an item on a checklist to a new value while viewing the remainder of the list. Use the Series 61 with an interface chip to provide step by step input for setting radio frequency, drill depth, RPM, etc. These changes are usually a few steps, and you need not turn the switch several revolutions for the desired value. Some examples are as follows: • Robot Position • Volume Setting • Radio Tuning • Limit Setting • Motor Control DIMENSIONS In inches (and millimeters) Diagram illustrates a 16-position switch with integral pushbutton switch. .859 ± .020 (22,1 ± 0,5) .769 ± .025 (19,5 ± 0,6) .375 ± .020 (9,5 ± 0,5) A ± 3˚ .250 ± .002 (6,35 ± 0,05) DIA. .312 ± .020 (7,9 ± 0,5) .152 ± .002 (3,86 ± 0,05) .200 ± .010 (5,1 ± 0,5) .562 ± .015 (14,3 ± 0,4) .050 ± .005 (1,3 ± 0,1) .015/ .040 (0,38/ 1,02) TRAVEL .066 ± .002 (1,68 ± 0,05) .219 ± .004 (5,6 ± 0,1) PIN 1 PIN 2 PIN 3 PIN 4 PIN 5 PIN 6 .250 ± .020 (6,4 ± 0,5) 3/8-32 UNEF-2A THREAD CL OF SWITCH *ANGLE A Centerline of switch to perpendicular of shaft flat 32 Pos. 24 Pos. 16 Pos. .293 ± .010 (7,4 ± 0,25) OF SWITCH CL CL OF PINS .025 ± .002 (0,6 ± 0,1) SQUARE PIN (6 PLACES) CL OF SHAFT FLAT Grayhill part number and date code marked on label. Customer part number marked on request. 5.63° 7.50° 11.25° .375 ± .020 (9,53 ± 0,51) A ± 3˚ .250 ± .002 (6,35 ± 0,05) DIA. .100 ± .005 (2,5 ± 0,1) TYPICAL .767 ± .020 (19,48 ± 0,51) SQUARE .950 (24,13) MAX. DIM. XXX* ± .30 (7,62) .562 ± .015 (14,27 ± 0,38) .312 ± .020 (7,92 ± 0,51) .152 ± .002 (3,86 ± 0,05) .015/.040 (0,38/1,02) TRAVEL PIN #1 PIN #2 PIN #3 PIN #4 PIN #5 PIN #6 .219 ± .004 (5,56 ± 0,10) .767 ± .020 (19,48 ± 0,51) SQUARE .066 ± .002 (1,68 ± 0,05) CL OF SWITCH CL OF SHAFT FLAT 3/8-32 UNEF-2A THREAD .250 ± .020 (6,35 ± 0,51) *See Ordering Information for cable length. Unless otherwise indicated, tolerances are ± .010 (0,25). I-19 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders SPECIFICATIONS Materials and Finishes Pushbutton Switch Ratings Rating: 5 Vdc, 10 mA, Resistive Contact Resistance: less than 10 (TTL or CMOS Compatible) Voltage Breakdown: 250 Vac between mutually insulated parts. Contact Bounce: Less than 4 milliseconds at make and less than 10 milliseconds at break Actuation Life: 3,000,000 operations Actuation Force: Maximum actuation force of 615 grams and a minimum actuation force of 415 grams. Encoder Ratings Coding: 2-bit quadrature coded output Operating Voltage: 5 ±.25 Vdc Supply Current: 30 mA maximum at 5 Vdc Logic High: 3.8V minimum Logic Low: 0.8V maximum Logic Rise and Fall Times: Rise Time less than 30 mS at 16.6 RPM. Fall Time less tham 30 mS at 16.6 RPM. Operating Torque: 2.0 ± .75 in-oz Rotational Life: more than 1,000,000 cycles of operation (1 cycle = 360° rotation and return) Shaft Push Out Force: 50 lbs minimum Mounting Torque: 15 in-lbs maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Vibration Resistance: Harmonic motion with amplitude of 15g, within a varied 10 to 2000 Hz frequency for 12 hours per MIL-STD-202, Method 204 Shock Resistance: Test 1: 100g for 6 mS half sine wave with velocity change of 12.3 ft/s. Test 2: 100g for 6 mS, sawtooth wave with velocity change of 9.7 ft/s. Relative Humidity: 90–95% at 40°C for 96 hours Detent Cover: Thermosetting plastic Bushing: Zinc casting, cadmium-plated per QQP–416, Class 2, Type II Shaft: Reinforced thermoplastic Note: Earlier versions may have electropolished stainless steel shafts (still available in customs only). Detent Balls: Passivated, stainless steel Detent Spring: Tinned music wire Printed Circuit Boards: NEMA Grade FR-4 Board Terminals: Copper alloy, CDA No. 725 Through Bolts: Stainless steel, unplated Through Bolt Nuts: Stainless steel Switch Assembly Cover and Code Rotor: PBT polyester thermoplastic Mounting Hardware: One brass, cadmiumplated nut and lockwasher supplied with each switch. Nut is 0.094" thick by 0.562" across flats. Strain Relief: PBT polyester thermoplastic (cable version only) Cable: 26 AWG, stranded/tinned wire, PVC coated on .100 (2,54) centers (cable version only) PIN# POWER +5V Clockwise Rotation Position Output A Output B 1 2 3 4 6 R* 5 OUTPUT A • • 150Ω R* OUTPUT B 4 Optical and Mechanical Encoders CIRCUITRY, TRUTH TABLE, AND WAVEFORM: Standard Quadrature 2-Bit Code • • logic high; blank indicates logic • Indicates low. Code repeats every 4 positions. 3 N.O. PUSHBUTTON SWITCH GROUND 2 OUTPUT A 1 OUTPUT B HIGH LOW HIGH LOW *EXTERNAL PULL UP RESISTORS REQUIRED FOR OPERATION. 8.2 kΩ IS SUGGESTED FOR TTL; 3.3 kΩ IS SUGGESTED FOR CMOS 1 2 3 4 5 6 POSITION NUMBER ORDERING INFORMATION Series Style: B = Standard, unsealed Angle of Throw: 11 = 11.25° or 32 Positions 15 = 15° or 24 Positions 22 = 22.25° or 16 Positions Coding: 01 = Quadrature Pushbutton Option: 01 = Without pushbutton, 02 = With pushbutton 61B11–01–02–020 Termination: Blank (no dash or numbers) = pins as described in drawing Cable Termination 020 = 2.0 inches minimum to 250 = 25 inches maximum. Provided in increments of 1/2 inch. Example 035 = 3.5", 060 = 6 inches. Cable is terminated with standard Amp Connector 640442-6. Use any 6 position, .100 center header to mate with the cable assembly. Contact Grayhill Custom shaft and bushing lengths, shaft/panel seal, and additional supply voltages are available through Grayhill only. Control knobs available, see page I-57. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. ACCESSORIES See page I-41. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com I-20
61B22-01-02-060 价格&库存
很抱歉,暂时无法提供与“61B22-01-02-060”相匹配的价格&库存,您可以联系我们找货
61B22-01-02-060
    • 1+1358.27358
    • 3+1142.61605
    • 7+1074.37019
    • 13+1013.86138
    • 25+846.94389
    • 100+706.02869
    • 250+635.44867
    库存:5
    61B22-01-02-060
      • 1+1954.98927
      • 3+1480.16937
      库存:5
