Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product.
Optical Encoders
SERIES 62B
Push-Pull, High Torque
FEATURES
• Multiple Switching Functions Available
in One Compact Device
• Push and Pull Travel Options
• Pull Shaft Resists Accidental
Actuation
• High Rotational Torque for Positive
Detent Feel and Superior Tactile
Feedback
• Long Life, High Reliability
• CMOS, HCMOS, and TTL Compatible
• Pin, Cable and Connector with Cable
Termination Options
• Custom Modifications Available
APPLICATIONS
• Use for Menu Scrolling or
• Function Selection
• Avionics
• Industrial
• Medical
DIMENSIONS in inches (and millimeters)
Connector Version
Pinned Version
Stripped Version
.430
(10,92)
Optical and Mechanical
Encoders
DIM "A"
SEE CHART
SHAFT-DETENT POSITION CHART
.350
(8,89)
(.050 SPC X 7)
.219.004
(5,560,1)
1.183±.015
(30,05±0,38)
4.000±.20
.400
(10,16)
.335
(8,51)
.161 ± .002
[ 4,09 ± 0,05 ]
.500
(12,7)
11.25
5.625
Ø .250.001)
(6,350,02)
.312
(7,92)
.707
(17,96)
3/8-32 UNEF-2A
THREAD
.395.015
(10,030,38)
Suggested Mounting Panel Cutout
DIM "A"
16
32
*SHAFT SHOWN IN A DETENT POSITION
Ø.687
(17,45)
CONNECTOR IS
AMP P/N 215083-8
OR EQUIVALENT
# POS
.250.004
(6,350,1)
1.045
(26,54)
1.080.015
(27,430,38)
Ø .380 ± .003
[ 9,65 ± 0,07 ]
.110
(2,79)
.100
(2,54)
XXX.20
SEE ORDERING INFO
*TOLERANCES.010 U.O.S.
.057 ± .002
[ 1,45 ± 0,05 ]
SWITCH SCHEMATIC, WAVEFORM, AND TRUTH TABLE
POWER (5V)
8
R*
OUTPUT A
OUTPUT B
7
R*
6
PULLBUTTON
5
PULLBUTTON
4
PUSHBUTTON
3
PUSHBUTTON
2
GROUND
*EXTERNAL 2.2k
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
1
PULL-UP RESISTANCE REQUIRED FOR OPERATION.
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Optical Encoders
WAVEFORM AND TRUTH TABLE
Standard Quadrature 2-Bit Code
HIGH
OUTPUT "A"
OUTPUT "B"
LOW
1
2
HIGH
LOW
Clockwise Rotation
Position
3
1
2
3
4
5
POSITION NUMBER
6
4
Output A
Output B
• Indicates logic high; blank indicates
logic low.
Code repeats every 4 positions.
SPECIFICATIONS
Environmental Specifications
Rotary Electrical and
Mechanical Specifications
Operating Voltage: 5.00±.25 Vdc
Supply Current: 30 mA maximum at 5 Vdc
Output: Open collector phototransistor, external pull-up resistors are required
Output Code: Two-bit quadrature, channel
A leads channel B by 900 electrically during
clockwise rotation of the shaft
Logic Output Characteristics:
Logic high signal shall be no less
than 3.0 Vdc
Logic low signal shall be no greater
than 1.0 Vdc
Minimum Sink Current: 2.0 mA
Power Consumption: 150 mW maximum
Mechanical Life: 1 million rotational cycles of
operation. One cycle is a rotation through all
positions and a full return
Average Rotational Torque: 16 position:
5.0 ± 1.5 in-oz, 32-position: 2.5 ±1 .5 in-oz.
Torque shall be within 50% of initial value
throughout life
Mounting Torque: 15 in-oz maximum
Shaft Push-Out Force: 45 lbs minimum
Shaft Pull-Out Force: 20 lbs minimum
Terminal Strength: 15 lbs minimum
terminal pull-out force for cable or header
termination
Solderability: 95% free of pin holes and
voids
Pull-Button/Push-Button Electrical
and Mechanical Specifications
Rating: 10 mA at 5 Vdc
Contact Resistance:
很抱歉,暂时无法提供与“62B11-LPP-040C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+933.3526825+119.72125
