62C1111-02-P
62C1111-02-P
    GRAYHILLINC.
    OPTICAL ENCODER
62C1111-02-P 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders Series 62C Concentric Shaft FEATURES • Economical Size • Combined Functionality • Optically Coupled for more than a Million Cycles of Operations • Optional Integral Pushbutton • Compatible with CMOS, TTL, and HCMOS Logic • Available with 12, 16, 24, and 32 Detent Positions for Deck • Choices of Cable Length and Terminations • Available in 3.3 Volt Input (contact Grayhill for details) APPLICATIONS • Used to Set Radio Frequency, Drill Depth, RPM, Menu Selection, Parameter Selection for Patient Monitoring Devices, etc. Unless otherwise specified, standard tolerance are: Linear ± .025 Deck A: 0.250 (6,35) shaft Diameter ± .010 Deck B: 0.125 (3,18) shaft Angle ± 2.0° G R AY H I L L 8 7 6 5 4 3 2 1 Suggested Mounting Panel Cutout Pin Version .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 .125 ± .002 (3,18 ± 0,05) .250 ± .005 (6,35 ± 0,13) .250 ± .005 (6,35 ± 0,13) CL .066 ± .005 (1,68 ± 0,13) Cable Version 28 AWG CABLE WIRES ON .050 (1,27) CENTER .152 ± .005 (3,86 ± 0,13) .360 ± .010 (9,14 ± 0,25) .540 ± .010 (13,72 ± 0,25) .100 (2,54) STRIPPED AND TINNED G R AY H I L L 8 7 6 5 4 3 2 1 .250 ± .002 (6,35 ± 0,05) .057 ± .002 [ 1,45 ± 0,05 ] 4.0 ± .20 (4.0 ± 5,08) 3/8-32 UNEF-2A THREAD. TO BE WITHIN .030 (0,76) OF SHOULDER [ 9,65 ± 0,07 ] .490 ± .010 (12,45 ± 0,25) .312 ± .005 (7,92 ± 0,13) .375 ± .015 (9,53 ± 0,38) CL .460 ± .010 (11,68 ± 0,25) .580 (14,73) .230 ± .050 (5,84 ± 1,27) 62CXXXX-XX-XXXC XXXX X-X Optical and Mechanical Encoders DIMENSIONS in inches (and millimeters) CONNECTOR IS AMP P/N 215083-8 .040 (1.02) .094 ± .004 (2,39 ± 0,1) .250 ± .005 (6,35 ± 0,13) .219 ±.004 (5,56 ± 0,1) .250 ± .005 (6,35 ± 0,13) .375 ± .015 (9,53 ± 0,38) .933 (23,69) REF. .500 ±.010 (12,7 ± 0,25) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders CIRCUITRY, TRUTH TABLE AND WAVEFORM: Standard Quadrature 2-Bit Code PIN# POWER +5V Clockwise Rotation Position Output A Output B 1 2 3 4 8 R* OUTPUT A DECK A 7 • • R* OUTPUT B DECK A 6 R* OUTPUT A DECK B Indicates logic high; blank indicates • logic low. Code repeats every 4 positions. 5 R* OUTPUT B DECK B 4 N.O. PUSHBUTTON SWITCH DECK B 3 OUTPUT A 2 GROUND • • OUTPUT B 1 HIGH LOW HIGH LOW 1 * External pull-up resistors required for operation (2.2kΩ) 2 3 4 5 6 POSITION NUMBER SPECIFICATIONS Pushbutton Switch Ratings Encoder Ratings Coding: 2-bit quadrature coded output Operating Voltage: 5 ± .25 Vdc Supply Current: 50 mA maximum at 5 Vdc Logic High: 3.8V minimum Logic Low: 0.8V maximum Logic Rise and Fall Times: less than 30 mS Operating Torque: 2.0 in-oz ± 1.4 in-oz initially Rotational Life: more than 1,000,000 cycles of operation (1 cycle = 360° rotation) Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Operating Speed: 100 RPM maximum Axial Shaft Play: 0.010 max. for each shaft Environmental Ratings Operating Temp. Range: -40°C to 85°C Storage Temp. Range: -55°C to 100°C Relative Humidity: 90–95% at 40°C, 96 hrs. Vibration Resistance: Harmonic motion with amplitude of 15g, within a varied 10 to 2000 Hz frequency for 12 hours per MIL-STD-202, Method 204 Shock Resistance: Test 1: Tested at 100g for 6 mS, half sine, 12.3 ft/s Test 2: 100g for 6 mS, sawtooth, 9.7 ft/s ORDERING INFORMATION Materials and Finishes Bushing: Zinc casting Shaft: Aluminum Shaft Retaining Ring: Stainless steel Detent Spring: Stainless steel Printed Circuit Board: NEMA grade FR-4 Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and zinc-plated spring steel with clear trivalent chromate finish lockwasher supplied with each switch. (Nut is 0.094 inches thick by 0.433 inches across flats) Rotor: Thermoplastic Code Housing: Reinforced thermoplastic Pushbutton Dome: Stainless steel Pushbutton Housing: Thermoplastic Pushbutton Contact: Brass, nickel-plated Dome Retaining Disk: Thermoplastic Strain Relief: Stainless steel Cable: 28 AWG, stranded/top coated wire, PVC coated on .050 centers (cable version) Header Pins: Phosphor bronze, tin-plated Insulator: Glass-filled polyester Spacer: Zinc casting 62C2211- 02 - 040 C Series Style: C = Concentric Angle of Throw (Deck A): 11 = 11.25° or 32 positions, 15 = 15° or 24 positions, 22 = 22.5° or 16 positions, 30 = 30° or 12 Positions Angle of Throw (Deck B): 11 = 11.25° or 32 positions, 15 = 15° or 24 positions, 18 = 18° or 20 positions, 22 = 22.5° or 16 positions, 30 = 30° or 12 Positions Termination: S = stripped cable, C = connector, P = pins Cable Termination: 040 = 4.0in. Cable is terminated with Amp Connector P/N 215083-6. See Amp Mateability Guide for mating connector details. *Eliminate cable length if ordering pins. (Ex: 62C2211-02-P) Pushbutton Option: 01 = w/o pushbutton 02 = with pushbutton Custom shaft, pushbutton actuation force and termination options are available. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders Rating: 5 Vdc, 10 mA, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Voltage Breakdown: 250 Vac between mutually insulated parts Contact Bounce: less than 4 mS at make, less than 10 mS at break Actuation Life: 3,000,000 operations Actuation Force: 1000 ± 300 grams Pushbutton Travel: .010 / .025 inch
62C1111-02-P 价格&库存
很抱歉,暂时无法提供与“62C1111-02-P”相匹配的价格&库存,您可以联系我们找货
