62R22-01-040C
62R22-01-040C
    GRAYHILLINC.
    OPTICAL ENCODER
62R22-01-040C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62R 1/2'' Package, Redundant Circuitry FEATURES • Redundant Circuitry • 1 Million Rotational Cycles • Compatible with CMOS, TTL and HCMOS Logic • Optional Integral Pushbutton • Available in 12, 16, and 24 Detent Positions • Choices of Cable Length and Terminations • Ideal for Critical Applications APPLICATIONS • Cockpit Controls • Medical Equipment Cable Version Pin Version 4.000±.20 (4.000±5,08) 3/8-32 UNEF-2A THREAD.TO BE WITHIN .030 (0,76) OF SHOULDER GRAYHILL .100 (2,54) STRIPPED AND TINNED .250±.002 (6,35±0,05) DIA. 10 9 8 7 6 5 4 3 2 1 GRAYHILL .230±.050 (5,84±1,27) 10 9 8 7 6 5 4 3 2 1 .250±.005 (6,35±0,13) 28 AWG CABLE WIRES ON .050 (1,27) CENTER .152±.005 (3,86±0,13) .066±.005 (1,68±0,13) .360±.010 (9,14±0,25) .312±.005 (7,92±0,13) .490±.010 (12,45±0,25) .815±.015 (20,70±0,38) XXXX X-X .540±.010 (13,72±0,25) 62RXXXX-XX-XXXC Optical and Mechanical Encoders DIMENSIONS in inches (and millimeters) CONNECTOR IS AMP P/N 1-215083-0 .460±.010 (11,68±0,25) .580±.010 (14,73±0,25) .250±.005 (6,35±0,13) .219±.004 (5,56±0,1) .375±.015 (9,53±0,38) .855±.020 (21,7±0,51) .250±.005 (6,35±0,13) .933(23,69) REF. .500±.010 (12,7±0,25) .700±.010 (17,78±0,25) RECOMMENDED PANEL CUTOUT .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 [ 9,65 ± 0,07 ] Unless otherwise specified, standard tolerances are ±0.10 (0,25) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .057 ± .002 [ 1,45 ± 0,05 ] 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders CIRCUITRY, TRUTH TABLE, AND WAVEFORM Standard Quadrature 2-Bit Code Switch Schematic PIN # DECK B POWER 5V 10 DECK A POWER 5V 9 R* DECK A OUTPUT "A" R* DECK A OUTPUT "B" DECK B OUTPUT "A" DECK B OUTPUT "B" R* R* PUSHBUTTON N.O. Truth Table (CW Rotation) DECK A DECK B POSITION OUTPUT "A" OUTPUT "B" OUTPUT "A" OUTPUT "B" 1 2 3 4 8 7 INDICATES LOGIC HIGH. BLANK INDICATES LOGIC LOW. CODE REPEATS EVERY 4 POSITIONS 6 5 Wave Form (CW Rotation) 4 OUTPUT "A" DECK A 3 DECK A GROUND 2 DECK B GROUND 1 DECK B * 2.2k EXTERNAL PULL-UP RESISTORS REQUIRED FOR OPERATION HIGH LOW HIGH OUTPUT "B" LOW HIGH OUTPUT "A" LOW HIGH OUTPUT "B" LOW POS. #1 SPECIFICATIONS Pushbutton Switch Ratings Switch Ratings Coding: 2-bit quadrature coded output Operating Voltage: 5.0 ±.25 Vdc Voltage Breakdown: 250 Vac between mutually insulated parts Supply Current: 30 mA maximum@5.0 Vdc (per deck) Logic Output Characterisitics: Logic High: 3.5 Vdc minimum Logic Low: 1.5 Vdc maximum Mechanical Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Minimum Sink Current: 2.0 mA Power Consumption: 150mW max. (per deck) Output: open collector phototransistor Optical Rise and Fall Times: less than 30 mS maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Vibration Resistance: Harmonic motion with amplitude of 15G's, within a varied 10 to 2000 Hz frequency for 12 hours Mechanical Shock: Test 1: 100g, 6 mS, half sine, 12.3 ft/s; Test 2: 100g, 6 mS, sawtooth, 9.7 ft/s Humidity: 90–95% at 40°C for 96 hours Materials and Finishes Shaft: Aluminum Bushing: Zinc casting Shaft Retaining Ring: Stainless steel Detent Spring: Stainless steel Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated POS. #3 POS. #4 POS. #5 POS. #6 Mounting Hardware: One brass, nickel-plated nut and zinc-plated spring steel with clear trivalent chromate finish lockwasher supplied with each switch. (Nut is 0.094 inches thick by 0.433 inches across flats) Rotor: Thermoplastic Code Housing: Thermoplastic Pushbutton Dome: Stainless steel Dome Retaining Disk: Thermoplastic Pushbutton Housing: Thermoplastic Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Pushbutton Contact: Brass, nickel-plated Flex Cable: 28 AWG stranded, halogen-free polyolefin insulation on .050" centers (cabled version) Header Pins: Phospher bronze, tin-plated Spacer: Zinc casting Backplate/Strain Relief: Stainless steel Studs: Stainless steel OPTIONS Contact Grayhill for custom terminations, shaft and bushing configurations, and resolutions. Control knobs are also available. ORDERING INFORMATION 62R22-01-040S Series Angle of Throw: 15 = 15° or 24 pos, 22 = 22.5° or 16 positions, 30 = 30° or 12 Positions Pushbutton Option: 01 = w/o pushbutton, 02 = with pushbutton Termination: .050" centers; S = Stripped cable, C = Connector, P = Pin Cable Length: 040 = 4.0 inches. Cable is terminated with Amp Connector P/N 215083-8. See Amp Mateability Guide for mating connector details. *Eliminate cable length if ordering pins. (Ex: 62R22-02-P) Custom materials, styles, colors, and markings are available. Control knobs available. Available from your local Component Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders Pushbutton Rating: 10 mA, 5 Vdc, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations min. Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 1000 ±300 grams Pushbutton Travel: .010/.025" Operating Torque: 3.5 ±1.4 in-oz initially Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs max. Terminal Strength: 15 lbs cable pull-out force min. Operating Speed: 100 RPM max. POS. #2
62R22-01-040C 价格&库存
很抱歉,暂时无法提供与“62R22-01-040C”相匹配的价格&库存,您可以联系我们找货
