62H3030-H0-080S
62H3030-H0-080S
    GRAYHILLINC.
    OPTICAL ENCODER
62H3030-H0-080S 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62H High Torque, Concentric Shaft FEATURES • High Rotational Torque Provides Positive Tactile Feedback • Optically Coupled for More than a Million Cycles • Optional Integral Pushbutton • Compatible with CMOS, TTL and HCMOS Logic DIMENSIONS in inches (and millimeters) • Available in 8,12 and 16 Detent Positions • Choice of Cable Length and Terminations APPLICATIONS • Avionics Cable Version Suggested Mounting Panel Cutout .219 ±.002 [ 5,56 ±0,05 ] .236 [ 5,99 ] .110 [ 2,79 ] Optical and Mechanical Encoders .401 [ 10,19 ] .527 [ 13,39 ] .250 ±.002 [ 6,34 ±0,05 ] .125 ±.002 [ 3,18 ±0,05 ] CONNECTOR IS AMP P/N 215083-8 OR EQUIVALENT Pin 1 .161 ± .002 [ 4,09 ± 0,05 ] [ 9,65 ± 0,07 ] Pin 8 .057 ± .002 [ 1,45 ± 0,05 ] .066 ±.002 [ 1,68 ±0,05 ] .490 [ 12,45 ] .200 [ 5,08 ] Ø .380 ± .003 4.000 ± .200 4.000 ± 5,08 .094 ±.002 .250 [ 2,39 ±0,05 ] [ 6,35 ] .250 [ 6,35 ] .500 [ 12,7 ] .375 [ 9,53 ] .740 [ 18,8 .540 [ 13,72 .250 [ 6,35 ] .152 ±.002 [ 3,86 ±0,05 ] ] ] .750 [ 19,05 ] .817 [ 20,75 ] .375 [ 9,53 ] .312 [ 7,92 ] .878 [ 22,3 ] Stripped Version Pin Version 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 (0, 76) OF SHOULDER .335 [ 8,51 ] .100 [ 2,54 ] 1.126 ±.015 4.000 ± .200 4.000 ± 5,08 [ 28,6 ±0,38 ] WAVEFORM AND TRUTH TABLE OUTPUT A OUTPUT B Clockwise Rotation Position Output A Output B HIGH 1 LOW 2 3 4 HIGH LOW 1 2 3 4 5 6 POSITION NUMBER Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois • • • • • Indicates logic high; blank indicates logic low. Code repeats every 4 positions. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders CIRCUITRY POWER 5 V R* OUTPUT A DECK A R* OUTPUT B DECK A OUTPUT A DECK B OUTPUT B DECK B R* R* 8 7 100 100 6 5 4 PUSHBUTTON 3 PUSHBUTTON 2 1 GROUND * External pull-up resistors required for operation (2.2 k ). SPECIFICATIONS Pushbutton Switch Ratings Encoder Ratings Coding: 2-bit quadrature coded output Operating Voltage: 5.0 ±.25 Vdc Supply Current: 50 mA maximum@5.0 Vdc Logic Output Characterisitics: Logic High: 3.0 Vdc minimum Logic Low: 1.0 Vdc maximum Mechanical Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Minimum Sink Current: 2.0 mA for 5 Vdc Power Consumption: 150mW maximum Output: open collector phototransistor Logic Rise and Fall Times: less than 30 mS maximum Operating Torque: 5.0 in-oz +/- 1.5 in-oz initial Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs cable pull-out force minimum Operating Speed: 100 RPM maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Vibration Resistance: Harmonic motion with amplitude of 15G, within a varied 10 to 2000 Hz frequency for 12 hours Mechanical Shock: Test 1: 100G, 6 mS, half sine, 12.3 ft/s; Test 2: 100G, 6 mS, sawtooth, 9.7 ft/s Relative Humidity: 90–95% at 40°C for 96 hours Materials and Finishes Code Housing: Reinforced thermoplastic Shafts: Stainless steel ORDERING INFORMATION Bushing: Zinc casting Pushbutton Actuator: Zytel 70G33L Shaft Retaining Rings: Stainless steel Detent Spring: High carbon steel Detent Ball: Stainless steel Detent Section: Hiloy 610 Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and zinc-plated spring steel with clear trivalent chromate finish lockwasher supplied with each switch. (Nut is 0.094 inches thick by 0.433 inches across flats) Rotor: Thermoplastic Pushbutton Dome: Stainless steel Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Flex Cable: 28 AWG, stranded/top coated wire, PVC coated on .050 or .100" centers (cabled version) Header Pins: Brass, tin-plated Spacer: Hiloy 610 Shim: Stainless Steel Backplate/Strain Relief: Stainless steel Lockwashers: Stainless steel Hex Nuts: Stainless steel Studs: Stainless steel Series Style: H = High Torque, Concentric Angle of Throw (Deck A): 45 = 45° or 8 positions,30 = 30° or 12 positions, 22 = 22.5° or 16 positions Angle of Throw (Deck B): 45 = 45° or 8 positions, 30 = 30° or 12 positions, 22 = 22.5° or 16 positions 62HXXXX-XX-040C Termination: S = stripped cable, C = connector, P = pins Cable Termination: 040 = 4.0in. Cable is terminated with Amp Connector P/N 215083-8. See Amp Mateability Guide for mating connector details. *Eliminate cable length if ordering pins. (Ex: 62H2222-H9-P) Pushbutton Option: 0 = w/o pushbutton, 9 = 1100g pushbutton Rotational Torque: H = High Torque Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders Rating: at 5 Vdc, 10 mA, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations minimum Voltage Breakdown: 250 Vac between mutually insulated parts Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 1100 ±300g Shaft Travel: .025±.010 inch
62H3030-H0-080S 价格&库存
很抱歉,暂时无法提供与“62H3030-H0-080S”相匹配的价格&库存,您可以联系我们找货
