62HN22-H9-P
62HN22-H9-P
    GRAYHILLINC.
    OPTICAL ENCODER
62HN22-H9-P 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62HN High Torque, Non-Turn Concentric Shaft • Compatible with CMOS, TTL and HCMOS Logic • Available in 8,12 and 16 Detent Positions • Choice of Cable Length and Terminations FEATURES • High Rotational Torque Provides Positive Tactile Feedback • Non-turn Pushbutton to Ensure Pushbutton Text and Orientation • Optically Coupled for More than a Million Cycles • Seperate Pushbutton Function APPLICATIONS • Avionics DIMENSIONS in inches (and millimeters) Cable Version CONNECTOR IS AMP .236 [ 5,99 ] .219 ±.002 [ 5,56 ±0,05 ] .110 [ 2,79 ] Pin 1 Pin Version CONNECTOR IS AMP P/N 215083-8 OR EQUIVALENT .335 [ 8,51 ] CONNECTOR IS AMP Optical and Mechanical Encoders Pin 8 .125 ±.002 [ 3,18 ±0,05 ] .066 ±.002 [ 1,68 ±0,05 ] 1.000 ±.015 [ 25,4 ±0,38 ] .250 ±.002 [ 6,34 ±0,05 ] .200 [ 5,08 ] .490 [ 12,45 ] .094 ±.002 [ 2,39 ±0,05 ] DIM. 4.000 ± .200 DIM. 4.000 ± 5,08 .250 [ 6,35 ] .250 [ 6,35 ] .152 ±.002 [ 3,86 ±0,05 ] .500 [ 12,7 ] .750 [ 19,05 ] Stripped Version .375 [ 9,53 ] .375 [ 9,53 ] .740 [ 18,8 ] .540 [ 13,72 ] .691 [ 17,55 ] .785 [ 19,94 ] .312 [ 7,92 ] .250 [ 6,35 ] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 (0, 76) OF SHOULDER Suggested Mounting Panel Cutout .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 [ 9,65 ± 0,07 ] .100 [ 2,54 ] 4.000 ± .200 4.000 ± 5,08 Unless otherwise specified, standard tolerance is ±.010 (0,25). .057 ± .002 [ 1,45 ± 0,05 ] CIRCUITRY 8 POWER 5 V R* OUTPUT A DECK A R* OUTPUT B DECK A 7 100 100 6 R* 5 NO FUNCTION R* NO FUNCTION 4 PUSHBUTTON 3 PUSHBUTTON 2 GROUND 1 * External pull-up resistors required for operation (2.2 k Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois ). 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders WAVEFORM AND TRUTH TABLE OUTPUT A OUTPUT B Clockwise Rotation Position Output A Output B HIGH 1 LOW 2 3 4 HIGH LOW 1 2 3 4 5 • • • • • Indicates logic high; blank indicates logic low. Code repeats every 4 6 POSITION NUMBER positions. SPECIFICATIONS Pushbutton Switch Ratings Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs cable pull-out force minimum Operating Speed: 100 RPM maximum Encoder Ratings Environmental Ratings Coding: 2-bit quadrature coded output Operating Voltage: 5.0 ±.25 Vdc Supply Current: 30 mA maximum@5.0 Vdc Logic Output Characteristics: Logic High: 3.0 Vdc minimum Logic Low: 1.0 Vdc maximum Mechanical Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Minimum Sink Current: 2.0 mA for 5 Vdc Power Consumption: 150mW maximum Output: open collector phototransistor Logic Rise and Fall Times: less than 30 mS maximum Operating Torque: 5.0 in-oz +/- 1.5 in-oz initial Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Vibration Resistance: Harmonic motion with amplitude of 15G, within a varied 10 to 2000 Hz frequency for 12 hours Mechanical Shock: Test 1: 100G, 6 mS, half sine, 12.3 ft/s; Test 2: 100G, 6 mS, sawtooth, 9.7 ft/s Relative Humidity: 90–95% at 40°C for 96 hours Materials and Finishes Code Housing: Reinforced thermoplastic Shafts: Stainless steel Bushing: Zinc casting Shaft Retaining Rings: Stainless steel Detent Spring: High carbon steel Detent Ball: Stainless steel Detent Section: Hiloy 610 Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and zinc-plated spring steel with clear trivalent chromate finish lockwasher supplied with each switch. (Nut is 0.094 inches thick by 0.433 inches across flats) Rotor: Thermoplastic Pushbutton Dome: Stainless steel Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Flex Cable: 28 AWG, stranded/top coated wire, PVC coated on .050 centers (cabled version) Header Pins: Brass, tin-plated Spacer: Hiloy 610 Shim: Stainless Steel Endcap: Thermoplastic Non-turn Pin: Stainless steel Backplate/Strain Relief: Stainless steel Studs: Stainless steel ORDERING INFORMATION Series Style: HN = High Torque, Concentric, Non-Turn Angle of Throw: 45 = 45° or 8 positions,30 = 30° or 12 positions, 22 = 22.5° or 16 positions 62HNXX-XX-040C Termination: S = stripped cable, C = connector, P = pins Cable Termination: 040= 4.0in. Cable is terminated with Amp Connector P/N 215083-8. See Amp Mateability Guide for mating connector details. *Eliminate cable length if ordering pins. (Ex: 62HN22-H9-P) Pushbutton Option: 0 = w/o pushbutton, 9 = 1100g pushbutton Rotational Torque: H = High Torque Custom materials, styles, colors, and markings are available. Control knobs available. Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders Rating: at 5 Vdc, 10 mA, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations minimum Voltage Breakdown: 250 Vac between mutually insulated parts Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 1100 ±300g Shaft Travel: .025+/-.010 inch
62HN22-H9-P 价格&库存
很抱歉,暂时无法提供与“62HN22-H9-P”相匹配的价格&库存,您可以联系我们找货
62HN22-H9-P
