62T22-M10-040C
62T22-M10-040C
    GRAYHILLINC.
    OPTICAL ENCODER
62T22-M10-040C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders Series 62T Thumbwheel with Pushbutton FEATURES • • • • • • • APPLICATIONS Scroll and select functions Sealed against dust and particles Custom bezels that will blend with HMI grips and control panels Optional integrated pushbutton with over three million actuations MIL-STD-202 and MIL-STD-810F Compliant Standard panel seal Choice of cable length and termination • Scroll & select equipment in industrial and non-automotive transportation applications Display selectors Hand-grip joysticks • • DIMENSIONS in inches (and millimeters) Optical and Mechanical Encoders 1.758 [ 44,65 ] 1.500 ± .005 [ 38,1] Ø .200 ± .005 [ 5,0 ] C-BORE .265 X2 .327 [ 8,31] Unless otherwise specified, standard tolerances are: Linear ± .025 Diameter ± .010 Angle ± 2.0 0 .114 ±.015 [ 2,9 ] .780 [ 19,81] .020 [ 0,51 ] Ø.950 [ 24,13] CLOCKWISE ROTATION .485 [ 12,32 ] .830 [ 21,08 ] Ø.128 ± .002 [ 3,25 ] THRU HOLE X2 .640 [ 16,26 ] .125 [ 3,18 ] OF WHEEL 4.00 ±.25 .020 [ 0,51 ] .515 [ 13,08 ] .650 [ 16,51 ] RECOMMENDED PANEL CUTOUT AMP CONNECTOR PN 7-215083-6 1.300 ± -.005 [33,02 ± 0,12] 0.063± 0.005 [1,60± 0.12] .970 [ 24,64 ] R.250 [ 6,35 ] 0.660 ± 0.005 [16.76± 0,12] Thru 2 X 5-40 Tapped Hole Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 1.500 ± -.005 [38,10± 0,12] 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders WAVEFORM AND TRUTH TABLE +5Vdc R* OUTPUT "A" OUTPUT "B" R* 90˚± 45˚ 1 2 HIGH (3.8-5V) 3 OUTPUT A LOW (0-.8V) GROUND 4 PUSHBUTTON 5 PUSHBUTTON 6 POSITION OUTPUT B #2 N.O., MOMENTARY PUSHBUTTON SWITCH HIGH (3.8-5V) #3 OUTPUT B LOW (0-.8V) #4 POS #1 POS #2 POS #3 POS #4 POS #5 POS #6 R* - TWO 2.2K RESISTORS REQUIRED FOR OPERATION. SPECIFICATIONS Operating Temperature Range: -400 C to 850 C Storage Temperature Range: -550 C to 1000 C Humidity: 240 hours at 95% humidity at 300 C Mechanical Vibration: Harmonic motion with amplitude of 15g, within a varied frequency of 10 to 2000 Hz Mechanical Shock: Test 1: 100g for 6 ms half-sine wave with a velocity change of 12.3 ft/sec Test 2: 100g for 6 ms sawtooth wave with a velocity change of 9.7 ft/sec Rating: 10mA @ 5 Vdc Contact Resistance:
62T22-M10-040C 价格&库存
很抱歉,暂时无法提供与“62T22-M10-040C”相匹配的价格&库存,您可以联系我们找货
62T22-M10-040C
