62H2222-H9-040S
62H2222-H9-040S
    GRAYHILLINC.
    OPTICAL ENCODER
62H2222-H9-040S 数据手册
Optical Encoders SERIES 62H High Torque, Concentric Shaft FEATURES • High Rotational Torque Provides Positive Tactile Feedback • Optically Coupled for More than a Million Cycles • Optional Integral Pushbutton • Compatible with CMOS, TTL and HCMOS Logic DIMENSIONS in inches (and millimeters) • Available in 8,12 and 16 Detent Positions • Choice of Cable Length and Terminations APPLICATIONS • Avionics Cable Version .219 ±.002 [ 5,56 ±0,05 ] .110 [ 2,79 ] .250 ±.002 [ 6,34 ±0,05 ] .125 ±.002 [ 3,18 ±0,05 ] .236 [ 5,99 ] CONNECTOR IS AMP P/N 215083-8 OR EQUIVALENT Optical and Mechanical Encoders .401 [ 10,19 ] .527 [ 13,39 ] .066 ±.002 [ 1,68 ±0,05 ] .490 [ 12,45 ] 4.000 ± .200 4.000 ± 5,08 .094 ±.002 .250 [ 2,39 ±0,05 ] [ 6,35 ] .200 [ 5,08 ] .250 [ 6,35 ] .740 [ 18,8 .540 [ 13,72 .250 [ 6,35 ] .152 ±.002 [ 3,86 ±0,05 ] ] .500 [ 12,7 ] ] .750 [ 19,05 ] .375 [ 9,53 ] .817 [ 20,75 ] .375 [ 9,53 ] .878 [ 22,3 ] .312 [ 7,92 ] Pin Version Stripped Version 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 (0, 76) OF SHOULDER .335 [ 8,51 ] [ .100 2,54 ] 1.126 ±.015 [ 28,6 ±0,38 ] 4.000 ± .200 4.000 ± 5,08 WAVEFORM AND TRUTH TABLE OUTPUT A OUTPUT B Clockwise Rotation Position Output A Output B HIGH 1 LOW 2 3 4 HIGH LOW 1 2 3 4 5 POSITION NUMBER 6 • • • • • Indicates logic high; blank indicates logic low. Code repeats every 4 positions. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders CIRCUITRY POWER 5 V R* OUTPUT A DECK A R* OUTPUT B DECK A 100 100 5 R* OUTPUT B DECK B 7 6 R* OUTPUT A DECK B 8 4 PUSHBUTTON 3 PUSHBUTTON 2 1 GROUND *EXTERNAL 2.2k PULL-UP RESISTORS REQUIRED FOR OPERATION SPECIFICATIONS Pushbutton Switch Ratings Encoder Ratings Coding: 2-bit quadrature coded output Operating Voltage: 5.0 ±.25 Vdc Supply Current: 50 mA maximum@5.0 Vdc Logic Output Characterisitics: Logic High: 3.0 Vdc minimum Logic Low: 1.0 Vdc maximum Mechanical Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Minimum Sink Current: 2.0 mA for 5 Vdc Power Consumption: 150mW maximum Output: open collector phototransistor Logic Rise and Fall Times: less than 30 mS maximum ORDERING INFORMATION Operating Torque: 5.0 in-oz +/- 1.5 in-oz initial Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs cable pull-out force minimum Operating Speed: 100 RPM maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Vibration Resistance: Harmonic motion with amplitude of 15G, within a varied 10 to 2000 Hz frequency for 12 hours Mechanical Shock: Test 1: 100G, 6 mS, half sine, 12.3 ft/s; Test 2: 100G, 6 mS, sawtooth, 9.7 ft/s Relative Humidity: 90–95% at 40°C for 96 hours Materials and Finishes Code Housing: Reinforced thermoplastic Shafts: Stainless Steel Bushing: Zinc casting Pushbutton Actuator: Zytel 70G33L Shaft Retaining Rings: Stainless steel Detent Spring: Stainless steel Detent Ball: Stainless steel Detent Section: Hiloy 610 Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and zinc-plated spring steel with clear trivalent chromate finish lockwasher supplied with each switch. (Nut is 0.094 inches thick by 0.433 inches across flats) Rotor: Thermoplastic Pushbutton Dome: Stainless steel Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Flex Cable: 28 AWG, stranded/top coated wire, PVC coated on .050 or .100" centers (cabled version) Header Pins: Brass, tin-plated Spacer: Hiloy 610 Shim: Stainless Steel Backplate/Strain Relief: Stainless steel Lockwashers: Stainless steel Hex Nuts: Stainless steel Studs: Stainless steel Series Style: H = High Torque, Concentric Angle of Throw (Deck A): 45 = 45° or 8 positions,30 = 30° or 12 positions, 22 = 22.5° or 16 positions Angle of Throw (Deck B): 45 = 45° or 8 positions, 30 = 30° or 12 positions, 22 = 22.5° or 16 positions 62HXXXX-XX-040C Termination: S = stripped cable, C = connector, P = pins Cable Termination: 040 = 4.0in. Cable is terminated with Amp Connector P/N 215083-8. See Amp Mateability Guide for mating connector details. *Eliminate cable length if ordering pins. (Ex: 62H2222-H9-P) Pushbutton Option: 0 = w/o pushbutton, 9 = 1100g pushbutton Rotational Torque: H = High Torque Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders Rating: at 5 Vdc, 10 mA, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations minimum Voltage Breakdown: 250 Vac between mutually insulated parts Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 1100 ±300g Shaft Travel: .020±.010 inch
62H2222-H9-040S 价格&库存
很抱歉,暂时无法提供与“62H2222-H9-040S”相匹配的价格&库存,您可以联系我们找货
