62T22-M7-040C
62T22-M7-040C
    GRAYHILLINC.
    OPTICAL ENCODER
62T22-M7-040C 数据手册
Optical Encoders Series 62T Thumbwheel with Pushbutton FEATURES • Scroll and select functions • Sealed against dust and particles • Custom bezels that will blend with HMI grips and control panels • Optional integrated pushbutton with over three million actuations • MIL-STD-202 and MIL-STD-810F Compliant • Standard panel seal • Choice of cable length and termination APPLICATIONS • Scroll & select equipment in industrial and non-automotive transportation applications • Display selectors • Hand-grip joysticks DIMENSIONS in inches (and millimeters) Optical and Mechanical Encoders 1.758 [ 44,65 ] 1.500 ± .005 [ 38,1] Ø .200 ± .005 [ 5,0 ] C-BORE .265 X2 Unless otherwise specified, standard tolerances are: Linear ± .025 Diameter ± .010 Angle ± 2.0 0 .327 [ 8,31] .780 [ 19,81] .020 [ 0,51 ] Ø.950 [ 24,13] CLOCKWISE ROTATION .485 [ 12,32 ] .830 [ 21,08 ] .125 [ 3,18 ] OF WHEEL .020 [ 0,51 ] 4.00 ±.25 Ø.128 ± .002 [ 3,25 ] THRU HOLE X2 .515 [ 13,08 ] AMP CONNECTOR PN 7-215083-6 .114 ±.015 [ 2,9 ] .650 [ 16,51 ] .640 [ 16,26 ] .970 [ 24,64 ] R.250 [ 6,35 ] Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders WAVEFORM AND TRUTH TABLE +5Vdc R* OUTPUT "A" OUTPUT "B" R* 90˚± 45˚ 1 2 HIGH (3.8-5V) 3 OUTPUT A LOW (0-.8V) GROUND 4 PUSHBUTTON 5 PUSHBUTTON 6 POSITION OUTPUT B #2 N.O., MOMENTARY PUSHBUTTON SWITCH HIGH (3.8-5V) #3 OUTPUT B LOW (0-.8V) #4 POS #1 POS #2 POS #3 POS #4 POS #5 POS #6 R* - TWO 2.2K RESISTORS REQUIRED FOR OPERATION. SPECIFICATIONS Operating Temperature Range: -400 C to 850 C Storage Temperature Range: -550 C to 1000 C Humidity: 240 hours at 95% humidity at 300 C Mechanical Vibration: Harmonic motion with amplitude of 15g, within a varied frequency of 10 to 2000 Hz Mechanical Shock: Test 1: 100g for 6 ms half-sine wave with a velocity change of 12.3 ft/sec Test 2: 100g for 6 ms sawtooth wave with a velocity change of 9.7 ft/sec Rating: 10mA @ 5 Vdc Contact Resistance:
62T22-M7-040C 价格&库存
很抱歉,暂时无法提供与“62T22-M7-040C”相匹配的价格&库存,您可以联系我们找货
