Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product.
Optical Encoders
SERIES 60AD
Optical Encoder with integrated
Joystick and Pushbutton
FEATURES
• Dome contacts provide excellent tactile feedback in all directions
• Choices of actuation force, cable length and termination
• Customized solutions available
APPLICATIONS
• Aerospace
• Automotive
• Medical devices
DIMENSIONS in inches (and millimeters)
Pin Version
.250
[6,35]
.219
[5,56]
.408
[10,36]
.040
[1,02]
.582
[14,78]
.125
[3,18]
PIVOT POINT
Unless otherwise specified, standard tolerance are:
Linear ± .025
Diameter ± .010
Angle ± 2.0°
Optical and Mechanical
Encoders
.205
[5,21]
.950
[24,13]
.886
[22,5]
.940±.020
[23,88±0,5]
Recommended Panel Cut Out
.652 ± .003
[ 16,56 ± 0,07 ]
SECTION A-A
Cable Connector Version
.250
[6,35]
.219
[5,56]
.408
[10,36]
.125
[3,18]
PIVOT POINT
.582
[14,78]
Ø.679 ± .003
[ 17,25 ± 0,07 ]
.040
[1,02]
.205
[5,21]
.950
[24,13]
.886
[22,5]
.460
[11,68]
CABLE LENGTH
.200
[ 5,08]
Connector: Amp 215083-8
Mating Connector: Amp 215079-8
SECTION A-A
ORDERING INFORMATION
60AD18-4-M-060S
Angle of Throw: 18= 18° or 20 positions
Joystick: 4= Four contacts & directions;
8= Four contacts & eight directions
L
1 ACTUATION FORCE (JOYSTICK) [g]
550±200
OPTION
M
725±200
H
1050±250
2 ACTUATION FORCE (PUSHBUTTON) [g]
625±200
800±200
1100±250
3 AVERAGE ROTATIONAL TORQUE [in-oz]
1.50±0.75
3.50±1.75
5.00±2.00
Termination: 0.050" center P= pin header; C= connector; S= stripped cable
Cable Length: 020 thru 250 in 1/2 inch increments, 060= 6.0 inch cable
Force Option: (see table) L=low, M=medium, H=high
For prices and custom configurations, contact a local sales office, an authorized distributor, or Grayhill's sales department.
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Optical Encoders
JOYSTICK OPERATION + ENCODER WAVEFORM AND TRUTH TABLE Standard Quadrature 2-Bit Code
NEUTRAL
NEUTRAL
NEUTRAL
NEUTRAL
SPECIFICATIONS
Rotary Specifications
Operating Voltage: 5.00 ± 0.25 Vdc
Supply Current: 20mA max at 5 Vdc
Minimum Sink Current: 2.0mA at 5 Vdc
Power Consumption: 100 mW max at 5 Vdc
Output: Open collector phototransistor,
2.2k W external pull-up resistors are required
Output Code: 2-Bit quadrature, channel A
leads channel B by 90° in clockwise rotation
Logic Output Characteristics:
High: No less than 3.5 Vdc
Low: No greater than 1.0 Vdc
Mechanical Life: 1 million rotational cycles
(through all positions and a full return)
Rotational Torque: see table
Maximum Rotational Speed: 100 RPM
Mounting Torque: 15 in-lbs. maximum
Shaft Push/Pull Out Force: 45 lbs min.
Shaft Side-Load Force: 20 lbs. max.
Terminal Strength: 15 lbs pull-out force min.
Pushbutton Specifications
Rating: 10 mA at 5 Vdc resistive
Contact Resistance: less than 10 ohms
Contact Bounce: < 4ms make, 4.5 Vdc
Low-State Position:
很抱歉,暂时无法提供与“60AD18-8-L-025C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+866.5874925+112.10632
