60AD18-4-H-P
60AD18-4-H-P
    GRAYHILLINC.
    OPTICAL ENCODER
60AD18-4-H-P 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 60AD Optical Encoder with integrated Joystick and Pushbutton FEATURES • Dome contacts provide excellent tactile feedback in all directions • Choices of actuation force, cable length and termination • Customized solutions available APPLICATIONS • Aerospace • Automotive • Medical devices DIMENSIONS in inches (and millimeters) Pin Version .250 [6,35] .219 [5,56] .408 [10,36] .040 [1,02] .582 [14,78] .125 [3,18] PIVOT POINT Unless otherwise specified, standard tolerance are: Linear ± .025 Diameter ± .010 Angle ± 2.0° Optical and Mechanical Encoders .205 [5,21] .950 [24,13] .886 [22,5] .940±.020 [23,88±0,5] Recommended Panel Cut Out .652 ± .003 [ 16,56 ± 0,07 ] SECTION A-A Cable Connector Version .250 [6,35] .219 [5,56] .408 [10,36] .125 [3,18] PIVOT POINT .582 [14,78] Ø.679 ± .003 [ 17,25 ± 0,07 ] .040 [1,02] .205 [5,21] .950 [24,13] .886 [22,5] .460 [11,68] CABLE LENGTH .200 [ 5,08] Connector: Amp 215083-8 Mating Connector: Amp 215079-8 SECTION A-A ORDERING INFORMATION 60AD18-4-M-060S Angle of Throw: 18= 18° or 20 positions Joystick: 4= Four contacts & directions; 8= Four contacts & eight directions L 1 ACTUATION FORCE (JOYSTICK) [g] 550±200 OPTION M 725±200 H 1050±250 2 ACTUATION FORCE (PUSHBUTTON) [g] 625±200 800±200 1100±250 3 AVERAGE ROTATIONAL TORQUE [in-oz] 1.50±0.75 3.50±1.75 5.00±2.00 Termination: 0.050" center P= pin header; C= connector; S= stripped cable Cable Length: 020 thru 250 in 1/2 inch increments, 060= 6.0 inch cable Force Option: (see table) L=low, M=medium, H=high For prices and custom configurations, contact a local sales office, an authorized distributor, or Grayhill's sales department. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders JOYSTICK OPERATION + ENCODER WAVEFORM AND TRUTH TABLE Standard Quadrature 2-Bit Code NEUTRAL NEUTRAL NEUTRAL NEUTRAL SPECIFICATIONS Rotary Specifications Operating Voltage: 5.00 ± 0.25 Vdc Supply Current: 20mA max at 5 Vdc Minimum Sink Current: 2.0mA at 5 Vdc Power Consumption: 100 mW max at 5 Vdc Output: Open collector phototransistor, 2.2k W external pull-up resistors are required Output Code: 2-Bit quadrature, channel A leads channel B by 90° in clockwise rotation Logic Output Characteristics: High: No less than 3.5 Vdc Low: No greater than 1.0 Vdc Mechanical Life: 1 million rotational cycles (through all positions and a full return) Rotational Torque: see table Maximum Rotational Speed: 100 RPM Mounting Torque: 15 in-lbs. maximum Shaft Push/Pull Out Force: 45 lbs min. Shaft Side-Load Force: 20 lbs. max. Terminal Strength: 15 lbs pull-out force min. Pushbutton Specifications Rating: 10 mA at 5 Vdc resistive Contact Resistance: less than 10 ohms Contact Bounce: < 4ms make, 4.5 Vdc Low-State Position:
60AD18-4-H-P 价格&库存
很抱歉,暂时无法提供与“60AD18-4-H-P”相匹配的价格&库存,您可以联系我们找货
60AD18-4-H-P
    • 1+1405.91160
    • 200+560.97360
    • 500+542.22480
