PART NUMBER
REV.
PART DESCRIPTION
ITEM
Q'TY
1
1
H-178C-2
T-1¾ (5mm) LED Holder, 90° Mount
2
1
5XX
T-1¾ (5mm) Non-Flange LED, See Page 2
1
D
E
F
G
H
DESCRIPTION
Updated LED Protrusion from .215 to .200
Corrected Typo
Updated Specs, Page 2
Added 5UUYC LED
Engineering Update w/o Changes
DATE
APPROVED
01/09/07
02/13/07
02/10/09
03/25/10
06/20/16
M. C.
M. C.
T. Y.
T. Y.
J. C.
2
0.200 [5.1mm]
0.350 [8.9mm]
0.250 [6.4mm]
Ø.206 [Ø5.2mm] H-178C-2
0.190 [4.8mm]
Ø.197 [Ø5.0mm] LED
0.240 [6.1mm]
0.120 [3.0mm]
0.157 [4.0mm]
0.100 [2.5mm]
0.200 [5.1mm]
0.020 [0.5mm] SQ. TYP.
Holder Faces
0.200 [5.1mm]
Ø.032+.003
-.002
TYP.
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
03/05/04
DATE:
03/05/04
T-1¾ (5MM)
90° SINGLE-LEVEL LED ASSY
REVISION:
PART NO:
H178CXX
CAGE CODE : 32559
H
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
Electro-Optical Data
LED Assy. No.
Peak Wave
Length
λp(nm )
Em itted Color
Lens
Appearance
If
(m A)
TYP
STANDARD
Iv
(m cd)
Vf
(V)
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
LED P/N
Data @ 20m A
H178CBWD
430
BLUE
DIFFUSED
4.5
15
45
5BWD
H178CGD
568
GREEN
DIFFUSED
2.8
25
45
5GD
H178CSGD
568
GREEN
DIFFUSED
2.8
30
45
5SGD
H178CSUGC
570
GREEN
WATER CLEAR
2.4
400
35
5SUGC
H178CYD
590
YELLOW
DIFFUSED
2.8
25
45
5YD
H178CSYD
590
YELLOW
DIFFUSED
2.4
300
45
5SYD
H178CUUYC
590
YELLOW
WATER CLEAR
2.4
500
35
5UUYC
H178CAD
605
AMBER
DIFFUSED
2.8
25
45
5AD
H178CHD
625
HE RED
DIFFUSED
2.8
25
45
5HD
H178CRD
700
RED
DIFFUSED
2.8
2
45
5RD
H178CSRD
645
RED
DIFFUSED
2.4
40
45
5SRD
LOW CURRENT
Data @ 2m A
H178CGDL
568
GREEN
DIFFUSED
2
2.1
2.6
5
45
5GDL
H178CYDL
590
YELLOW
DIFFUSED
2
2.0
2.6
4
45
5YDL
H178CHDL
625
HE RED
DIFFUSED
2
2.0
2.6
5
45
5HDL
5 VOLT
Data @ 5V
H178CGD5V
568
GREEN
DIFFUSED
10
5.0
25
45
5GD5V
H178CYD5V
590
YELLOW
DIFFUSED
10
5.0
5YD5V
H178CHD5V
625
HE RED
DIFFUSED
10
5.0
50
45
5HD5V
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
T-1¾ (5MM)
REVISION:
PART NO:
H178CXX
CAGE CODE : 32559
H
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H178CGD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.161651+1.18424
- 5+7.701735+0.99553
- 10+6.4778510+0.83733
- 100+4.90428100+0.63393
- 国内价格
- 1+8.51276
- 5+7.15566
- 10+6.01895
- 100+4.55643
