PRODUCT FAMILY DATA SHEET
C503B-Axx-015: 5-mm Round Amber LEDs
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
Round LEDs offer superior light output • Size (mm): 5
• Electronic Signs & Signals (ESS)
for excellent readability in sunlight and
• Motorway Signs
dependable performance. They provide • Color and Typical Dominant
• Variable Message Sign (VMS)
extremely stable light output over long
Wavelength:
• Advertising Signs
periods of time.
Amber (591nm)
• Petrol Signs
• Amusement
These lamps are made with an advanced
optical-grade epoxy offering superior hightemperature and high-moisture-resistance
• Luminous Intensity (mcd)
C503B-AAS/AAN-015:
(12000-32900)
• Roadway Signs
performance in outdoor signal and sign • Viewing angles:
applications.
C503B-AAS/AAN-015
15 degree minimum
• Lead - Free
• RoHS Compliant
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the
Cree LED logo is a trademark, of Cree, Inc.
CLD-CT1213
REV 4
1
C503B-Axx-015: 5-MM ROUND AMBER LEDS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
IF
50 Note1
mA
IFP
200
mA
Reverse Voltage
VR
5
V
Power Dissipation
PD
130
mW
Operation Temperature
Topr
-40 ~ +100
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Lead Soldering Temperature
Tsol
Max. 260°C for 3 sec. max.
(3 mm from the base of the epoxy bulb)
Electrostatic Discharge
Classification (MIL-STD-883E)
ESD
Class 2
Forward Current
Peak Forward Current
Note2
Note:
1.
For long term performance the drive currents between 10mA and 30mA are recommended. Please contact Cree LED sales representative for more
information on recommended drive conditions.
2.
Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Symbol
Condition
Unit
Minimum
Typical
Forward Voltage
VF
IF = 20 mA
V
Reverse Current
IR
VR = 5 V
μA
Dominant Wavelength
λD
IF = 20 mA
nm
584
591
Luminous Intensity
IV
IF = 20 mA
mcd
12000
15000
50% Power Angle
2θ½
IF = 20 mA
deg
15
2.1
Maximum
2.6
100
596
Continuous reverse voltage can cause LED damage.
CLD-CT1213
REV 4
2
INTENSITY BIN LIMIT
Amber
15° min(20 mA) - C503B-AAS/AAN-015
Bin Code
Min.(mcd)
Max.(mcd)
A0
12000
16800
B0
16800
23500
C0
23500
32900
Tolerance of measurement of luminous intensity is ±15%
COLOR BIN LIMIT
Amber (20 mA) - C503B-Axx
Bin Code
Min.(nm)
Max.(nm)
A2
584
587
A3
587
590
A4
590
593
A5
593
596
Tolerance of measurement of dominant wavelength is ±1 nm.
CLD-CT1213
REV 4
3
ORDER CODE TABLE
Color
Amber
Viewing
Angle
15°
Order Code
Dominant Wavelength
Package
Standoff
596
Bulk
Yes
593
Bulk
Yes
A5
596
Bulk
No
A4
593
Bulk
No
584
A5
596
Ammo
Yes
587
A4
593
Ammo
Yes
A2
584
A5
596
Ammo
No
A3
587
A4
593
Ammo
No
Min.
Max.
Color Bin
Min.(nm)
Color Bin
Max.(nm)
C503B-AAS-CA0C0251-015
12000
32900
A2
584
A5
C503B-AAS-CA0C0341-015
12000
32900
A3
587
A4
C503B-AAN-CA0C0251-015
12000
32900
A2
584
C503B-AAN-CA0C0341-015
12000
32900
A3
587
C503B-AAS-CA0C0252-015
12000
32900
A2
C503B-AAS-CA0C0342-015
12000
32900
A3
C503B-AAN-CA0C0252-015
12000
32900
C503B-AAN-CA0C0342-015
12000
32900
Notes:
The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin
code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable.
Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions.
Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT1213
REV 4
4
GRAPHS
The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED.
Hence, these data will be changed without further notice.
(RELATIVE LUMINOUS INTENSITY)
IF (mA)
100.0
5.0
80.0
4.0
60.0
3.0
40.0
2.0
20.0
1.0
0.0
1.8
VF(V)
2.0
2.2
2.4
2.6
0.0
0.0
2.8
-60
-50
-40
-30
-20
40
60
80
IF(mA)
100
FIG.2 RELATIVE LUMINOUS INTENSITY VS.
FORWARD CURRENT
FIG.1 FORWARD CURRENT VS.
FORWARD VOLTAGE.
Vr(V)
-10
100%
-10
80%
-20
60%
-30
40%
-40
20%
0%
300
-50
Ir(uA)
FIG.3 REVERSE CURRENT
VS. REVERSE VOLTAGE.
IF(mA)
100
500
400
600
700
WL(nm)
800
FIG.4 RELATIVE LUMINOUS INTENSITY VS.
WAVELENGTH.
50% Power Angle : 15
C503B-AAS/AAN-015
80
60
0.5
40
Ta( C)
40
80
100
FIG.5 MAXIMUM FORWARD DC CURRENT VS AMBIENT
TEMPERATURE (Tjmax=110 C)
-60
-30
60
Angle
90
FIG.6 FAR FIELD PATTERN
CLD-CT1213
REV 4
5
MECHANICAL DIMENSIONS
All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted.
An epoxy meniscus may extend about 1.5 mm down the leads.
Burr around bottom of epoxy may be 0.5 mm max.
C503B-AAS-015:
C503B-AAN-015:
NOTES
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result.
CLD-CT1213
REV 4
6
KIT NUMBER SYSTEM
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted
LEDs are packaged for shipping in various convenient options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
CLD-CT1213
REV 4
7
SOLDERING GUIDELINES
The LED soldering specification is shown below(suitable for both leaded solder & lead-free solder):
Manual Soldering
Soldering iron
35 W max
Temperature
300 ºC max
Soldering time
Position
Solder Dipping
Preheat
110 ºC max
Preheat time
60 seconds max
Solder-bath temperature
260 ºC Max
3 seconds max
Dipping time
5 seconds max
Not less than 3 mm from the base of the package.
Position
• Manual soldering onto the PCB is not recommended because soldering time is uncontrollable.
• The recommended wave soldering is as below:
300
laminar wave
Temperature ºC
250
200
150
100
50
30
Fluxing
Preheat
10
40
50
60
70
Times (sec)
80
90
100
110
120
• Do not apply any stress to the LED package, particularly when heated.
• Only bottom preheat is suggested & should not preheat on top in order to reduce thermal stress experienced by the LEDs.
• The LEDs must not be re used once they have been extracted from PCB.
• After soldering the LEDs, the package should be protected from mechanical shock or vibration until the LEDs have reached 40 ºC or
below.
• Precautions must be taken as mechanical stress on the LEDs may be caused by PCB warpage or from the clinching and cutting of
the LED leads.
• When it is necessary to clam the LEDs during soldering, it is important to ensure no mechanical stress is exerted on the LEDs.
• Cut the LED lead at normal room temperature. Lead cutting at high temperature may cause failure of the LEDs.
• Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT1213
REV 4
8
PACKAGING
• The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
• Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation.
• The boxes are not water resistant, and they must be kept away from water and moisture.
• Max 500 pcs per bulk and Max 2500 pcs per ammo.
Bulk Pack Packaging Type:
Ammo Pack Packaging Type:
xxx xxx
R
COLOR LED LAMP
TYPE
LXXXXXXXX-XXX
LOT
JOWAXXXXX -XX-XXX
QTY
RANK
PCS
Iv
X
Vf
XX
Hue
XX
AXXXXXXXXXXX
Label
(anti-electrostatic
bag)
20 bags/carton
CLD-CT1213
REV 4
9
很抱歉,暂时无法提供与“C503B-ACS-CW0Y0251”相匹配的价格&库存,您可以联系我们找货
