G21.B.W.301111
G21.B.W.301111
    TAOGLASLIMITED
    G21.B.W.301111
G21.B.W.301111 数据手册
Specification Part No. : Product Name : G21.W Hercules Gen.II Penta Band Cellular Antenna Screw-mount (Permanent mount)- White Version 850/900/1800/1900/2100 MHz Features : • • • • • G21.B.W.301111 • Low profile - Height 29mm and diameter 49mm Heavy duty screw mount UV and Vandal resistant White ABS housing IP65 Rated Enclosure Standard is 3M Cable RG174 SMA(M)-Customizable ROHS & REACH Compliant SPE-12-8-155-D Page 1 of 21 1. Introduction The G21.W (Generation II) Hercules is a high performance steel thread-mount Pentaband cellular antenna for external use on vehicles and outdoor assets worldwide. Omnidirectional high gain across all bands ensures constant reception and transmission. Durable UV resistant ABS housing is IP65 rated, resistant to vandalism and direct attack. At only 29 mm height it complies with the latest EU height restrictions directives for roofmounted objects, with a diameter of 49 mm. Designed to not catch on tree-branches. This antenna can be mounted on metal structures. 2. Specification ELECTRICAL CELLULAR Standard AMPS GSM DCS PCS 3G Band (MHz) 850 900 1800 1900 2100 Frequency (MHz) 824-896 880-960 1710-1880 1850-1990 1920 –2170 0.3 -6.0 -5.2 -6.1 -6.2 -5.8 1.0 -7.8 -8.7 -11.4 -15.3 -13.7 2.0 -8.1 -9.3 -16.5 -20.3 -19.5 3.0 -11.0 -12.4 -17.5 -18.3 -18.1 5.0 -11.8 -13.6 -17.6 -17.8 -17.8 0.3 51.1 41.4 38.0 46.5 32.3 1.0 29.4 40.2 42.2 43.4 29.9 2.0 24.3 27.5 28.4 20.2 19.6 3.0 24.6 27.6 22.0 17.8 15.0 5.0 17.1 16.4 15.7 15.0 12.0 0.3 1.8 0.8 1.3 3.9 1.5 1.0 1.0 2.2 0.6 1.6 -0.3 2.0 0.9 1.8 0.2 -0.7 -1.1 3.0 0.8 0.9 -1.0 -1.1 -2.2 5.0 -1.0 -0.5 -4.5 -4.2 -4.3 Return Loss (dB) Cable length (meter) Efficiency (%) Cable length (meter) Gain (dBi) Cable length (meter) Polarization Linear Impedance 50 ohms Max Input Power VSWR 10 watts
G21.B.W.301111 价格&库存
很抱歉,暂时无法提供与“G21.B.W.301111”相匹配的价格&库存,您可以联系我们找货
