PRODUCT FAMILY DATA SHEET
C503D-WAN: 5-mm Round White LED
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
Round LEDs offer superior light output • Size (mm): 5
• Torch
for excellent readability in sunlight and
• Channel Letter
dependable performance. They provide • Color Temperatures:
extremely stable light output over long
periods of time.
These lamps are made with an
advanced optical grade epoxy
offering superior high temperature
and high moisture resistance
• Retail Display Lighting
Cool White :
Min . (4600K) / Typical (9000K)
• Luminous Intensity (mcd)
C503D-WAN:(28200-64600)
• Viewing angles:
15°: C503D-WAN
performance in lighting and
illumination applications.
• Lead - Free
• RoHS Compliant
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the
Cree LED logo is a trademark, of Cree, Inc.
CLD-CT935
REV 9
1
C503D-WAN: 5-mm ROUND WHITE LED
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
IF
30
mA
IFP
100
mA
Reverse Voltage
VR
5
V
Power Dissipation
PD
120
mW
Operation Temperature
Topr
-40 ~ +95
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Lead Soldering Temperature
Tsol
Forward Current
Peak Forward Current
Note 1
Max. 260°C for 3 sec. max.
(3 mm from the base of the epoxy bulb)
Note:
1.
Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Symbol
Condition
Unit
Forward Voltage
VF
IF = 20 mA
V
Reverse Current
IR
VR = 5 V
μA
Luminous Intensity
IV
IF = 20 mA
mcd
Chromaticity
Coordinates
x
IF = 20 mA
50% Power Angle
y
IF = 20 mA
2θ½
IF = 20 mA
Minimum
Typical
3.2
Maximum
4.0
100
28200
48000
0.2895
0.2905
deg
15
Continuous reverse voltage can cause LED damage.
CLD-CT935
REV 9
2
INTENSITY BIN LIMIT
Cool White (20 mA) - C503D-WAN
Bin Code
Min.(mcd)
Max.(mcd)
Cb
28200
32900
Da
32900
39500
Db
39500
46100
Ea
46100
55350
Eb
55350
64600
Tolerance of measurement of luminous intensity is ±15%
VOLTAGE BIN LIMIT
Bin Code
Min. (V)
Max. (V)
27
2.8
3.0
28
3.0
3.2
29
3.2
3.4
2a
3.4
3.6
2b
3.6
3.8
2c
3.8
4.0
Tolerance of measurement of voltage is ±0.05V
CLD-CT935
REV 9
3
COLOR BIN LIMIT
Bin
Code
Sub-bin
Wa
Wb
W1
Wc
Wd
We
Wf
W2
Wg
Wh
x
y
Bin
Code
Sub-bin
x
y
Bin
Code
Sub-bin
x
y
0.2545
0.2480
0.2830
0.3050
0.3300
0.3600
0.2633
0.2410
0.2950
0.3210
0.3455
0.3725
0.2545
0.2245
0.2998
0.3028
0.3443
0.3535
0.2450
0.2290
0.2895
0.2905
0.3300
0.3390
Wj
Wt
0.2633
0.2410
0.2895
0.2905
0.3300
0.3390
0.2720
0.2340
0.2998
0.3028
0.3443
0.3535
0.2640
0.2200
0.3045
0.2865
0.3430
0.3345
0.2545
0.2245
0.2960
0.2760
0.3300
0.3180
0.2950
0.3210
0.3455
0.3725
0.3070
0.3370
0.3610
0.3850
Wk
W3
Wu
W5
0.2545
0.2480
0.2640
0.2670
0.2720
0.2575
0.3100
0.3150
0.3585
0.3680
0.2633
0.2410
0.2998
0.3028
0.3443
0.3535
Wm
Wv
0.2633
0.2410
0.2998
0.3028
0.3443
0.3535
0.2720
0.2575
0.3100
0.3150
0.3585
0.3680
0.2800
0.2480
0.3130
0.2970
0.3560
0.3510
0.2720
0.2340
0.3045
0.2865
0.3430
0.3345
Wn
0.2640
0.2670
0.3070
0.3370
0.2735
0.2860
0.3185
0.3485
0.2808
0.2740
0.3200
0.3270
0.2720
0.2575
0.3100
0.3150
0.2720
0.2575
0.3100
0.3150
0.2808
0.2740
0.3200
0.3270
0.2880
0.2620
0.3215
0.3075
0.2800
0.2480
0.3130
0.2970
0.2735
0.2860
0.3185
0.3485
0.2830
0.3050
0.3300
0.3600
0.2895
0.2905
0.3300
0.3390
0.2808
0.2740
0.3200
0.3270
0.2808
0.2740
0.3200
0.3270
0.2895
0.2905
0.3300
0.3390
0.2960
0.2760
0.3300
0.3180
0.2880
0.2620
0.3215
0.3075
Wp
Wq
W4
Wr
Ws
Ww
Tolerance of measurement of the color coordinates is ±0.01
CLD-CT935
REV 9
4
00
K
CIE CHROMATICITY DIAGRAM
00
K
50
0 .3 9 0 0
00
70
K
80
00
W
0 .1 9 0 0
0 .2 3 0 0
aW
b
W
f
3
k
h
d
1
W
c
W
n
W
W
e
q
W
W
0 .2 7 0 0
g
W
W
s
2
y
W
j
W
W
W
u
w
W
10
00
W
m
p
r W
W
W
90
00
K
W
0K
0 .3 1 0 0
0 .2 3 0 0
W
t
4
0 .3 5 0 0
5
K
W
v
W
60
W
0 .2 7 0 0
0 .3 1 0 0
0 .3 5 0 0
0 .3 9 0 0
x
CLD-CT935
REV 9
5
ORDER CODE TABLE
Color
Cool White
Viewing
Angle
15°
Kit Number
Color Bin Code
Package
64600
W1,W2,W3,W4,W5
Bulk
64600
W2,W3
Bulk
28200
64600
W1,W2,W3,W4,W5
Ammo
28200
64600
W2,W3
Ammo
Min.
Max.
C503D-WAN-CCbEb151
28200
C503D-WAN-CCbEb231
28200
C503D-WAN-CCbEb152
C503D-WAN-CCbEb232
Notes:
The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin
code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable.
Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions.
Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT935
REV 9
6
GRAPHS
The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED.
Hence, these data will be changed without further notice.
CLD-CT935
REV 9
7
MECHANICAL DIMENSIONS
All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted.
An epoxy meniscus may extend about 1.5 mm down the leads.
Burr around bottom of epoxy may be 0.5 mm max.
NOTES
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result.
CLD-CT935
REV 9
8
KIT NUMBER SYSTEM
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted
LEDs are packaged for shipping in various convenient options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
CLD-CT935
REV 9
9
SOLDERING GUIDELINES
The LED soldering specification is shown below(suitable for both leaded solder & lead-free solder):
Manual Soldering
Soldering iron
35 W max
Temperature
300 ºC max
Soldering time
Position
Solder Dipping
Preheat
110 ºC max
Preheat time
60 seconds max
Solder-bath temperature
260 ºC Max
3 seconds max
Dipping time
5 seconds max
Not less than 3 mm from the base of the package.
Position
• Manual soldering onto the PCB is not recommended because soldering time is uncontrollable.
• The recommended wave soldering is as below:
300
laminar wave
Temperature ºC
250
200
150
100
50
30
Fluxing
Preheat
10
40
50
60
70
Times (sec)
80
90
100
110
120
• Do not apply any stress to the LED package, particularly when heated.
• Only bottom preheat is suggested & should not preheat on top in order to reduce thermal stress experienced by the LEDs.
• The LEDs must not be re used once they have been extracted from PCB.
• After soldering the LEDs, the package should be protected from mechanical shock or vibration until the LEDs have reached 40 ºC or
below.
• Precautions must be taken as mechanical stress on the LEDs may be caused by PCB warpage or from the clinching and cutting of
the LED leads.
• When it is necessary to clam the LEDs during soldering, it is important to ensure no mechanical stress is exerted on the LEDs.
• Cut the LED lead at normal room temperature. Lead cutting at high temperature may cause failure of the LEDs.
• Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT935
REV 9
10
PACKAGING
• The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
• Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation.
• The boxes are not water resistant, and they must be kept away from water and moisture.
• Max 500 pcs per bulk and Max 2500 pcs per ammo.
Bulk Pack Packaging Type:
Ammo Pack Packaging Type:
xxx xxx
R
COLOR LED LAMP
TYPE
LXXXXXXXX-XXX
LOT
JOWAXXXXX -XX-XXX
QTY
RANK
PCS
Iv
X
Vf
XX
Hue
XX
AXXXXXXXXXXX
Label
(anti-electrostatic
bag)
20 bags/carton
CLD-CT935
REV 9
11
