FW.43.B.SMA.M
FW.43.B.SMA.M
    TAOGLASLIMITED
    FW.43.B.SMA.M
FW.43.B.SMA.M 数据手册
Meteor Part No: FW.43.B.SMA.M Description: Meteor ISM Band 433MHz Flexible Whip Monopole Antenna SMA(M) Straight Features: External ISM Band 433MHz Monopole Antenna Designed for Outdoor Use 60%+ efficiency* 0dBi peak gain* Robust Inner Steel Core Antenna Length: 323mm SMA Type(M) Straight Connector IP65 dust and water-resistant *Tested on 30cm*30cm Ground Plane RoHS Compliant SPE-16-8-004/C/WY 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 9 6. Packaging 10 Changelog 11 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-16-8-004/C/WY www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. Introduction The FW.43 is a flexible 433MHz whip antenna with a SMA type (M) connector for outdoor use. It features excellent efficiency (>60%) and peak gain (>0 dBi) at 433MHz on a 30x30 cm ground plane. Common applications are wireless sensor monitoring, smart metering, remote asset monitoring, and security systems. Introduction 1. The FW.43 has an excellent omnidirectional radiation pattern, ensuring wide coverage. The antenna’s high efficiency means that it allows your radio to consume less power than with a lower efficiency antenna when transferring data. It also means a better signal strength and better sensitivity in areas of low signal levels. The antenna performs at its best while attached to a ground plane with dimensions of at least 30x30 cm 1. The FW.43 whip is made of a flexible inner steel core covered by PE so it is extremely resistant to abrasion and maintains its original shape and RF performance even after shock. This rugged design and IP65 waterproof rating on the housing ensure high reliability. Introduction Introduction This antenna comes with SMA(M) connector as standard. Other custom variants can be provided subject to NRE and MOQ. Contact your regional Taoglas office for details. SPE-16-8-004/C/WY www.taoglas.com 3 2. Specifications 3. 433MHz Antenna Characteristics2.ISM Band Specifications 3. 4. Center Frequency 433MHz Design Environment On 30x30cm ground Efficiency 66.42% Antenna Characteristics Peak Gain Return loss < -15dB VSWR ≤ 1.5:1 Antenna Radiation Patterns3.Antenna Impedance Polarization Characteristics2. Radiation Pattern 3. 3. 4. 0.46dBi 50Ω Linear Specifications Omni-Directional Input Power 2W Total Power 10 W Antenna Characteristics2. Specifications Mechanical Dimensions Height 323 ± 10 mm Base Diameter 16 ± 0.6 mm Whip Diameter Antenna Characteristics 6.2 ± 0.6 mm Casing ABS Connector SMA Type(M) Straight Weight 66 g Antenna Radiation Patterns3.Antenna Dust and Water Resistance Characteristics IP65 Environmental Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-16-8-004/C/WY Specifications www.taoglas.com 4 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-004/C/WY www.taoglas.com 5 3.3 Peak Gain 3.4 Average Gain SPE-16-8-004/C/WY www.taoglas.com 6 4. Radiation Patterns 4. 4. 4. 4.1 Antenna Radiation Patterns Test Setup Antenna Radiation Patterns Y X 4. Antenna Radiation Patterns Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. On 30x30 cm ground plane Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-16-8-004/C/WY www.taoglas.com 7 4.2 3D and 2D Radiation Patterns 3-D Radiation Pattern on 30cm*30cm Ground Plane @433MHz XY Plane XZ Plane X Z X Y SPE-16-8-004/C/WY YZ Plane Z Y www.taoglas.com 8 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 8. 6. Packaging Packaging5. SPE-16-8-004/C/WY Mechanical Drawing www.taoglas.com 9 6. Packaging 6. Packaging5. 6. 7. Mechanical Drawing 1pcs FW.43.B.SMA.M per PE Bag Bag Dimensions - 370*50mm Weight - 66g Packaging Application Note6. Packaging5. Mechanical Drawing 6. 6. 7. 50 PE bags per Large PE Bag 50 pcs FW.43.B.SMA.M per Large Polybag Large PE Bag Dimensions - 470*340mm Weight - 3.4Kg Packaging5. Mechanical Drawing Packaging 5 Large PE Bags per Carton 250 pcs FW.43.B.SMA.M per Carton Carton Dimensions - 360*310*180mm Weight - 17Kg Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Pallet Dimensions: 1200*1000*1350mm 63 Cartons Per Pallet 9 Cartons Per Layer 7 Layers Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-004/C/WY Mechanical Drawing www.taoglas.com 10 Changelog for the datasheet SPE-16-8-004 - FW.43.B.SMA.M Revision: C Date: Changes: Changes Made by: 2019-08-16 Updated to new format Dan Cantwell Previous Revisions Revision: B (Current Version) Date: Changes: Changes Made by: 2017-07-01 Reformatted specs and added disclaimer Andy Mahoney Revision: A (Original First Release) Date: Notes: 2015-12-01 Author: Wayne Yang SPE-16-8-004/C/WY www.taoglas.com 11 www.taoglas.com SPE-16-8-004/C/WY © Taoglas www.taoglas.com 12
FW.43.B.SMA.M 价格&库存
很抱歉,暂时无法提供与“FW.43.B.SMA.M”相匹配的价格&库存,您可以联系我们找货
FW.43.B.SMA.M
  • 1+228.913921+29.70885
FW.43.B.SMA.M
    • 1+295.77960
    • 200+118.02240
    • 500+114.08040
    • 1000+112.12560
